Did a compression test today on my 3.0 with 221k on it #716160 04/16/06 08:35 PM
Mike_C Offline OP
I finally went out and bought a new cap and rotor, along with plugs and wires today. And since I had to pull all the old plugs I figured I should do a compression check as well.
I marked all my plug wires before pulling the plugs. Then after I marked them all at the rotor, I noticed they were already marked.... Original wires dated 1988.
All 6 plugs were white, so its on the lean side. But they were not worn to bad yet. But they were champions, I replaced them with NGK's.
I started on the drivers side with cylinder #2 and worked my way back to the fire wall, then I moved on to the other side. So here are the numbers.
#2 178 #1 180
#4 90 #3 172
#6 175 #5 180
So #4 was low, I poured in a bit of oil and tried it again after running the rest of them. It tested out at 174 with some oil in it. So this would mean I have worn rings on that piston, correct?
It idles smoother now, and runs pretty good. And all but one cylinder had good numbers, so I am pretty happy with it.
89 Silver Extra cab Pickup
33x12.5 super swampers on 15x8 cragar rims
Rancho AAL in the rear, stock up front, skyjacker nitro shocks all around.
Re: Did a compression test today on my 3.0 with 221k on it [Re: Mike_C] #716161 04/17/06 05:24 PM
ToyoLoyal Offline
Yes, worn rings.
1997 T100 extracab, 3.4L, 5-speed, 169K, 4x4. Love the truck, never buy anything but toyota, I tried it once, most miserable six months of my life.
PHP: 7.4.33 Page Time: 4.394s Queries: 15 (0.003s) Memory: 0.5871 MB (Peak: 0.6357 MB) Data Comp: Off Server Time: 2026-06-21 01:42:57 UTC
