Re: Top end noise, looking for TECH suggestions [Re: fasteddy] #716269 04/17/06 08:35 PM
Kevin C Offline
I think all the truck V6's have rollers. I would pull a valve cover to look for the source of the noise.
Kevin
Re: Top end noise, looking for TECH suggestions [Re: DaphneD] #716270 04/17/06 11:44 PM
LandRaider Offline
What to look at? Take the covers off and stare at it until the answer squirts me in the eye?
Tech help please.
Sarchasm engine in the final stages of development!? <img src="/forums/images/graemlins/lol.gif" alt="" />
Hate to hear your motor is junk <img src="/forums/images/graemlins/angry.gif" alt="" /> <img src="/forums/images/graemlins/barf.gif" alt="" />
Re: Top end noise, looking for TECH suggestions [Re: Kevin C] #716271 04/18/06 01:13 AM
52degrees Offline
It must be on the cam side then. I don't remember it very well. I'll have to look at the one on my bench at work tomorrow.
Clay
KG6VNX
Re: Top end noise, looking for TECH suggestions [Re: 52degrees] #716272 04/18/06 03:24 AM
FrankR Offline
Mitsu/Raider 3.0Ls had rollers.... the early Chrysler 3.0L variants did not.
Frank
Re: Top end noise, looking for TECH suggestions [Re: DaphneD] #716273 04/18/06 11:59 PM
V
v6lsmonty Offline
Doug,
I had a similiar sound coming from my 3.0 after changing the timing belt. I thought it was the lifters becuase the sound seemed to be coming from the top end. Well, after 3000 miles I decided to take a look. Sure enough the tensioner was loose. Re-adjusted and the sound went away. A look see at the belt is a bit easier than pulling the v-covers in my book (no gaskets).e
1989 Montero LS (sold)
1994 Cherokee Country bone stock
Re: Top end noise, looking for TECH suggestions [Re: v6lsmonty] #716274 04/19/06 12:50 AM
DaphneD Offline OP
Doug,
Honestly, that's the same thought I had just yesterday. Going to check things out this weekend hopefully.
Re: Top end noise, looking for TECH suggestions [Re: DaphneD] #716275 04/20/06 02:35 AM
Tag Offline
I hope that is it. Good luck. If that does not work pour one of your mitsu beers in the oil fill tube it might like that. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Top end noise, looking for TECH suggestions [Re: DaphneD] #716276 04/20/06 05:04 AM
Kevin C Offline
Doug,
I have read that some of the newer oils have less high pressure additives to improve converter life.
It might be that a older engine oil with more EP additives would work better. Also a 10-40 may get you a bit more film strength.
I ahve been running the 5w-40 wt Mobil 1 truck oil with good results.
www.bobistheoilguy.com has good info.
Kevin
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6296 MB (Peak: 0.7288 MB) Data Comp: Off Server Time: 2026-06-21 16:14:56 UTC
