Oh No!! 88 trooper help! #716992 04/19/06 12:48 AM
tobeornottobe Offline OP
oh no what happened.... i stopped and washed truck washed under the hood to get rid of dirty and see where oil leak is from ...drove home and it startesd to sputter , poor power and shake...slowed down to turn corner and it stalled ...started again ....then slowed and it died.....got out and checked antifreeze resevoir is over full.....tried to start again and when it did( some cranking) there was terrible white blue smoke that came out of exhaust......quite a bit also.....had to keep it reved so could so would stay running... HELP!!!!!! what happened??
Re: Oh No!! 88 trooper help! [Re: tobeornottobe] #716993 04/19/06 01:36 AM
litnin Offline
You didn't wash under the hood with the engine hot, did you?
That's a real good way to crack or warp a cylinder head.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: Oh No!! 88 trooper help! [Re: litnin] #716994 04/19/06 02:09 AM
Troopersphere Offline
It was already on it's way out...
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: Oh No!! 88 trooper help! [Re: Troopersphere] #716995 04/19/06 06:39 AM
thepcguy Offline
Time to look into a head gasket change. How long did you run the truck after the white smoke appeared? You may get lucky and simply have to replace the gasket (like me), or you might be buying a new head. There is all the information you'll need on these forums if you search. Good luck and welcome.
- Jim
1989 Isuzu Trooper II
- 2.6L 4ze1 Motor
- BFGoodrich 235/75/15 AT
Re: Oh No!! 88 trooper help! [Re: tobeornottobe] #716996 04/19/06 07:52 AM
mlclark Offline
Isuzu Moderator
Everything you need to know is,
HERE.
You are dealing with the same problem you had before. In fact, with that low of compression in that one cylinder, you should not have been driving it at all.
Good Luck,
Michael
Re: Oh No!! 88 trooper help! [Re: thepcguy] #716997 04/19/06 04:38 PM
yes i did wash under hood while warm........crap learn the hard way ok wont do that any more, it only ran for about max 2 min. just about 2 blocks..am towing it to mechanics in next couple of days..can i just hook on and throw in "N" and pull it...someone said this may not be a good idea. oh well i guess now ill see whats inside!
thanks
Re: Oh No!! 88 trooper help! [Re: mlclark] #716998 04/19/06 04:42 PM
I should not have been driving it? I did not read that any where!!! oh well guess we see whats going on in there...and yes there is lots of good info that i will relay to my mechanic...thank u will let u know how it goes..
Re: Oh No!! 88 trooper help! [Re: tobeornottobe] #716999 04/19/06 05:36 PM
ISueYou Offline
Typically one wouldn't drive a vehicle that was showing signs of impending doom (low compression)
Jay <img src="/forums/images/graemlins/mrt.gif" alt="" />
1989 Trooper 2.8 V6 5-Speed(the daily driver)- Superwinch Hubs, otherwise Stock - $350
1990 Trooper LS 2.8 V6 Auto - Superwinch Hubs, otherwise stock....for now - $182.50
1983 Chevy Blazer - Stock - $150
No Car Payments - PRICELESS
Re: Oh No!! 88 trooper help! [Re: ISueYou] #717000 04/21/06 04:12 AM
ok well guess now i know!! learned something new then....as i am very uneducated in the auto field. lol thanks hope to have it towed in next few days. then will see whats up!
Re: Oh No!! 88 trooper help! [Re: tobeornottobe] #717001 04/30/06 03:42 AM
I don't mean to oversimplify but did you check your spark plug wires or see if maybe you cracked a plug?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6283 MB (Peak: 0.7200 MB) Data Comp: Off Server Time: 2026-05-31 23:14:54 UTC
