Straight axle for front T100
#717142
04/19/06 01:02 PM
Hafa day to all from the Island of Guam, I'm new here and I need some expert advice. planning to put a front straight axle on my T100 having problem finding correct axle size to use some are saying Dana 60 will do. Any body out there having this problem, or had found the solution your help will be greatly appreciated.
Re: Straight axle for front T100
#717143
04/19/06 09:42 PM
Use SEARCH for straight axle on this forum. This has been discussed numerous times. <img src="/forums/images/graemlins/cheers.gif" alt="" /> Brew
98 T100 SR5 4x4 3.4L auto, TRD Goodies, Bilsteins, engine/TC skids, 2" body/d.train lifts, F/R ARBs, 4.56 R&Ps, Aisin hubs, 255/85R16 Dunlop Rover RVXTs (street), 16x7 +8mm offset wheels, custom bumpers, Warn M8000, Master-pull synth. line
#717144
04/19/06 11:22 PM
Look for posts here by surlynkid, he did a solid front axle swap on his T100.
You should also check over on pirate4x4.com in the toyota section. Surlynkid has more posts there in addition to the ones here on 4x4wire.com
97 T100, 32" BFG/AT, Warn hubs, stock height with Bilstein shocks, Optima battery
#717145
04/20/06 05:37 AM
A 60 will more than do. A lot use 44s. Spring widths are closer to the T100 framerails on a 44 than a 60, but still in the negotiable arena to fit a 60. A high pinion would be better, but you'd need it retubed. You'll need to figure out how to hang and steer whatever you choose, but the steering box is the same as in the Toyota mini sas recipe, so the correct length linkage is not hard to come by. The driveshaft, also, can be a lengthened '84 or '85.
There's 3 or 4 the search should turn up.
~Adam  96 T100: D44, lockers and stuff
#717146
04/20/06 08:47 AM
Just like Adam said. Not that hard to do now. You just need a fullsize chevy dana 44/60 and you will be all set.
Cheers
