Re: lincon locker? [Re: powerRam50] #717189 04/19/06 11:41 PM
open dif is 80$ from pickapart LSD is 250$from junk yard.so I think i'll get the lsd and lock the open dif I have now.The gearing will sill be crap but I will not get stuck on littel things. I have weeled with gys with rear locker only(in 2 weel drive) and was imprest as to how well they did.how will my axels hould up with this set up.
Re: lincon locker? #717190 04/20/06 12:27 AM
IIRC all Gen I V6 monties come w/ the larger diff's/axles. That means slightly bigger than a D44 but smaller than a D60.
Re: lincon locker? [Re: off-roader] #717191 04/20/06 01:14 AM
WOW like a D56 that is good to know. I now have a lot to do, I got some time off to work to fix-up my rigs I am going to pick up a moter for my 74 fj55 on sunday so next week I can weld up my dif and go from there. Oh boy the sickness has got me good
Re: lincon locker? #717192 04/20/06 02:14 AM
Here's a pic of my dif ring gear (1990 v6 automatic).
Re: lincon locker? [Re: off-roader] #717193 04/20/06 01:31 PM
powerRam50 Offline
my rear axle has held up fine being welded and it is smaller than yours.
Re: lincon locker? [Re: powerRam50] #717194 04/22/06 12:46 AM
Fancy87Raider Offline
I still dont know where to weld. i would love to wel the rear in my raider. It never hit the pavement. Clay tried to explain it to me over the phone but i have no idea what part he was telling me to tack together. <img src="/forums/images/graemlins/confused.gif" alt="" />
87 Raider-31x10.5 Trexus M/T,5" Shackels,T-Bars jacked up,home made CHOP-TOP
Re: lincon locker? [Re: Fancy87Raider] #717195 04/22/06 02:09 AM
CapnCrunch Offline
I don't know for sure if there are any specific locations to weld or not to weld, but my guess would be to weld the two red gears in this animation so that they can't move:
How Differentials Work on howstuffworks.com
Just make sure to weld them good and solid because a lot of stress can be generated there.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: lincon locker? [Re: CapnCrunch] #717196 04/22/06 06:56 AM
LandRaider Offline
Here is a NICE high res picture of my Welded up front differential.
The Spider gears all get welded together where they touch, and interlace with each other.
The proper way to do it is to pull the case out, pull the ring gear off, and then cover the bearings up with tape so no slag gets into them. Weld it as HOT as you can, and after each super hot pass, stop, and chip ALL the slag out. I mean all of it. Chipping hammer, wirebrush, carb cleaner, chipping hammer wirebrush. I mean get that weld clean.
If you do it right, it will never break.
http://myweb.cableone.net/wmartz/Pictures/Broke.JPG
Remember!!!! This took a 4.3, 3:1 gears, and 33 inch LTB swampers HAMMERING on it to break the axle stub.
Anyone who doubts a lincoln locker.... this should be enough proof. <img src="/forums/images/graemlins/mrt.gif" alt="" /> Tough
For further info on this subject search with my username, and you will find out what you need to know. I have a very detailed post on it somewhere.
Re: lincon locker? [Re: LandRaider] #717197 04/22/06 07:24 PM
For all that may not have the patience for the search function and the sorting through the hundres of posts here it is.....
Re: Welded diffs? [Re: LandRaider]
#465457 - 02/26/04 06:39 PM Edit Reply Quote
Front Differential welding goodness found withen.
Hmm OK here we go. This is how I did it, and I am by no means an expert.
I started the day off buy going to my local pick and pull to scrounge the front diff out of a Gen1 4cyl that Sparkem and I found. I got it out, and brought it home. I took out the carrier, and Unbolted the ring gear from it. The ring gear is set aside, and the carrier is put in the vice with easy acess to the spider gears.
I hosed the spider gears down with Prestone brake parts cleaner, and thats the BEST stuff I can find for cutting grease out of a spray can.
I used the Stumpy axle to stab into the Opposite gear I was welding so as not to spatter any weld into the splines.
The way I saw it, there was a strongest point to the "meshing" of the spider gears, and I posisitioned them to the deepest meshing point I could find. I just started here, and began welding the spider gears together. NOT to the case. I was able to make a few welds before I had to reposisition. I welded all the contact points up, and then got out the chipping hammer.
This is by far where I spent the most time. I chipped all the slag off of my welds, and then chipped off EVERY peice of spatter I could find. I got the wirebrush out, and went over the entire case looking for spatter.
I took 3 passes over the spider gears like this, covering more gear, and overlapping my welds a little. Every pass you have to stop, and chip the slag off, and clean up your spatter, and move your axle stump so as not to get any weld into the splines. (I actually did, but hammering the axle into the splines *pre truck assembly* knocked the spatter out)
I could actually see the spider gears melting into each other, and "becomming one" with one another.
After I welded the spider gears up, I had to let the carrier cool to ambient before the ring gear would go back into it's home due to thermal expansion. I just bolted the ring gear back on, locktighted, and correctly torqued the bolts, and then stuck the carrier back into the housing, and I think I had to hammer one of the shims back in, but it all went back together great.
I did not take any pictures just beacuse this whole project went together so fast, and so smoothly. If you look into my carrier, you can see a nice radiused weld at each contact point of the spider gears. No Huge redneck blobs, and No ultra porus welds. Just nice smooth, and relativly small welds.
The gears are not ever near any welding heat, so this is not a factor. I really feel confident that the welds are not going to break, and IF they do, the whole housing is comming apart with them. (this is why I tried this on a $40 spare diff) I really think the CV's will go first. We shall see. With my turbo, and my driving habits, I will seek and destroy weakness. I have already taken it on the trail, and it performed EXCELENT!!!. Turning was noticable different, BUT if you are rolling even the slightest ammount it is acceptable, and on soft dirt or mud, or sand it is un noticable. I locked the hubs in on the pavement just for grins, and it was impossible.
I used. 6011 rods, and 90 amp setting on my Lincoln stick welder.
You should not weld the gears to the case as they are a dissimilar metal.
Definantly a mod for off road use only. Any more specific questions?
AND of course with my hubs unlocked on the street, it drives like any other car on earth. Totally sane, and nice.
http://www.4x4wire.com/forums/showf...;oldertype=&bodyprev=#Post213161
http://www.4x4wire.com/forums/showf...in=209287&Search=true#Post209290
http://www.4x4wire.com/forums/showf...&o=&fpart=4&vc=1
http://www.4x4wire.com/forums/showf...in=202425&Search=true#Post202432
87 Raider 4.3 700R4 NP231CHD
Dana44 front 9.25 mitsu rear Air Locked
Chevrolet conversion approx 80% complete.
Re: lincon locker? [Re: Fancy87Raider] #717198 04/22/06 08:19 PM
LandRaider Offline
Lloyd? Do you still think those spider gears are the weak link?
<img src="/forums/images/graemlins/lol.gif" alt="" />
This was only a few years ago, but seems like ages in my mind. Thats all gone now. Replaced by Spooled, D44, goodness. Superflex100000. In retrospect, I am glad I did not buy a front arb. ARB costs the same for D44, and Mitsu IFS. <img src="/forums/images/graemlins/smile.gif" alt="" />
Edit. I had 0 problems looking that stuff up.
Mitsu Tech forum
Lincoln for the search
LandRaider for the username
9999999999999 days
25 results. bam. answers.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6464 MB (Peak: 0.7615 MB) Data Comp: Off Server Time: 2026-06-07 05:44:43 UTC
