turbo pondering #717391 04/20/06 08:41 AM
kyle-22r Offline OP
for some time, i've wondered why forced induction isn't more common on our toyota 4 bangers. it seems that almost every other make has successfully been turboed or supercharged, but for some reason, the idea of cramming some extra cubes down the good old 22R-E is sort of taboo.
i was wondering, what it would take to build a reliable turbo engine, using a lower compression ratio(e.g. OE turbo pistons) and either LC's $$$$ turbo kit, or cobbled together from other parts.
the goal would be something simple, no intercoolers or fancy computers -- just something to push things to 22RTE levels. we're mainly going after torque here, otherwise i'd just stick to good old N/A performance. would the factory computer be able to handle it?
'91 4x4 shortbed
22R-E, W56, the dd!
Re: turbo pondering [Re: kyle-22r] #717392 04/20/06 12:29 PM
having done this on my 84 22R 4unner, here's the rundown:
you're going to have to start from a bare block and build it up from there. the big reasons (IMO) why no one turbos a 22re is becuase the stock compression is too high (9.5:1) and the stock computer is too stupid to cope with changes.
I started wit ha blown 22rte long block, but the procedure is pretty much the same.
you'll need 22rte pistons. I wanna say I paid about $95 to EB for them, and he had to gout and find them for me, they're kinda hard to get for a reasonable price. you should also get a 22rte head, or of your engine head is good, open up the chambers to match the 22rte head. EB had new 22rte head castings last I emailed about it, but I think they're like $350. you'll also want the $100 cometic turbo head gasket and the $120 ARP head studs
that should get you up to a long block, after that, you're either going to need to find a stock 22rte exhaust manifold or an aftermarket item. the stock manifolds go for about $75-$200 depending on condition (they like to crack) LCE sells a turbo header/downpipe combo for $750, turbonetics sells a cast iron manifold for lik4 $450, there's a guy on ebay selling log manifolds for $250, and Toysport(?) has an online article about how to weld up your own header for about $200 in tubing and flanges.
then you're going to need a 22rte computer and injectors for fuel management. some have substituted supra turbo injectors for the 22rte ones, but I have not tried this yet, myself.
for the turbo, you'll have to either find a stock ct-20, a supra ct-26, or adapt to a garrett turbo. I bought a core garrett T-3 off of a Merkur xr4ti for $60 and had the center bearing rebuilt for another $100. I built a $20 adpater plate out of 1" plate steel using nothing more than my drill press and a grinder.
everything after this is just plumbing. you have to get air to the turbo from the AFM, and to the throttle body from the turbo. oil has to come from the pressure sending unit on teh passenger side around the back to the turbo and then out the turbo into a bung on the oil pan. if you choose to go with a water cooled turbo (highly reccomended) you'll ahve to plumb into the heater lines to make that happen.
the last thing is the exhaust, and you'll have to weld all that up yourself. I sourced flanges and tubing from ATP and it took me about a day to weld up the whole exhaust syetem. USE A FLEX JOINT or you break something in the system.
that's the most of it.
including the scratch built long block, I spent about $1850.
Re: turbo pondering #717393 04/20/06 06:47 PM
mosk Offline
That's really good advice, Sundowner -- I think you nailed it. The only other item I'd mention is that (IMO) the stock two core radiator is inadequate for a turbo motor; stepping up to a three core would be a very good idea. Oh, and go with the biggest exhaust you can stuff in there: a 2.5" downpipe + 3" exhaust if using a CT20, or a 3" DP + 3" exhaust is using a CT26 or T3.
-Jeff
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: turbo pondering [Re: mosk] #717394 04/20/06 06:52 PM
G
Greg_Canada Offline
I see all this, but there are a few guys on customtacos that are running 15psi boost on their stock long block 2rz's (with metal head gaskets and head studs) and makign 250whp no problem, and they also have a high compression ratio.
Hell, they're turboing completely stock 3.4's and making 350hp.. all of these intercooled of course... and no problems.
Howcome the 22re is so troublesome with boost?
89 4Runner
Re: turbo pondering [Re: Greg_Canada] #717395 04/20/06 07:45 PM
kyle-22r Offline OP
maybe the stock computers on the 2RZ and 5VZ handle timing under boost better? i'm not sure...
would the stock ECU be up to the task of handling say, 6lbs of boost? low compression pistons would definitely be on the list. funny you listed the 3 core radiator as being important, as i just installed one last week(the original was cracked, and the 3 core was only $5 more or something from radiator barn)
what i'm dreaming over is having something mild to drive to work every day, but having that ability to drop a gear, spool that turbo and be able to have a little more of a fighting chance at the passes, or when towing my little boat, etc
'91 4x4 shortbed
22R-E, W56, the dd!
Re: turbo pondering [Re: Greg_Canada] #717396 04/20/06 08:53 PM
you're talking OBDII computers with flashable memory. the 22rte ECU is a pile of resistors orthagonally placed on a piece of square green plasitc. you might as well be asking why you can't play Doom II on your VIC20. <img src="/forums/images/graemlins/wink.gif" alt="" />
can't believe I forgot about the radiator.
I used a 3 core from a 94 V6 truck. it fits. mostly.
and fwiw, I run 8 lbs of boost on the stock rte computer. any more than that and it knocks. you may be able to get more boost or you may knock at less. every engine seems to be a bit different.
I will tell you that my rte with 32's and 4.88 gears will run rings around my 02 xcab 4x4 with the 3.4L/5 speed. and the 4runner a few hundred ponds more than the tacoma
Re: turbo pondering [Re: Greg_Canada] #717397 04/20/06 11:30 PM
mosk Offline
Pretty hard to compare a barely-refined forklift motor like the 22RE/RTE with a DOHC mill like the 2RZ/3RZ.
Of course, people can (and do) turbocharge all sorts of motors, some more successfully than others. The 22RE/RTE has a first generation digital EFI system. It has a very simple closed loop mode, a rudimentary knock detection system, and a very old fashioed flapper-door style AFM. You can stuff a lot more air into it, but the computer doesn't know what to do with that air, and you can open a large can of worms trying to fool the computer into giving the system enough fuel to match the increased air flow. Been there, done that, and it didn't work too well, which is why I ultimately moved to a standalone EFI system. MUCH better, but not financially realistic for most people unless you go the MegaSquirt route, something that wasn't available to me when I was at that point in my project.
As for low boost turbo systems: IF you change to larger injectors you can get away with 3-4 psi on a stock 22RE. If you change to lower compression pistons and larger injectors you can sneak that up to 6 psi or so. It may not be painless, and it may not run smoothly throughout the powerband, but it should tolerate those sorts of numbers, and it will give you an extra 15-20 hp and comparable increases in torque. More than that is definitely pushing it on an otherwise stock 22RE.
Keep in mind, the stock RE makes 116 hp at the flywheel, while the stock RTE only makes 136 hp -- and to make that extra 20 hp, the Toyota engineers gave the 22RTE 50% larger injectors (295cc/min vs. 195 cc/min), a different head, lower compression pistons, and a turbo-specific ECU and AFM. All for a very modest 6 psi of boost.
One point that tends to get overlooked in these discussions is that to be successful and reliable, a turbocharger needs to be integrated as a system, not as a bolt on. This isn't a header or a cat back exhaust -- this is a heat pump, and it will draw more air, use more fuel, generate more heat, and expell more spent gasses as a result of its installation. Do it right and it's your friend, do it wrong and you will get to spend future weekends fixing the stuff that breaks.
Sorry if I sound like I'm beating a dead horse, but I get a lot of email from folks who want 200+ hp for $200 and a weekend's worth of work, and then get unhappy when I tell them that it doesn't work that way. My own experience with this motor tells me that there are definitely better motors out there to turbocharge -- where a modest 6 psi gives you a big seat-of-the-pants thrill, and where the stock fuel system is very tolerant and has all sorts of overhead built into it to accomodate a forced induction system. The 2RZ/3RZ is one of those motors. Unfortunately, the 22RE is NOT. I have spent years and lots of money trying to make a silk purse out of a sow's ear. I now have a very fast sow's ear <img src="/forums/images/graemlins/notooth.gif" alt="" />, and learned a lot about the perils of purse making in the process. I have also have a good sense of when does and doesn't work when you turbocharge this motor. Cutting corners DOES NOT work, at least not long-term. Reliable turbo motors require planning and some sort of budget. They also require reliable fuel injection (which, along with the headgasket, is the biggest Achilles' heel in the 22RTE). The stock RTE EFI setup is perfectly serviceable up to 150-ish hp -- people have taken it a lot higher, but I think it gets flakey above the 150-160 mark. The stock 22RE system -- which looks similar but uses different fuel and spark maps, in addition to different injectors -- can barely handle 140 hp.
Even if you are just playing with the idea in your head, make sure you include a RELIABLE, turbo-friendly EFI system in your plans. In all honesty, the turbo is the easiest part of this system to install, while the tuning is the hardest to get right, while also being the most important.
My .02 cents,
-Jeff
Jeff Moskovitz
Jeff's 22R-TE page
Re: turbo pondering [Re: mosk] #717398 04/21/06 04:39 AM
G
Greg_Canada Offline
My .02 cents,
-Jeff
well put.
You guys want turbo power? Drop a 3rz with a turbo in your truck... heh...
89 4Runner
Re: turbo pondering [Re: Greg_Canada] #717399 04/21/06 05:53 AM
kyle-22r Offline OP
remember, this is all speculation at this point! otherwise i'd be making the guys at LC much richer!
you do raise a lot of good points, mosk. the EFI system as a whole is what kind of throws me off, since i'm mainly a carb guy and i'm still learning the fuely thing.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: turbo pondering [Re: kyle-22r] #717400 04/21/06 02:46 PM
I converted my 84 to efi before I went to a turbo. it makes life a little easier in the long run. my next stop is a magesquirt with spark control. the system has come forward by leaps and bounds in the past few years.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6555 MB (Peak: 0.7981 MB) Data Comp: Off Server Time: 2026-06-21 12:16:01 UTC
