oem (dealer) vs Checker auto?!?! #717587 04/20/06 08:31 PM
sjsjeep Offline OP
I am about to replace timing belt, tensioner and water pump and wanted some options on if it matters where I get the parts.
Re: oem (dealer) vs Checker auto?!?! [Re: sjsjeep] #717588 04/20/06 08:45 PM
CPOM Offline
For about $130 bucks you can get all the parts you need from www.stcharlesauto.com and they are Japan made OEM parts. I have never seen the store brand parts for this application, so I can't comment on the differences but that seems cheap for parts that you KNOW will work correctly for your application without the fear of mistakes being made.
CHRIS
98 Amigo, 92 Pup
Re: oem (dealer) vs Checker auto?!?! [Re: sjsjeep] #717589 04/20/06 09:14 PM
L
Locomigo Offline
Scott, I have a timing belt for a DOHC 3.2L, not certain if that is the same you need or not...
Jerry Lemond is THE MAN when it comes to 'zu parts/knowledge. I would look no further. Here is his email <img src="/forums/images/graemlins/kewl.gif" alt="" />
jlemond@bellsouth.net
Keith
Do not meddle in the affairs of dragons; for you are crunchy and taste good with ketchup.
www.geocities.com/kelling.rm/index.html
Is it May yet?!?!!
Re: oem (dealer) vs Checker auto?!?! [Re: sjsjeep] #717590 04/21/06 12:25 PM
DieselBob Offline
I would have to second the St. Charles Auto. I have purchased several parts through Merlin there and have always received great service and good prices. Just to demonstrate, I priced a part at the local Isuzu dealer $279.00, Merlin @ St. Charles, $192.00. Exact same new OEM part. On any repair/maintenance parts I use the 2 hour rule. If it takes 2 hours or less to replace I will try a local discount parts outlet. Anything over that gets new,OEM parts. Just my experience, but I have never had to return a new,OEM part because it was defective but I have returned several replacement parts from discount chains. JMO.
Re: oem (dealer) vs Checker auto?!?! [Re: Locomigo] #717591 04/22/06 07:23 AM
sjsjeep Offline OP
I bought the sohc one...... Thanks,
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6038 MB (Peak: 0.6697 MB) Data Comp: Off Server Time: 2026-05-28 23:43:27 UTC
