Brake bleeding #718003 04/22/06 05:13 AM
Myredyota Offline OP
So I replaced a leaky driver's side wheel cylinder today and just bled that one. There was no air left. I went to replace the shoes on the other side and decided it would probably be a good idea to replace the wheel cylinder over there also. Again, no air. Now here is the problem. The emergency brake doesn't hold and the pedal is soft, like the rear brakes are not working. Do I need to pull the drums and adjust the parking brake, re-bleed the rear, or both? <img src="/forums/images/graemlins/zombie.gif" alt="" />
[color:"blue"]Carey[/color][b]
[b][color:"red"]89 SR5 Extended Cab 4X4 V6
[/color][color:"blue"]Don't forget to pay your taxes......
Millions of illegal aliens are depending on you!!![/color]
Re: Brake bleeding [Re: Myredyota] #718004 04/22/06 07:21 AM
fourwd1 Offline
Start by pulling the drums and adjusting the shoes.
Then if necessary bleed the brakes in this order:
LR, RR, RF, LF, LSPV.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: Brake bleeding [Re: fourwd1] #718005 04/22/06 03:27 PM
Thank you! I went out and adjusted the shoes and now have good pedal and brakes. That was next on the list last night but I just ran out of daylight and energy. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5930 MB (Peak: 0.6462 MB) Data Comp: Off Server Time: 2026-06-08 18:45:47 UTC
