Forum List Of Everyones Mods #718048 04/22/06 03:31 PM
barak Offline OP
I wanted to try and get a list of everyones mods that they have done or are in the process of doing , in one thread , so that new people , or even people thinking of doing different mods know what has been done , or whats in the process of being done , and by whom , so they can always know who to direct questions at.I'll even go first.Remember this is mods done , or in the process of being done , not stuff you want to do in a year or when you have $$ to do it <img src="/forums/images/graemlins/smile.gif" alt="" />
Engine Mods:
3.4 swap from 95 Camaro
1.6 roller rockers
Hypertech undrive pulleys
Edelbrok chrome valve covers
Edelbrok chrome air filter
Holley TBI (also bored intake)
Jacobs Omni Magnum ignition
Accel 8MM plug wires
Accel high performance distributor cap
new distributor
new oil pump
all new gaskets
new waterpump
new knock sensor
new high torque starter
new headers
oil filter relocation kit with dual filters
transmission cooler
new motor mounts
new flywheel
new radiator
taurus electric fan
delta controller
new thermostat
Trooper Mods:
4" suspenion lift
3" body lift
Darlington drop diff and modified bracket
front lockright locker
rear G80 LSD
new Rancho 9000 and in cab controller
custom fuel cell and all stainless braided lines
custom fuel filters
holley black fuel pump
class 3 hidden hitch
rear tube bumper
33" savero M/T
15x8 polished steel Eagle rims
new ball joints
new rear bushings
new brakes
new brake lines
new Indy4x brake lines
new bushings in the front end
tera low gears in the trans
tabor magnum 9000 winch
50 watt reverse light bulbs (in place of stock 5 watt)
80/110 headlight bulbs (instead of 50/100)
DVD player with 7" screen
2 amps
onboard computer
optima blue top battery
4 6" speakers , 2 6x9 speakers , 1 500 watt sub
lifted the seats 3-4"
newer transmission (9000 miles)
newer transfer case(20,000 miles)
GPS navigation system
2 100 watt off road lights on the front
2 55 watt lights on the back for extra back up lighting
Indy4x tie rods
Aisin manual hubs
new body mount bushings(rubber ones)
added A/C
new A/C compressor
new 100 amp alternator
Thats about all I can think of off hand.I probably did more , but I'm going by memory here , and its not the best at the best of times
<img src="/forums/images/graemlins/nana.gif" alt="" />
Re: Forum List Of Everyones Mods [Re: barak] #718049 04/22/06 05:15 PM
Jim_Paget Offline
You certainly aren't the first person to make a post request like this. Repeatedly it has been met with a very few enthusiastic responses and a whole lot of apathy.
It is my personal belief that many people aren't interested in reading through long lists of mods, some major, some trivial. When I saw the length of your list, I could not bring myself to read through the list. For one thing, some of the items on your list are not mods, but simply replacement parts. Others are plug-in replacements for stock parts. I am much more interested in specific solutions to particular problems.
If people respond, then good for you. I just don't hold out much hope for your request.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Forum List Of Everyones Mods [Re: Jim_Paget] #718050 04/22/06 07:27 PM
paulevans76 Offline
35x12.50's on 15x8 3.75" bs steel
indy4x poly flex joint rear shackle hangars (moved forward from stock ~1.25") w/ longer shackles
a little bit of tbar crank and bj flip (really unneccessary for my miniscule amount of lift)
hacked fenders and beat in wheelwells
home-hacked rear rect. tube bumper
home-hacked rect. rock rails
I tried the front cross-linked air shocks but blew a hole in one of the bags on the first real wheeling trip. now replaced with the cheapest monroes they had at the parts store.
88 Troop - Posing yard art
Re: Forum List Of Everyones Mods [Re: paulevans76] #718051 04/22/06 09:00 PM
Bigpoppax2 Offline
On my 98 Passport
4.77 gears
Aussie locker in the open 2nd gen rear (custom spacers needed)
ARB locker in the front (third member swap needed 98 won't work)
Custom rock bars
Calmini front bumper
Alpine Supercharger
Fender trimmed and body seam removed to clear 33's
Snorkel
Dropped front diff
Joe
Re: Forum List Of Everyones Mods [Re: Bigpoppax2] #718052 04/22/06 09:56 PM
strawmyers Offline
Isuzu Moderator
'93 Amigo XS
AMC head
Delta cam
ARB in rear axle
Tera Lows in t-case
custom rock bars
custom rear bumper
2" suspension lift (DOR Springs Upgradez)
1.25" body lift
1.75" gas tank lift
1.25" dropped front diff
Independent4x Braided SS brake lines
32" Goodyear MT/R's on 15x8 3 5/16" BS Mickey Thompson Classic II's
As a side note, any 'directing' of questions toward a specific board member needs to be handled via PM's. If anyone has a question about a product, they need to make a general audience post. For example, a post titled "Bigpoppax2, tell me about your supercharger" will be locked with a note to PM Joe if you have a question specifically for him." A post titled "Thoughts or opinions on Alpine Superchargers?" is acceptable and will be left open... but I'll still tell the poster to use the search function <img src="/forums/images/graemlins/pfft.gif" alt="" />
BTW, these 'list your mods' posts have been done several times... use the search function <img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Sean Strawmyer
Re: Forum List Of Everyones Mods [Re: strawmyers] #718053 04/22/06 10:24 PM
Iluvmud Offline
95.5 Rodeo
3" body lift
5" susp lift- OME T bars and lift spring packs, Shackles byBansil, ball joint flip and spacers
Rock Sliders by Bansil
Custom front and rear bumpers by yours truly
T-Maxx 9000lb winch
2 Hella 55W driving lights
4 KC 100W daylighters on light bar
33x12.50 Durango MTs on 15x7 "Snowflakes"
Sony Explode sound system
Powertrax locker in the rear
Indy 4x SS brakelines
1pc. drive shaft
8 inches of lift, 33s, custom bumpers and rockbars, powertrax, T-maxx 9000, lots o lights, and some bass in the trunk
Lifted, locked, and ready to rock!!! <img src="/forums/images/graemlins/evil.gif" alt="" />
[url=http://www.cardomain.com/memberpage/743285][/url]
Re: Forum List Of Everyones Mods [Re: Iluvmud] #718054 04/23/06 12:00 AM
ducktrooper Offline
'99 Trooper
OME 912's w/1" Poly spacers
Rancho 9000xs
ARB bullbar w/M8000 winch, Amsteel rope
Front ARB locker
Custom boulder bars
Flowmaster and K&N
33" Kumho MT's
Indy Steel braid lines
Mods being added in 30 days
4.77 gears and rear ARB locker
Darlington diff drop brackets
'99 Trooper, ARBs, 4.77s, ARB bullbar, Warn M8000 w/Amsteel, OME 912s w/2.5" spacers, Rancho 9000xs, K&N/Magnaflow, 33" Kumho MT's, Aisins, boulder bars, Indy 4X brake lines, diff drop, Flexalite
Re: Forum List Of Everyones Mods [Re: ducktrooper] #718055 04/23/06 12:22 AM
onebadtrooper Offline
I've got an 89 trooper Ls 2.8L 5 speed...
Well here's my list.......
Indy4x 3" suspension lift
3" body lift
tera low transfer case gears
tera 5.38 gears f&r
Home made rock sliders
Home made 1/4" front winch bumper
Home made 1/4" rear bumper
Warn m8000 winch
bushwacker fender flares
35x13.5 baja claws
15x10 extreme aloy's
safari snorkle
hella lights
welded rear third
edelbrock extreme travel remote res. shocks
home made 1.5" diff drop
indy4x braided stainless brake lines
K&N air filter
herculined interier
custom dual exhaust 2 1/4", with magna flow muffler
Tie-rod shields
optima yellow top battery
4" gas tank lift.
warn hubs
home made rear quarter rock sliders
custom skid plate
limo window tint 5%
Auto meter, volt meter
pro-comp steering stabalizer
relocated the computer behind the glove box.
Thats pretty much all that I can think of. I'm sure theres other little things, but it already took me too long remembering this much.
Re: Forum List Of Everyones Mods [Re: onebadtrooper] #718056 04/23/06 07:16 AM
maxwell417 Offline
89 Trooper RS
33x10.5R-15 BFG M/T on 15x8 wheels
2" lift, t-bar crank, bj flip, low pro snubbers and welded up some shackles
Calmini Header - 2.25" exhaust - turbo muffler
Warn hubs
Mini-van center console
90 Trooper
3.4 v6 swap
Competion Cams 1.6 roller rockers
GM 4.3 TBI with bored intake, K&N
Hayden electric fan - booster for ac
Tranny cooler
Rerouted 2.5" exhaust - no low dragging crossover pipe
Low profile tranny crossmember
3" suspenion lift, t-bar crank, bj flip and 1/4" spacer, low pro snubbers, DOR spring upgrade, shackles
3" body lift
3" gastank lift
Warn hubs
33x12.5R-15 Procomp M/T on 15x10 wheels
1/2" front drop diff
One piece drive shaft
Ugly front winch bumper HF 8000# winch
Rear bumper airtank filled by Master Flow MF-1050 air compressor underhood
DOR Rocker protection
Hi-lift jack and 5 gal can hanging on back doors
3" JCW fender flares
HF 55W driving lights
Mp3 cd radio
CB Radio
Garmn Etrex on the dash
Fire ex. first aid, 50lbs. tools and recovery junk
...... eventually 5.38s, welded rear .... still under my bed.
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: Forum List Of Everyones Mods [Re: maxwell417] #718057 04/23/06 06:15 PM
9
94redrodeo Offline
Engine & Powertrain
Custom Auto zone intake with K&n cone
2.5" cat back no muffler
Tarus Fan
G80-LSD rear diff
Suspension
3" PA body lift
3" suspension lift from independent4x includes bj spacers add a leafs and shackles
Darlington Tie rod Shieldz
Ice
2 12" JL audio subs
Viper class d mono 600 watt amp
Alpine 75X4 4 channel amp
Alpine 4s in the front
crappy pioneer head unit I need to replace
Wheels & tires
American Racing 15X8 Ar-23 wheels
Bf goodrich 35x12.50 R15 All terrain TA
spare is a used 32x11.50 Bf good rich All terain mounted on 15x8 black rock crawler wheel
misc
clear turn sgnals and parking lights
yakima roof rack
hella 500 driving lights
Optima Yellow top
PHP: 7.4.33 Page Time: 1.227s Queries: 16 (0.007s) Memory: 0.6499 MB (Peak: 0.7774 MB) Data Comp: Off Server Time: 2026-07-16 12:41:57 UTC
