Tacoma coilovers, or coil springs?? #718149 04/23/06 01:49 AM
Would these coilovers work better then then just getting some 4" coil springs for my truck, theres a 3 inch lift in the rear, and was wondering if 4" coil springs would be better then these coilovers....please let me know!!
Coilovers:
http://cgi.ebay.com/ebaymotors/Taco...585QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Coil springs:
http://cgi.ebay.com/ebaymotors/ws/e...p;amp;sspagename=ADME%3AL%3AAAQ%3AUS%3A1
(I won these already)
Re: Tacoma coilovers, or coil springs?? #718150 04/23/06 01:52 AM
Or should I get both???!!!
Re: Tacoma coilovers, or coil springs?? #718151 04/25/06 04:39 AM
Jeff the marmot Offline
Refer to this old post about alternatives to SAW coil-overs:
www.4x4wire.com/forums/showflat.php?Board=UBB13&Number=389145
There's a ton of info in that thread about those coil-overs that you're considering buying.
Don't buy the separate Doetsch-Tech coils. You first need an adjustable coil-over-shock assembly anyway, which would come with springs that are probably better than those.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
Re: Tacoma coilovers, or coil springs?? [Re: Jeff the marmot] #718152 04/28/06 04:49 AM
so would this coilover system work with the springs
http://cgi.ebay.com/ebaymotors/ws/e...sspagename=STRK%3AMEWA%3AIT&rd=1
idk, Im so confused on what to do, I just wanted to save some money and get my truck lifted, guess im not doin to good on that
Re: Tacoma coilovers, or coil springs?? #718153 04/28/06 06:09 AM
99TRD Offline
No those wouldnt work because the 05's use a different type of strut than the 98-04's...Unless you have an 05, but going off the name 99greenyota I'm assuming you have a 99 <img src="/forums/images/graemlins/lol.gif" alt="" /> Try and find a pair of used sway away, king or fabtech replacement coilovers...From my own personal experience dont try and mix and match parts because it usually ends up being way more hassle and money then if you had just bought the replacements. Here are links to different coilovers that come ready to bolt in with no modification <img src="/forums/images/graemlins/kewl.gif" alt="" />
www.swayaway.com
www.donahoeracing.com
www.allprooffroad.com
www.kingshocks.com
www.fabtechmotorsports.com
1999 Black TRD Prerunner X-Cab V6
3 Revtek Lift
32x11.50 BFG AT
8"x2.5" Sway Away remote resi. coilovers and Total Chaos upper arms sitting in the garage begging to be installed
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5986 MB (Peak: 0.6622 MB) Data Comp: Off Server Time: 2026-06-21 06:36:15 UTC
