anti-dranback filter #718680 04/24/06 07:12 PM
TATER Offline OP
My local Toy dealer is out of the old anti-drainback filters.
Does anyone have a few or an alternative filter as a replacement.
I recall someone using Mobile 1 filters and am currently using one. It has the timing chain rattling untill pressure is built up.
I used the search function and not having success with the
"past 5 years" part of the search page.
Re: anti-dranback filter [Re: TATER] #718681 04/24/06 07:23 PM
4Crawler Offline
I use the Purolator Pure One filters. They seem to retain the oil well with an internal ADB valve.
Re: anti-dranback filter [Re: 4Crawler] #718682 04/24/06 07:28 PM
TATER Offline OP
Once again, 4Crawler comes to the rescue. Thanks.
Re: anti-drainback filter [Re: TATER] #718683 04/24/06 08:51 PM
Wix also has an ADV. Found that out yesterday in the middle of an oil change when I discovered my stash of filters had run out. I wanted to get a NAPA Gold, but they were all closed.
Muffin Man
Re: anti-dranback filter [Re: TATER] #718684 04/25/06 01:21 AM
RatLabGuy Offline
Can someone please enlighten me. Are the "current" Toy dealer filters not ADB? I just go and get 2 for $11... the one they give me is for 22re, 3vze and a few other motors.
How can you tell?
Question Reality.
Re: anti-dranback filter [Re: RatLabGuy] #718685 04/25/06 01:33 AM
87Toy4x4 Offline
yes the "new" ones have antidrainback valves, along w/ almost everyother filter on the market. some just work better than others. the only difference between the old and new ones is that they arent made in japan anymore. i read that they get their filters from purolator and put toyota on them b/c if you cut them open they are pretty much identical.
Re: anti-dranback filter [Re: TATER] #718686 04/25/06 12:16 PM
foxtrapper Offline
Understand Tater that all filters will drain out through the crankshaft bearings. The anti-drainback valve just prevents them from draining out through the oil pump.
It's a common misconception that having an anti-drainback valve means the filter will hold all its oil. That's actually not the case at all.
'97 T-100 SR5
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6107 MB (Peak: 0.6885 MB) Data Comp: Off Server Time: 2026-06-22 17:10:53 UTC
