Re: Want rear suspension setup thoughts [Re: Talon84X4] #718704 04/25/06 05:08 AM
4Crawler Offline
Works fine as-is and w/o a trac-bar, I am a little concerned with axle wrap. Also, I need to tweak my shock setup to handle the extra travel as well as cut out my wheel wells, since I suspect I will be hitting pretty hard on the stuffed tire if the other side drops down.
Re: Want rear suspension setup thoughts [Re: Talon84X4] #718705 04/25/06 01:54 PM
TexJeff87 Offline
What's the angle on that? length?
how well does it work?
I read that you want the angle to be around 50-60 degrees, that 45 wasn't good
I'd say they are about 9.5" long...as for angle...prolly 45 <img src="/forums/images/graemlins/smile.gif" alt="" />
Works great.
If Mad Max had a 4runner...
Re: Want rear suspension setup thoughts [Re: TexJeff87] #718706 04/25/06 06:25 PM
Talon84X4 Offline OP
<img src="/forums/images/graemlins/lol.gif" alt="" />, i'm only going off what i read
I would think it would be a good angle, enough so that the shackle is moving in the right direction but still enough room to move back [Linked Image]
'84 PU low & slow
Central Valley Crawlers
Re: Want rear suspension setup thoughts [Re: Talon84X4] #718707 04/25/06 06:51 PM
4Crawler Offline
I used to get a pretty flat shackle angle with 7" shackle, stock hanger and 56" springs:
Flex was great, but it was a little unstable on the road. Now with a more upright shackle, it works better on the road.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6105 MB (Peak: 0.6667 MB) Data Comp: Off Server Time: 2026-06-17 12:56:25 UTC
