Daytime Running Lights on 3rd Gen #71873 06/24/03 06:54 AM
Do the 3rd Gens have daytime running lights?
If so what year did the start?
Thanks
Steve
Re: Daytime Running Lights on 3rd Gen #71874 06/24/03 01:03 PM
Jeff the marmot Offline
Yes. DRL's started in 2000.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
Re: Daytime Running Lights on 3rd Gen #71875 06/24/03 01:39 PM
On my 99, I can leave the lights on all the time and they will shut off when I turn off the engine... I guess that makes them "switchable" running lights since I can turn mine off.
Re: Daytime Running Lights on 3rd Gen #71876 06/24/03 03:46 PM
FattyCBR Offline
My 98 had/has DRLs, but it was imported from Canada and that may be why.
Milan
_ _ _ _ _ _ __ _ _ _ _ _ _
Support our troops!
'98 4R Limited
'82 Toy 4.3 TBI sold
Re: Daytime Running Lights on 3rd Gen #71877 06/26/03 05:47 AM
If you dont have DRL's or fogs you can do what I did. Wire up a fog kit to a switch on your dash and use them as your drl's. I have yet to see another vehicle set up this way on the street, and I think it looks pretty cool. The bulbs are 100 watts and are plenty bright for daytime DRL use. They can be on with no other lights and go off automatically with the key if you forget to flip the switch. See my pic.
<small>[ June 26, 2003, 12:49 AM: Message edited by: 4Runner4Christ ]</small>
Re: Daytime Running Lights on 3rd Gen #71878 07/06/03 10:02 PM
Rob_dup2 Offline
I'm not sure on when DRL's started. I have a '97 and it doesn't have them. My Dad's '00 had DRL's.
Sidenote: to disengage/disable them there is a small metal box on the drivers fender pretty close to the battery, and if the wires are unplugged the DRL's should be disabled.
Re: Daytime Running Lights on 3rd Gen #71879 07/07/03 11:49 PM
Rob I looked for the metal box to disengage the DRL's on my 01 runner. Could not find this box next to the battery. I do however know of a plastic DRL switch/box under to the right of the steering column. Does anybody know if unplugged this will disable them?
I dont use PIAA lights anymore becasue the DRL wore them out too quickly to run them. Got way too expensive. I would like to use them again.
Thanks guys, I apreciate the help <img border="0" title="" alt="[Cool]" src="images/icons/cool.gif" />
Re: Daytime Running Lights on 3rd Gen #71880 07/08/03 12:23 AM
My dad has DRL's on his 2000 and he has told me if you start the car with the emergency break up then it will disengage them. I have not tested it out but he swore it works.
Re: Daytime Running Lights on 3rd Gen #71881 07/08/03 12:31 AM
Bighead Offline
The e-brake thing doesn't work on my '01. This has a copy of the Toyota TSB about disabling the daytime running lights.
Lance
2001 Toyota 4Runner 4WD Limited | 4.88s/Dual ARBs | OME/Tundra Suspension | Aisin Manual Hubs | BFG A/T 285/75 | TJM T-15 w/ M8000 | Nuke Discos | Slee Sliders | Rockware Rear Bumper/Tire Carrier
Re: Daytime Running Lights on 3rd Gen #71882 07/08/03 12:50 AM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Paul:
<strong>My dad has DRL's on his 2000 and he has told me if you start the car with the emergency break up then it will disengage them. I have not tested it out but he swore it works.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">I agree with you dad. I have a 2000. It does the same thing. When you start the engine, it will check the brake to see whether it's on or off. If on, the light will not be turned on. If off, the light will be turned on, (and would not turn off if you pull up the brake after starting the engine).
PHP: 7.4.33 Page Time: 0.017s Queries: 15 (0.013s) Memory: 0.6256 MB (Peak: 0.7299 MB) Data Comp: Off Server Time: 2026-11-18 17:43:58 UTC
