Does anything look odd to you guys in this pic? #719188 04/27/06 02:49 AM
8
84YOTA Offline OP
Just curious if you see anything odd about this front end?
besides no steering just refering to the set up [Linked Image]
84 toyota std cab with stuff on it
Re: Does anything look odd to you guys in this pic? [Re: 84YOTA] #719189 04/27/06 03:06 AM
ummm, the tranny is too low <img src="/forums/images/graemlins/cyclops.gif" alt="" />
It would be better if the spring hanger cross brace made contact with the frame cross member all the way across, that way you could weld them together.
Re: Does anything look odd to you guys in this pic? #719190 04/27/06 03:32 AM
CraShYota Offline
uh... that hanger doesnt contact because of the way the frame is. its just like that. you just fill the gap with weld. Dont post when u dont know what ur talken about.
Welding and Fabrication Engineer
2003 taco V6 ext cab sr5
1988 Toyota Pickup V6(totaled)
Re: Does anything look odd to you guys in this pic? [Re: CraShYota] #719191 04/27/06 03:36 AM
Dude, no reason to have an attitude, this isn't Pirate. That gap looks like it's a good 5/8" thats more than I have ever seen on a front hanger. Maybe it's just the way the pics is.
Re: Does anything look odd to you guys in this pic? #719192 04/27/06 04:17 AM
Brian894X4 Offline
I don't think it's 5/8th, but it looks normal. What we did was fill the gap with pieces of scrap metal then weld to make contact. And by the way, I agree, this isn't "that other board". We're all usually pretty friendly and patient...as long as it's not a Presidental election year. <img src="/forums/images/graemlins/smile.gif" alt="" />
84Yota: Are you referring to the front traction bar bracket thingie?
post [Re: Brian894X4] #719193 04/27/06 04:31 AM
8
84YOTA Offline OP
it just seems when moving the axle 2" forward it pitched my 3rd member down a lil bit
Re: post [Re: 84YOTA] #719194 04/27/06 05:25 AM
Toybluggie Offline
Thats why many who put rears up front also drop the front spring hangers, more lift and a better pinion angle.
JT
84 22re pickup
Re: post [Re: 84YOTA] #719195 04/27/06 05:50 AM
bkg Offline
Totally normal. The springs have the pin slightly forward of your stockers, which means they mount the axle to a different spot on the arc.
Brian K. Gallus
Re: Does anything look odd to you guys in this pic? [Re: 84YOTA] #719196 04/27/06 05:56 AM
missouriman Offline
pinon angle is hard to see in that picture. if it is to much you may want to get 4 crawlers degree shims or drop that front cross member.. or it will not steer right.
what springs are you running?
Re: Does anything look odd to you guys in this pic? [Re: missouriman] #719197 04/27/06 06:50 AM
8
84YOTA Offline OP
running allpros in front
angled shims would seem better to me
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6343 MB (Peak: 0.7570 MB) Data Comp: Off Server Time: 2026-06-06 10:20:54 UTC
