general operational question... idle, mpg, TPS #719394 04/28/06 02:53 AM
Scotty_Gotti Offline OP
Hi, I have an 87 4runner EFI I have had some problems with it running rich. I changed the plugs, wires, cap rotor, O2 sensor, and had the timing corrected. I have noticed that my idle is somewhat inconsistant. It will idle high upon startup which I assume is normal but then once it warms up it will idle anywhere between 600rpms to 900rpms is this normal? I was also wondering what sorts of mpg I should expect for city driving? If my problem is TPS related how difficult are these to replace out?
Thanks!
Re: general operational question... idle, mpg, TPS [Re: Scotty_Gotti] #719395 04/28/06 03:47 AM
Your TPS may just need to be adjusted. Check the FSM stickied at the top of this section for info on how to check your TPS.
Mike in AR
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5847 MB (Peak: 0.6342 MB) Data Comp: Off Server Time: 2026-06-14 02:57:35 UTC
