TJ (and other?) rattle fix. #719771 04/30/06 12:42 AM
no_hank Offline OP
For the past several months I've had a rattle from behind the dash whenever the engine was idling. It drove me nuts for a while, zip tying things under the dash, banging on the dash and glovebox, etc... I opened the glovebox at a stoplight yesterday, and having forgotten to attach the strap that keeps it from falling out, it fell out. In the midst of trying to get everything back together, I found the rattle, the fuses. The plastic housings on several of the fuses had vibrated loose from their internals, and the amount of vibration at idle was just enough to set them off into a chatter that would make the pope spew profanities.
The fix, get new fuses, or start wedging toothpicks into the gaps and break the tip off (was done in the parking lot closest to the light I found the rattle at).
The doctors said I can stop taking the nerve meds now that the rattle is gone. <img src="/forums/images/graemlins/zombie.gif" alt="" />
97 TJ Sahara 4.0, K&N FIPK, 2.5" rancho, 31x10.5 BFG, black rims, tuffy stuff, hi-lift, AA SYE+tom woods CV rear, tera adj. upper rears, centerforce dual-friction, MSD coil/8.5mm, borla cat-back, warn steering skid, slotted rotors+high perf pads.
Re: TJ (and other?) rattle fix. [Re: no_hank] #719772 04/30/06 04:11 PM
Are you shure the rattle is gone?????? <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: TJ (and other?) rattle fix. #719773 05/02/06 12:11 AM
no_hank Offline OP
Well, sometimes, I still hear it when I sleep... <img src="/forums/images/graemlins/barf.gif" alt="" />
Re: TJ (and other?) rattle fix. [Re: no_hank] #719774 05/02/06 02:40 AM
My jeep rattles and creak so much that I just put a louder stereo in it...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5923 MB (Peak: 0.6518 MB) Data Comp: Off Server Time: 2026-06-13 13:38:32 UTC
