Re: timing? or TPS or...? 87 4runner 22re #720390 05/06/06 03:40 AM
rednekbean Offline
no the thermostat is simply what controls the flow of coolant. when the coolant reaches a specific temprature( most standard t-stats are at 195) the bi-metalic properties cause the spring/plunger to "open". the temp gauge on the 22re i belive is that little sensor between cylinder #2 and #3 on the intake manifold, and there is another one that sits horizontaly pointing towards the radiator on the front of the intake manifold. that one is part of the colds start circuit. right there next to that is were the cold start injector is located, almost like a 5th injector, it can be identified because there should be a line of some sort that runs from that to the fuel reail i belive.
at any rate if your motor runs in its normal range on the temp gauge and you dont have to crank and really nurse it along to get it started when it is cold and usually cold only, that should be of no worry to you.
you should be able cheak the injectors for a resitance value, just like your TPS and AFM, but im not entirely sure. i have access to an osciliscope so i can run a little more in depth diagnostics than just a resistance value.
i just got rid of the stumble in mine today. i put the exhaust on and now some times it will studder at worst but the baby revs pretty damn quick now, only it seems like the exhaust is still running hot. dotn know yet havent driven at night to be able to see.
cinco de mio dinner time
later
nick
92' Pick-up, SAS, gears to make her crawl, 37's , bullet proof motor, and alot of time invested.
06 CRF450R one mean roost flinging machine
Re: timing? or TPS or...? 87 4runner 22re [Re: rednekbean] #720391 05/06/06 01:15 PM
well i can use an oscope, and I can generally work on just about any eletronics, but when it comes to this moter, I need pictures. Im not the brightest but it sounds alot like the temp sensor. anyone have a pic of the temp sensor? and how its wired up, vaccumes and so on. these hanes manuals arent very helpfull.
Re: timing? or TPS or...? 87 4runner 22re #720392 05/06/06 02:03 PM
4Crawler Offline
The FSMs have the temp sender testing procedures. They are typically either a resistance that varies with temperature or they are a contact that is closed (or open) below a certain temperature and open (or close) above that temperature. They will either have one terminal (with the case grounded) or they will have two floating terminals where the resistance is measured. I have a picture showing how to test one (not a Toyota engine) on my web page:
http://www.4crawler.com/Diesel/CheapTricks/GlowPlugs.shtml#TemperatureSensor
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6005 MB (Peak: 0.6545 MB) Data Comp: Off Server Time: 2026-06-17 13:02:25 UTC
