Tranny no go reversey #721042 05/04/06 11:18 PM
Myota Offline OP
Picked up a used R151 last week. After taking the case apart, verifying that all gears work and some mild cleaning, I reassemble. I swear I verified that I could shift into all 5 gears plus reverse once it was all back together and on the bench.
Now that I have in the truck, it will not shift into reverse. All other gears are fine.
Any thoughts before I pull it back out?
-Chris
'88 EFI Xtracab, 32 x 11.50 Buckshots, AZ bed, Turbo drivetrain.
Re: Tranny no go reversey [Re: Myota] #721043 05/05/06 04:57 PM
Myota Offline OP
No thoughts?
Re: Tranny no go reversey [Re: Myota] #721044 05/05/06 09:37 PM
LUV24BY Offline
Isn't there a specific plug on the driverside of the manual trannies that are a direct relation to the reverse gear? I know it looks like a drain plug however it isn't (this could be on the W56 models) and if taken off thinkin' it was the drain plug now there is no reversey! Just a thought.
John
This is my first time here, be gentle......
.....But play DIRTY!
1985 Toyota 4Runner
http://www.cardomain.com/ride/2066809 Check this if you want to see her!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5895 MB (Peak: 0.6424 MB) Data Comp: Off Server Time: 2026-06-05 20:50:25 UTC
