help identify AC component #721765 05/08/06 03:03 AM
tim_s Offline OP
Howdy. I've got an AC leak and I've got dye on a component indicating where the leak is. Problem is, I don't know what it is, whether it's part of the AC line it's connected to, etc.. It's the rectangular piece that is on the AC line, and is between the front grill and radiator (or condenser) next to the canister with the sight glass. I have the OEM factory manual, but it doesn't help.
Clues???
Also, if anyone knows something about replacing it, please let me know.
thanks [img]http://pg.photos.yahoo.com/ph/cyndyschaefer/album?.dir=a59escd&.src=ph&store=&prodid=&.done=http%3a//pg.photos.yahoo.com/ph/cyndyschaefer/my_photos[/img]
Re: help identify AC component [Re: tim_s] #721766 05/08/06 03:26 AM
H2O_MAN Offline
I'm not sure what it is, but I think I have a new one.
Look at the end of the line sticking out of the box...
What vehicle do you own?
Re: help identify AC component [Re: H2O_MAN] #721767 05/08/06 03:51 AM
tim_s Offline OP
oops... it's a '98 T100. The component in your picture doesn't look quite like the one I have that is leaking, but then I haven't seen it from any angle other than from above. Still, the one in your picture appears smaller....
Re: help identify AC component [Re: tim_s] #721768 05/08/06 02:45 PM
Squeezer99 Offline
its on a low pressure line. take off the grill and take it out. there's going to be an o-ring in there and it has failed.
Re: help identify AC component [Re: Squeezer99] #721769 05/08/06 10:29 PM
ErikB Offline
Toyota Moderator
The blocks on the ends of the lines are just the type of fittings they use. As was mentioned, they use o-ring seals (which can be seen in the pic that H20man posted). The line itself could be bad, but more likely its the o-ring.
http://home.4x4wire.com/erik
Re: help identify AC component [Re: ErikB] #721770 05/09/06 04:43 AM
tim_s Offline OP
Thanks all. I got the grill off, cleaned the area and drove around to check for the leak. It does look like the o-ring is the problem. I guess the dealer is the only place to go to get the correct o-ring. I've not had luck before going to the auto parts store for such parts before.
Re: help identify AC component [Re: tim_s] #721771 05/09/06 03:14 PM
ErikB Offline
Toyota Moderator
I haven't had any problems getting my local NAPA to find me matching o-rings when I bring them in. A/C shops will have them too. But the dealer will work...
Re: help identify AC component [Re: ErikB] #721772 05/10/06 03:18 PM
garym Offline
When you replace an "O" ring in an AC system, do you coat it with silicone lube or anything or just put it in dry?
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: help identify AC component [Re: garym] #721773 05/10/06 04:59 PM
Squeezer99 Offline
put it in dry
Re: help identify AC component [Re: garym] #721774 05/10/06 08:38 PM
you should lube it up with compressor oil, or whatever type of oil is used in your a/c system.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6335 MB (Peak: 0.7404 MB) Data Comp: Off Server Time: 2026-06-16 02:11:50 UTC
