Ok, so I've been reading this forum avidly ever since I acquired my 1990 22RE pickup a couple of months ago. Usually by searching past threads I've been able to find pretty much everything I needed to know, but the time has come to ask a question.
I'll start with a long winded description of the specifics of my problem - my questions are at the end.
I started having starting issues a couple weeks back. The dreaded click. Since I couldn't make it reproduce reliably (it always happened at the worst times, of course) and I lacked a voltmeter (at the time) I decided to go for broke and replace the starter contacts (thanks 4Crawler!) without checking any of the electricals upstream. That seemed to fix the problem for a couple of weeks.
Yesterday, I stopped for gas. Attempting to restart the truck, I heard to starter relay clicking repeatedly for several seconds. Finally the starter turned weakly, the engine caught and I drove 120 miles home (at night w/lights, stereo, the works) without any more problems.
Today, same situation starting in the morning. In the afternoon, I couldn't get it to start period. Luckily, a friend was nearby, and we jumped my truck. Started right up, no clicking. I drove 20 mins home, again no issues. Turned off the truck at home, and immediately tried to restart it. Nothing but a few clicks.
Took the battery in to get it checked - the battery is fine. The nice people at the auto shop even charged it for me. Now my truck starts great, every time.
My diagnosis:
I'm pretty new to electricals, but it sure seems obvious that the battery isn't getting charged, which would point to the alternator. However, I read in a past thread that if the alternator wasn't doing its job, disconnecting the negative terminal of the battery while the truck was running would kill the engine, which it doesn't. Also, my crappy analog voltmeter shows 14v, steady, at the battery terminals with the truck running, which seems right.
My questions:
From my understanding of the charging system, it seems like if the alternator had failed, I wouldn't be able to drive 120 miles without having some serious issues. As it is, once the engine is running everything is fine - no rough running, no idiot lights, nothing.
-What else could be causing the battery not to charge?
-I've read that corroded ground straps can cause all sorts of issues, but how does one check for corrosion, short of cutting the ground strap open?
-Is there anyway of testing the alternator reliably while it's on the vehicle with just a crappy analog voltmeter? The FSM shows a complex setup with an Ammeter and a voltmeter. I just have an analog voltmeter and as far as I can tell it's precision is at best +/- 1 volt.
-How do I know if I have an internally or externally regulated alternator?
-Is there something else that I'm missing here???
Any insights/tips/solutions on troubleshooting alternator and starting issues would be greatly appreciated!
Thanks,
Matt
