sway bar links #722269 05/09/06 10:13 PM
kingfoss Offline OP
how do you remove the stock swaybar links on the front of a 2000 jeep wrangler
2000 TJ 5" lift
33" BFG AT
Rear 4-link coming soon
Front hp dana 44 and frod 9" Rear coming sonn
Re: sway bar links [Re: kingfoss] #722270 05/10/06 03:26 AM
I remember there being a lower torx bolt and an upper eye???
My brother has an 06. When he gets here, if no one else has chimmed in, I'll go take a gander.
Re: sway bar links #722271 05/10/06 05:16 PM
kingfoss Offline OP
yeah i got the lower torx bolt out and i got the nut off the top but i can not get the link out of the sway bar and was just wondering if there was somthhing that i was missing. i messed up the threads using the bfh method.
2000 TJ 5" lift
33" BFG AT
Re: sway bar links [Re: kingfoss] #722272 05/10/06 05:56 PM
Well, if it is anything like the YJ...
Try the bfh on the sway bar. The links are sort of pressed in...sometimes you can tap them out by vibrating the bar enough.
Second option...go get a fork. Forget the technical name:
U
You hammer it in between the joint and the thing it goes into. There is more than just the sway bar put in this way.
Third option, just remove the sway bar entirely...that is what I did and it hasn't made enough difference in drivability for me to worry about. I pulled the links off where they attached to the axles and threaded the whole assembly out of the vehicle. Be careful the first drive and don't go far...just test. If you don't notice a diff then what's the diff? All that thing does is keep your body from leaning too far, and if that doesn't happen you don't really need the thing; just keep to decent speeds.
Re: sway bar links #722273 05/10/06 06:11 PM
tcoff Offline
I just did the same job. I took the sway bar off first, then hit it with a bfh. the sway bar is easy to get out takes only a few minutes.
99 wrangler sport, auto. 2.5 inch lift, 31 MTR's
Re: sway bar links #722274 05/10/06 07:40 PM
zxkevinxz Offline
Pickle Fork i think.
i don't like the idea of removing a sway bar completely unless i was going trailer my jeep. the difference is going to show when you get hit on the highway by some idiot during the rain, you spin, hit the curb, and go over. i like the bfh method. you know what's cool? i read that the 07 rubicons are going to have electronic sway bar disconnect. <img src="/forums/images/graemlins/kewl.gif" alt="" />
"Not all who wander are lost"
86 CJ7; 258,MC2100,30/300/44,2.5" susp. lift,31s
Re: sway bar links [Re: zxkevinxz] #722275 05/10/06 10:26 PM
kingfoss Offline OP
thx for the help i will try the pickle fork and if that does not work i will take off the swaybar and use a really bfh
2000 TJ 5" lift
33" BFG AT
Re: sway bar links [Re: kingfoss] #722276 05/10/06 11:08 PM
kingfoss Offline OP
the pickle fork worked
Thx again
2000 TJ 5" lift
33" BFG AT
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6149 MB (Peak: 0.6967 MB) Data Comp: Off Server Time: 2026-11-15 06:09:34 UTC
