Re: How does everyone like their locker? [Re: fred1980] #722500 05/17/06 06:20 AM
I have 33's and a lock right and I beat the crap out of my jeep....
Re: How does everyone like their locker? [Re: fred1980] #722501 05/17/06 02:03 PM
BigJim Offline
Fred they do not disengage when shifting gears.. I betcha what you are describing is the TURNING of the wheels.
When behind another vehicle and turning left to pass under power the locked wheels do not want to go left. As one will have to go faster than the other.. I betcha that is what you felt.
The only time the locked wheels unlock is when coasting and turning. At that time the locker allows the wheels to turn at different speeds.. BUT when power is applied both wheels MUST turn at the same speed.
Re: How does everyone like their locker? [Re: zxkevinxz] #722502 05/17/06 05:31 PM
Paddler Offline
the last of my lift got shipped monday. <img src="/forums/images/graemlins/smile.gif" alt="" /> once installed it's on to tires. then locker for the rear only. i am wondering about your locker and what you like and don't like about it, issues, install, anything to help me make a decision on which one to order. <img src="/forums/images/graemlins/cheers.gif" alt="" />
What I like about it?
It's stock and it's selectable. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
What I don't like about it? That you can only engage it if you're in 4Low. (Haven't had the time to complete the bypass yet)
All kidding aside, having had a non-selectable and now having a selectable, i will never go back to a non-selectable.......definitely not in the frontend, down right dangerous.
1995 Honda Passport;
Some people wait a life time for their ship to sail in, while others simple grab the oars and begin paddling
Yours truely
http://www.zutah.com
Re: How does everyone like their locker? [Re: BigJim] #722503 05/17/06 07:45 PM
JeePete Offline
BigJim, what he is describing is what I was talking about. Pardon me while I quote myself.
what happens is, as you shift gears the cross shaft in the diff goes slack, and as power is applied in the next gear one rear wheel is driven before the other. this causes a slight pull to one side or the other until both wheels are being driven.
Re: How does everyone like their locker? [Re: BigJim] #722504 05/17/06 07:58 PM
fred1980 Offline
That might be it, but I was under the impression that these lunchbox type lockers disengage when they have no power going to them (letting off the gas) and engaging once power is given, thus allowing the vehicle to go around a corner without chirping the inside tire when you let off the gas and then engageing once you get on the gas when your going strait. So when you depress the clutch to shift it disengages the power from the drivetrain to the locker and when you shift and let go of the clutch the power goes back to the locker engaging it once more. This does not happen with my ZJ because I has a auto but with the manual tranny on the Rodeo it happens, I think it is the sudden imput of power to the locker at a high rate of speed that's causeing the veering effects in my particular case. But then again I could be wrong and it just be some particular handleing characteristic on the Rodeo.
Fred R.
97 ZJ, 5" Long Arm Lift, Beadlocked 35's, 231/D300 Doubler, Locked Front & Rear (Narrowed HP D44 & F8.8), ARB Bull Bar & 9K winch, 1-Ton Hydro-assist steering, "Custom" body work and some other goodies... PICS
Re: How does everyone like their locker? [Re: JeePete] #722505 05/17/06 10:12 PM
BigJim Offline
Pete if that were true then OPEN diffs would react as you describe!
Re: How does everyone like their locker? [Re: fred1980] #722506 05/18/06 02:32 AM
john_luttrell Offline
I have run a powertrax no-slip in my tacoma with 33's for three years now and haven't broken any parts so far. I'd put one in my YJ, but I'm afraid it would be risky with my wife or daughter driving it on the highway.
John Luttrell
2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
Re: How does everyone like their locker? [Re: BigJim] #722507 05/18/06 02:51 AM
It does what fred describes. The hole for the cross shaft is an oval for a lunch box, not a perfect circle like a spider gear. The driving force is what locks them, hard. There is only enough slack for one side to pop out at a time, so when the torque is minimal one side usually disengages unless there is no difference in tire run out.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6255 MB (Peak: 0.7265 MB) Data Comp: Off Server Time: 2026-10-21 17:14:06 UTC
