wheels #723101 05/13/06 03:03 AM
mike3318 Offline OP
I am looking for a set of used aluminum rims for my 94 Toyota P/U 4x4. I have the stock steel wheels (15x7 û six lug) that have some surface rust on them. Since I am due for some new tires, I figured this would be the perfect time to replace the rims too. Can anyone tell me the size of the bolt pattern or what other make of vehicles I can look at that will fit?
Re: wheels [Re: mike3318] #723102 05/13/06 05:23 AM
OOP'S Offline
The lug pattern is 6 x 5.5. Most of the aftermarket wheels with that lug pattern will fit. Some of the early wheels the center hole is to small. Chevy Pickups, GMC pickups, Nissan Pickups all have the same lug pattern. I know there are more but I cannot which ones right now.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: wheels [Re: OOP'S] #723103 05/13/06 01:43 PM
I went with the 3.75 inch back spacing. they stick out a little but I have flares so it looks great. let me know if you want pix <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: wheels [Re: mike3318] #723104 05/13/06 04:41 PM
trythis Offline
I know that the isuzu trooper stock 15 inch wheels fit, they have the same 15XJJ (not sure if that is the actual code) stamped into the rims, I am using one for my spare, I checked for fit, and it works. You need to measure the center hole on the rim, because not all 6 lug wheels have the same inside hole diameter.
Re: wheels [Re: trythis] #723105 05/13/06 04:44 PM
Scerb Offline
Mitsubishi Montero rims fit as well.
-Scerb
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6030 MB (Peak: 0.6633 MB) Data Comp: Off Server Time: 2026-06-23 01:14:00 UTC
