somethings going out #723308 05/14/06 04:14 AM
blue97sr5 Offline OP
its either my starter or my nuetral safety switch. i push the clutch in and it trys to start(like it turns over once or twice and stops), or it clicks. then i try it again and fires up.
now the real problem it doesn't do it all the time, so i can't diagnos it <img src="/forums/images/graemlins/angry.gif" alt="" />
97 sr5 tacoma: TRD air filter, bilstien shocks, and a crazy sound system
mods soon to come
B&M short throw
TRD headers
MagnaFlow catback
Re: somethings going out [Re: blue97sr5] #723309 05/14/06 04:30 AM
kewlynx Offline
Give this a read; also make sure your battery cables are clean and have good connectivity.
We also have an FSM sticky'd here if you need schematics. <img src="/forums/images/graemlins/notooth.gif" alt="" />
**ubi apis- ibi salus**
Re: somethings going out [Re: blue97sr5] #723310 05/15/06 06:27 PM
ACES_HI Offline
Sounds like a bad starter. It will be intermittent and if you cant get it to turn over try hitting the starter with a bfh (gently) and it should start. In the meantime replace the contacts.
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: somethings going out [Re: ACES_HI] #723311 05/16/06 04:13 AM
DentedTacoma Offline
Is it a manual? That samish thing happened to me about a month ago but then I noticed that the clutch switch was going out on the floor and the clutch start cancel solved that. Might have nothing to do with it though...
98' Toyota Tacoma SR5
Manual Xtra Cab, Slight Lift
Maine Rules!
Re: somethings going out [Re: DentedTacoma] #723312 05/16/06 08:45 PM
yeah its a manual
it starts everytime with the clutch start cancel
mods soon to come
B&M short throw
TRD headers
MagnaFlow catback
Re: somethings going out [Re: blue97sr5] #723313 05/17/06 02:23 AM
kewlynx Offline
Make sure the plunger for the clutch switch is properly adjusted, and that your clutch bracket isn't cracked, esp if it makes noise when you work the pedal.
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.011s) Memory: 0.6098 MB (Peak: 0.6793 MB) Data Comp: Off Server Time: 2026-11-14 23:03:04 UTC
