Transfer Case Removal
#723535
05/15/06 04:51 AM
Still haven't figured out how to get the search on this forum to return pertinant results...any tips or tricks to what I might be doing wrong?
Anyways, Tuesday I am going to be pulling my stock transfer case and swapping in a Marling 4.7:1 case. In the factory service manual and the Hayes manual they both say to completely pull the transmission and t-case out at the same time. I am thinking that this is probably like alot of the instructions and makes for more work than needed.
First Question: Can I support the tranny and just pull out the transfer case and swap in the new one?
Second Question: Is there any particular oil I should use (synthetic/regular) in the 75w90 weight?
Thank you very much!! I cant wait to try out the lower crawl ratio.
~Eric
Re: Transfer Case Removal
[Re: CheviHemi]
#723536
05/15/06 05:13 AM
1. Yes
2. I have been running 75/90 Dino for seven years with no problems!!!
"Serenity through Sobriety"
[Re: OOP'S]
#723537
05/15/06 06:17 AM
[Re: CheviHemi]
#723538
05/15/06 06:30 AM
Prop up the tranny and pull the crossmember, drive shafts, and the speedo cable. Get a few cardboard boxes that fit inside each other and you can just help it down onto them if you're working by yourself (I always seem to be.....). If you have a helper the tcase should be easy to manage.
Jerod
89 4Runner, 282k miles. "I gotta have more cow bell"
[Re: 2ndGenToyotaFan]
#723539
05/15/06 11:50 AM
use a ratchet strap under the transmission. pull your fill plugs before you pull the drain plugs. next bring your old transfercase to the dakota territory challenge and give it to me.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6024 MB (Peak: 0.6672 MB) Data Comp: Off Server Time: 2026-06-10 13:36:56 UTCValid HTML 5 and Valid CSS
