Page 2 of 3 1 2 3
Re: I need to be CHILLIN'!! A/C Compressor buying ??'s [Re: CJM] #723613 05/16/06 12:47 AM
LUV24BY Offline OP
Sent ya a PM my main man!
John
This is my first time here, be gentle......
.....But play DIRTY!
1985 Toyota 4Runner
http://www.cardomain.com/ride/2066809 Check this if you want to see her!
Re: I need to be CHILLIN'!! A/C Compressor buying ??'s [Re: LUV24BY] #723614 05/16/06 02:04 AM
Kona Offline
Your going to have a problem using the 89-95 evap on your truck and there may be something odd about mounting the drier but everything else should work. I went the other way round and if I still had the '87 evap that I couldn't use in my truck it would already be yours.
Back in the West!
Re: I need to be CHILLIN'!! A/C Compressor buying ??'s [Re: Dandeman] #723615 05/16/06 02:46 AM
yodta Offline
You ought to at least check the price at a Toyota dealer...
The expensive parts like starters, alternators, A/C compressors are available as remanufacturered parts through the dealer and with a Toyota warranty..
I've always found the prices pretty reasonable on Toyota remanufactured parts, much less than a new factory Toyota replacement part.
I've not sure if the same suppliers or reman parts are available through all Toyota dealers in the US since the US is broken up into different distributor regions/dealership..
I'm speaking of a dealer in the SouthEast Toyota distributor region above..
wow, I didn't you know you could buy remanned Toyota stuff from the dealer.
msg - '87 xtracab
Re: I need to be CHILLIN'!! A/C Compressor buying ??'s [Re: yodta] #723616 05/16/06 01:14 PM
Dok Offline
Definitely check ebay, I just picked up a remanned compressor for $120. AC Kits.com is also great, I've ordered from them in the past and will be again this time around. Also, check out their forum, very helpful if you've got any questions!
'87 4-Runner--DD/wheeler, 4.3 swap coming soon
'89 Supra--E85 powered 2jz NA-T Swap, 533rwhp 497ft-lbs
'89 Festiva, turboed BP swap powered by megasquirt
Re: I need to be CHILLIN'!! A/C Compressor buying ??'s [Re: LUV24BY] #723617 05/16/06 03:48 PM
Vonka Offline
88 4x4 22re
86 2wd 1-ton 22re
91 2wd 22re
Re: I need to be CHILLIN'!! A/C Compressor buying ??'s [Re: Kona] #723618 05/16/06 03:58 PM
LUV24BY Offline OP
Thanks for the info Kona! I need to get as much information as I can prior to doing this. I think CJM's deal would be best as it's an almost complete system and about the cost of just the compressor down here. This way, I could also replace the worn out parts with the majority of stuff in his kit! If the dryer is from the kit why wouldn't it be good to use with the kit itself?
John
1985 Toyota 4Runner
Re: I need to be CHILLIN'!! A/C Compressor buying ??'s [Re: CJM] #723619 05/16/06 04:36 PM
Seattlegti Offline
Thought there was there was a huge Toyota wrecking yard down near Pheonix.
Re: I need to be CHILLIN'!! A/C Compressor buying ??'s [Re: Seattlegti] #723620 05/16/06 05:10 PM
Staceman Offline
There is, and their prices will scare you away so fast, it'll make you puke! <img src="/forums/images/graemlins/barf.gif" alt="" />
Re: I need to be CHILLIN'!! A/C Compressor buying ??'s [Re: LUV24BY] #723621 05/16/06 05:31 PM
azrain Offline
Give these guys a call:
Jack's Automotive Service
2623 E McDowell Rd
Phoenix, AZ 85008 - 3641
(602) 273-0717
I've used them in the past for old stuff and they were pretty reasonable.
Man, it ain't EVEN hot yet, you'll be wanting that AC before July! <img src="/forums/images/graemlins/smile.gif" alt="" />
Mike
Re: I need to be CHILLIN'!! A/C Compressor buying ??'s [Re: azrain] #723622 05/17/06 04:12 AM
LUV24BY Offline OP
Mike
THAT'S the EXACT reason I am starting this project *NOW*!! <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
John
1985 Toyota 4Runner
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6381 MB (Peak: 0.7464 MB) Data Comp: Off Server Time: 2026-06-07 06:10:59 UTC
