t100 weight #723792 05/16/06 06:24 AM
BIG-T Offline OP
i'm getting ready to do coils on my truck and I was wondering what the front of the t100 weighs, you know a v6, xcab, 4x4. i was thinking on running 185 lb coils in the front.
thnx
matt
97 T100, supercharged, 5spd,and 256k miles.......SAS Dana 44, 4:88 gears, locker, 37" MTR's............ <img src="/forums/images/graemlins/smile.gif" alt="" />
http://www.cardomain.com/memberpage/596514
Re: t100 weight [Re: BIG-T] #723793 05/18/06 03:14 AM
Jake97T Offline
that would make for a super flexy front end...for those with IFS still intact which i know yours went missing...they suggest 700-800 lb coils...however id run at least a 300lb coil with a SAS while still getting some good spring weight/flex. Find out what the new all-pro Coil-over SAS kit uses and add about 100lb to that spring rate...
Re: t100 weight [Re: Jake97T] #723794 05/22/06 03:27 AM
BIG-T Offline OP
I was thining about 185 lb coils and sway bars. Seems thats what the a lot of guys run on coiled v8 jeeps
Re: t100 weight [Re: BIG-T] #723795 05/22/06 06:32 AM
4
4xGeek Offline
Seems as though heeps are a smidge lighter... (comment said dripping in sarcasm)<img src="/forums/images/graemlins/cyclops.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
May want to think higher lbs per inch than 185.
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
PHP: 7.4.33 Page Time: 3.189s Queries: 15 (0.008s) Memory: 0.6004 MB (Peak: 0.6559 MB) Data Comp: Off Server Time: 2026-11-16 03:38:38 UTC
