lighting #724187 05/17/06 05:57 AM
justinmnhall Offline OP
It's night here so, I was wondering what would narrow down the problem before I try things in the morning.... The pass. head light is much dimmer than the drivers side. I just replaced the bulb, but still the same. Any suggestion would be great. 89 4runner
87 ex-cab 4x4 D D
89 4runner Work in progress!
Re: lighting [Re: justinmnhall] #724188 05/17/06 06:01 AM
4Crawler Offline
Probably the wiring, check the voltage at the headlight connector (with the lights on) and see if there is a difference:
- http://www.4crawler.com/4x4/CheapTricks/Headlights.shtml#TryBeforeYouBuy
Re: lighting [Re: justinmnhall] #724189 05/17/06 06:57 AM
stock87 Offline
Don't forget to check the fuses too. 1 per headlight, engine compartment fuse panel.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5933 MB (Peak: 0.6468 MB) Data Comp: Off Server Time: 2026-06-17 12:11:19 UTC
