lift kit #724521 05/22/06 05:45 AM
kingfoss Offline OP
so i just ordered a teraflex 4" kitfor my 2000 tj and it says that a sye is recomended and just wanted to know if anyone has experence with these kits. if i can still wheel it with no sye.
thx
2000 TJ 5" lift
33" BFG AT
Rear 4-link coming soon
Front hp dana 44 and frod 9" Rear coming sonn
Re: lift kit [Re: kingfoss] #724522 05/22/06 12:43 PM
cuervo25 Offline
i have no experiance with them,but from what i understand if you dont use them the driveshaft will fall out.once you lift your jeep that much the drive shaft is pulledd out of the transfer case a bit.when wheeling the travel of your rear axel can pull it out the rest of the way.
Re: lift kit [Re: kingfoss] #724523 05/22/06 01:08 PM
tcoff Offline
If it comes with a T-case drop kit you should be ok for while. That way you can still drive it while you save up for the sye.
99 wrangler sport, auto. 2.5 inch lift, 31 MTR's
Re: lift kit [Re: tcoff] #724524 05/22/06 03:38 PM
kingfoss Offline OP
thx for the info
2000 TJ 5" lift
33" BFG AT
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5981 MB (Peak: 0.6531 MB) Data Comp: Off Server Time: 2026-10-26 12:07:31 UTC
