how do i determine which rear axle I have #724709 05/22/06 06:50 PM
Looking in my Haynes, it says my 85 CJ7 most likely has an AMC/Jeep semi-floating tapered axleshaft axle assembly.
Any advice to be sure? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: how do i determine which rear axle I have #724710 05/22/06 08:16 PM
JeePete Offline
If the diff cover is round, like a perfect circle, It's an AMC 20. If there are nuts on the end of the axles, at each wheel, (under a little hub cap usually), it's an AMC 20. That's what came stock in 85 though it's not unusual for people to replace the stock axle/hub assemblies with one piece axles like most semi floating axles have, in which case there will be no nuts on the axle ends). The Key thing is the round cover. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: how do i determine which rear axle I have [Re: JeePete] #724711 05/23/06 02:09 AM
no_hank Offline
97 TJ Sahara 4.0, K&N FIPK, 2.5" rancho, 31x10.5 BFG, black rims, tuffy stuff, hi-lift, AA SYE+tom woods CV rear, tera adj. upper rears, centerforce dual-friction, MSD coil/8.5mm, borla cat-back, warn steering skid, slotted rotors+high perf pads.
PHP: 7.4.33 Page Time: 2.661s Queries: 15 (0.004s) Memory: 0.5896 MB (Peak: 0.6422 MB) Data Comp: Off Server Time: 2026-06-17 18:30:48 UTC
