simple trick when pulling birfs out and such... #724810 05/23/06 01:53 AM
ZUK Offline OP
Stace came over early this morning so that he could swap in new front wheel spacers, re-pack bearings, and Mar-tack the axles. So he discovers both of his birfs had a single crack on each so he had to use his trail spares.....now he has no spares <img src="/forums/images/graemlins/wink.gif" alt="" />
Anyways, as shown in the next 5 pics, you can see that we cut a simple slot in the dust cover brake bracket and that allowed us to place the caliper out of the way so we could assemble spindle assembly without the caliper dangling nearby. Simple and so easy to do.
While he was here, I upgraded his 12" coils to 14".....this allowed me to get rid of the spacers we welded in there for the desired lift. Looks real clean right now smile
mostly stock
Re: simple trick when pulling birfs out and such... [Re: ZUK] #724811 05/23/06 02:25 AM
OOP'S Offline
I did that when I first did my SAS. However, I found with the stock backing plates and the wider FJ rotors that small rocks would get stuck between the backing plate and the rotor. It made one heck of a noise and it grooved the rotor. I cut the center ring out of the backing plate and cut the brackets off my IFS backing plates, straightened them out, drilled a hole in them. The top caliper bolt holds them in place and no more breaking the brake line loose when I service the front end.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: simple trick when pulling birfs out and such... [Re: OOP'S] #724812 05/23/06 02:44 AM
fourwd1 Offline
That's how I did mine too. Makes front end maintainence and birf replacements much easier. Especially on the trail.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: simple trick when pulling birfs out and such... [Re: fourwd1] #724813 05/23/06 02:55 AM
4Crawler Offline
I did likewise many years ago. Had the stock brake line bracket, notched and welded it to the steering arm. That way it was both easy to remove if needed, or often you did not even have to remove it at all.
Re: simple trick when pulling birfs out and such... [Re: 4Crawler] #724814 05/23/06 02:32 PM
TexJeff87 Offline
Timing is everything. I was just about to post asking how you guys swap birf without having to bleed the friggin' brakes. I HATE bleeding brakes.... <img src="/forums/images/graemlins/zombie.gif" alt="" />
If Mad Max had a 4runner...
Re: simple trick when pulling birfs out and such... [Re: TexJeff87] #724815 05/23/06 03:00 PM
CraShYota Offline
dust shields are over rated.
Welding and Fabrication Engineer
2003 taco V6 ext cab sr5
1988 Toyota Pickup V6(totaled)
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6120 MB (Peak: 0.7001 MB) Data Comp: Off Server Time: 2026-06-06 13:16:04 UTC
