Page 2 of 7 1 2 3 4 5 6 7
Re: 4Runner Front Tube Bumper [Re: TheBandit] #724924 05/24/06 02:08 PM
OOP'S Offline
It takes quite a bit of time using a cutoff wheel! I really need to get a hole saw type notcher - these would go much faster
That bumper is looking great.
I use one of those tubing notchers from Harbor Freight in my drill press. It works pretty well. I have found that if I use a hole saw that is 1/8th inch bigger then the tube they seen to fit better with less grinding.
Keep up the good work and that bender you built blows me away!!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: 4Runner Front Tube Bumper [Re: OOP'S] #724925 05/25/06 05:36 AM
trythis Offline
Looks like a great setup you have there, I am jealous of the bender. Obviously engineering isnt a problem for you, but maybe a drawing class is in your future? <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 4Runner Front Tube Bumper [Re: trythis] #724926 05/25/06 07:08 AM
TheBandit Offline OP
Thanks guys!
I will take that drawing class ASAP.
UPDATE
It may not seem like I did much since last time, but it took me about an hour to tack these together. I'm sure more experienced folks wouldn't have taken nearly as long, but I took a ton of measurements and did a lot of creative "fixturing" using things laying around the garage to get all my angles right. I also did a little grinding here and there to get better fits on my notches. So although it doesn't look much different from where I left off yesterday, all this lower half needs now is finish welding. Here it is loosely attached to the truck (using bailing wire)
Do you think there will be enough room for a winch? I left about 8" in front of the radiator to work with.
Here is one area I would do differently a second time around. I am not happy with how much space there is between the marker light and the bend at the corner. If I moved the bend apex toward the rear of the truck this area would look much better.
It doesn't look too bad from this angle.
Here's what it will do for my approach angle. What do you think? Liveable?
33s and IFS
My next step will be making the plate for the front of the crossmember (that should be pretty quick/easy) then I will get started on the upper assembly.
WHY WAS THIS REMOVED FROM THE EARLY TOYOTA TRUCKS FORUM??? An '86 doesn't qualify as early? <img src="/forums/images/graemlins/scared.gif" alt="" />
[color:"darkgreen"]1986 4Runner - 4" IFS - 63" Chevys - 33" ATs - 5.29s - Rear Detroit
Sliders - Kayline - Rebuilt 22RE - On Board Air AND Factory AC
www.xtremefabricator.com[/color]
Re: 4Runner Front Tube Bumper [Re: TheBandit] #724927 05/25/06 07:32 AM
Robinhood150 Offline
I see allen being a fixture in a couple of you pictures.
Who's your advisor for your senior project?
Steve
My Website ||Gettin' off 4wheel drive club member
'93 4Runner V6 4x4 auto tranny
If you have to ask about a SAS, you're not ready for it.
Re: 4Runner Front Tube Bumper [Re: Robinhood150] #724928 05/25/06 08:02 AM
Yeah he was trying to show off his unhuman strength.
Jim Widmann is my SP advisor.
Re: 4Runner Front Tube Bumper [Re: TheBandit] #724929 05/25/06 03:19 PM
Jeff the marmot Offline
Looks great! Cool software.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
Re: 4Runner Front Tube Bumper [Re: TheBandit] #724930 05/26/06 12:55 AM
Dandeman Offline
Toyota Moderator
Agree... that your '86 belongs here in the Early Toyota Forum.. Sooo moved... <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 4Runner Front Tube Bumper [Re: Dandeman] #724931 05/26/06 01:51 AM
CORunner93 Offline
The trick to those outter bends near the corners is to not make them 90 degrees. I think mine are more like 75 or 80 degrees. I kind of stumbled into the right angle for mine, simply due to the fact that my bender wouldn't do a 90 degree bend without kinking the pipe. I stopped as soon as I saw it kinking (and thinking I was going to have to start over), and as luck would have it, it was a perfect fit. Once it comes around the corner near the light the outter edge cuts almost perfectly around the light and extends to the outter edge of the flared part of the fender...with about 3/4 of the pipe extending out from underneath the fender.
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
Re: 4Runner Front Tube Bumper [Re: CORunner93] #724932 05/26/06 03:12 AM
A
allochris Offline
wow, that looks good & simple!
Will you have 2 side tubes from frame to each ends of the main tube for side reinforcement?
How about cutting some 3/16" stainless plates to fill the 2 empty holes at the front (except the middle hole for winch) for increase look & air flow?
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: 4Runner Front Tube Bumper [Re: allochris] #724933 05/26/06 03:25 AM
Looking great dude. Oh and welcome back to the Early Toyota board <img src="/forums/images/graemlins/smile.gif" alt="" /> I'm looking forward to the final product <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6466 MB (Peak: 0.7570 MB) Data Comp: Off Server Time: 2026-06-07 07:16:32 UTC
