Page 5 of 7 1 2 3 4 5 6 7
Re: 4Runner Front Tube Bumper [Re: allochris] #724954 06/11/06 07:29 AM
TheBandit Offline OP
to plug up the ends of the tubing, i remember reading from somewhere that u can go get some 25cents bouncy ball from toy stores or the gum machine to plug it up temporaly.
I'm going to order 10 or 20 of these. I'm sure they will be handy for other projects also.
Name:
Ornamental End Cap
Item#:
AA-022-3C
Price/ea:
Qty 1-199 $0.49
Qty 200 Or more $0.41
1 3/4" Diameter
http://www.aa-mfg.com/pdshop/shop/item.asp?itemid=665
[color:"darkgreen"]1986 4Runner - 4" IFS - 63" Chevys - 33" ATs - 5.29s - Rear Detroit
Sliders - Kayline - Rebuilt 22RE - On Board Air AND Factory AC
www.xtremefabricator.com[/color]
Re: 4Runner Front Tube Bumper [Re: allochris] #724955 06/11/06 03:35 PM
Man that looks sexy. You gotta love that Rustoleum Hammerd paint.
Now get rid of that IFS, it's making your bumper look bad <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: 4Runner Front Tube Bumper #724956 06/13/06 01:19 AM
Thanks man.
I'll work on that whole IFS thing eventually.
Re: 4Runner Front Tube Bumper [Re: TheBandit] #724957 06/15/06 03:56 AM
I painted the front of the crossmember yesterday so it doesn't rust while the truck is sitting over summer. It is covered with 2" x 3/16 flat bar. I wasn't sure how much to weld on this. I ended up welding all the way around near the tubing to about three inches in, then added a few stitches along the length in the middle.
I also put together a second bottom half for a local guy. He wants to trade me tube work for a solid front axle. I bent/cut all the pieces and marked them for coping. Hopefully he'll be putting this half together this weekend. He wants a little different upper half with a stinger that I'll make when I get back to school in the Fall.
Re: 4Runner Front Tube Bumper [Re: TheBandit] #724958 06/15/06 02:20 PM
TexJeff87 Offline
I absolutely mean this in the best most positive way...
Makes your truck look like it's wearing a football helmet. COOL! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
I guess the one thing that hangs me up about bumpers like this is that's its WELDED on. What if you need to take it off?
If Mad Max had a 4runner...
Re: 4Runner Front Tube Bumper [Re: TexJeff87] #724959 06/19/06 09:47 PM
Thanks Tex. You aren't the first to find a resemblance to a football helmet. I think that will tone down some when more tubing is added.
There are certainly advantages to bolting things on, but this bumper will be part of an external roll cage (exo), so I think welding it on is the right way to go. If it needs to be removed, there are always cutoff wheels, sawzall blades, and torches. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 4Runner Front Tube Bumper [Re: TheBandit] #724960 06/19/06 10:23 PM
TexJeff87 Offline
huh huh... TORCHES!!!
Re: 4Runner Front Tube Bumper [Re: TexJeff87] #724961 06/20/06 04:34 PM
Red_Chili Offline
Toyota Section Staffer
You need to handle the rotational force of winching or impact or it will fold like a bad suit. Triangulate with the frame, preferably the top of the rails.
Decent effort! Lotsa work.
-Bill
Re: 4Runner Front Tube Bumper [Re: Red_Chili] #724962 06/20/06 06:13 PM
Please break out paintbrush and elaborate. I can't get a visual on what you are saying.
Re: 4Runner Front Tube Bumper #724963 06/20/06 06:19 PM
Red_Chili Offline
No can do at work. But if it is only mounted at the frame crossmember, down low, a winch will peel it right off and an impact will roll it back into your radiator, both due to leverage.
I was suggesting some upper mount, perhaps through the body to the top of the frame rails. Or, strengthening the stock upper fender mount bolts and using them, like Front Range Offroad does with their bumper.
FWIW, I did the latter, and ran 1/4" plate steel in vertical triangles from my winch mounting plate down to the crossmember, tying the whole assembly together. But there are lots of ways to do it.
-Bill
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6434 MB (Peak: 0.7479 MB) Data Comp: Off Server Time: 2026-06-10 06:28:42 UTC
