coil spring or leaf spring? #725379 05/24/06 11:09 PM
rednekbean Offline OP
so it's had come the time were i can retire the truck from DD as i have a aquired another vehicle, and i am going to start a tear down and replace/ fix all of the stuff that has been neglected, half-azzed, or were i used old junk parts to get by.
i am already going through and fixing the runabilitly problems of the truck, and have found/ fixed a bunch on just the motor alone, and i am still tinkering. it was amazing at how much was bad or out of spec and the girl still ran as she did.
any way a major part the needs to be up dated bad is the suspension. i did the SAS on her(a '92) and i am going to re-fab the ways i mounted the leaf springs. so i have come across a different i idea. i was browsing through the all-pro list and found that there SAS kit converts it to a 3-link coil in the front.
now my question is have you guys tried this suspension out and whould it be better than re-fabing the leaf mounts and going with a 6" lift. right now i run 36 swampers but am thinking about going to 38's.
note--- this will be a wheeling rig, the goal to have a rig that and wheel like mad on the trail but still be able to drive itself there and drive herself home to. i generally am the all around wheeler, mud, trails, dunes, rocks, pretty much anywere i can take the truck and not get ticketed.
nick
92' Pick-up, SAS, gears to make her crawl, 37's , bullet proof motor, and alot of time invested.
06 CRF450R one mean roost flinging machine
Re: coil spring or leaf spring? [Re: rednekbean] #725380 05/24/06 11:51 PM
DirtyHarry Offline
Toyota Moderator
I believe that the kit you saw from All-Pro is only for Tacomas, their SAS kits for earlier trucks still use leaf springs. If you are dead set on coils, Off Road Solutions has a coilover kit but it is considerably more expensive than leaves.
PHP: 7.4.33 Page Time: 6.757s Queries: 15 (0.003s) Memory: 0.5877 MB (Peak: 0.6368 MB) Data Comp: Off Server Time: 2026-06-05 23:38:12 UTC
