Rating: 5
Page 5 of 131 1 2 3 4 5 6 7 130 131
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #725631 06/11/06 02:57 AM
FrankR Offline OP
The lower intake is lightly ported to match the gasket - the new blower plenum flange runners will also be matched to the gasket:
Nothing fancy here - just die grinder work, since I would expect most gains from port matching on a forced induction engine to be recognized on the exhaust side. Whether this helps much or not is not so important to me as the thought that I've done what I believed to be the best I could with what I had to work with.... actually, quite a bit of cleanup was done here.... maybe it was even worth it. <img src="/forums/images/graemlins/wink.gif" alt="" />
Frank
Re: G-Raider 3.0L Supercharger Project [Re: LRJ4x4] #725632 06/11/06 03:06 AM
FrankR Offline OP
Have you thought about the hole your going to have to cut in the hood
Yessiree! - I've dreamed about it for several nights, now.... can't wait to get to that stage and build the hood bulge/scoop... <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
I think I'll make it angular and multi-faceted - you know like those F-117As and B-2s - very stealthy so I can't be seen on radar. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/ignore.gif" alt="" />
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #725633 06/12/06 02:16 AM
FrankR Offline OP
More lessons in why I haven't seen anyone put a Roots blower on a longitudinal 3.0L..... I'm quickly learning how to abandon plans and find alternate means to an end <img src="/forums/images/graemlins/shiner.gif" alt="" /> The fuel line layout didn't work due to interference with coolant lines, so I'm now hoping this arrangement will work:
Since the throttle body will have to move to the driver side, the coolant fittings to the throttle body are pointing in the wrong direction... I found some 180* bend hoses at a parts store... not the best solution.... but hopefully they'll work:
Here's a rough mockup of what will be the combination nose drive brace/idler pulley bracket - this piece isn't finished form - only a reference for location of the mounting holes:
It sure would be easier to walk away and say it can't be done.... but I still *think* it can be done - just a lot more work than I thought. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #725634 06/12/06 03:34 AM
LRJ4x4 Offline
If it was easy everyone would do it. Better than watching TV <img src="/forums/images/graemlins/smile.gif" alt="" />
Get the first one done then send the parts to china for reproduction....PROFIT <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: G-Raider 3.0L Supercharger Project [Re: LRJ4x4] #725635 06/19/06 01:54 AM
FrankR Offline OP
There's not a lot of room between the OE idler bracket and the alternator saddle to get the idler pulley(s) in the best location(s).... anyone think I can get away with the lower small idler so close to the belt run?... or do I run the risk of the belt rubbing at high rpms or when the blower load comes online?
I might be able to substitute a slightly smaller diameter idler between the fan pulley and the blower pulley, but it will reduce the wrap on the fan pulley a little... might be the best solution, though.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #725636 06/19/06 02:37 AM
FrankR Offline OP
Here's an alternate layout using a single idler - it's probably a better arrangement if there's enough wrap on the alternator and blower pulleys:
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #725637 06/21/06 03:07 AM
FrankR Offline OP
I think I can resolve the angle issues with the throttle body hoses and crankcase ventilation hose by using fuel hose and isolation clamps like so:
The standard hose will also be easier to find when replacement time comes around.
A mockup bracket mount was made for the coil pack, which will also serve as a stay for the oil fill neck:
Here it is assembled/mounted with standoff spacers:
The next job will be to build a jig to locate the throttle body and the air inlet pipe for fabrication.... maybe this weekend.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #725638 06/21/06 05:30 AM
sparkem Offline
When you finish, I can drive down there and put on my truck just to see if everything works. If it does work you can make another one for you. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Seriously, I want to see it in person and meet another 4x4wire member.
Re: G-Raider 3.0L Supercharger Project [Re: sparkem] #725639 06/21/06 11:24 AM
FrankR Offline OP
Sparkem, if you want to see the working model, there's no need to rush since I'm moving at a snail's pace. <img src="/forums/images/graemlins/lol.gif" alt="" /> Hopefully I'll start copying with aluminum in the next week or so.... just want to make certain everything fits ok before making expensive piles of scrap aluminum.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #725640 06/21/06 12:44 PM
FrankR Offline OP
I've been hoping I left enough room to change the thermostat without removing the blower and plenum. It can be done. I was even able to scrape off the old gasket and RTV - but it does take a while, even with the engine on a stand:
Frank
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.013s) Memory: 0.6629 MB (Peak: 0.7764 MB) Data Comp: Off Server Time: 2026-06-22 07:33:47 UTC
