Rating: 5
Page 11 of 131 1 2 9 10 11 12 13 130 131
Re: G-Raider 3.0L Supercharger Project [Re: sparkem] #725691 08/23/06 03:27 AM
FrankR Offline OP
SO did you take the hood off and drive it around the block yet?
Nope - still plenty of work left.... need to mark vacuum and boost port locations on the plenum and inlet pipe, weld some bosses at those locations so I can drill and tap for fittings, weld a rear support brace, fabricate the nose drive support, mount the fuel regulator, fabricate the intake flex hose, extend the wiring harness to the TPS and IAC, shorten the throttle and kickdown cables, send the blower back to Magnacharger for a replacement, install everything with plumbing, etc, make and install a hood scoop, paint the hood - and so forth.
Patience, grasshoppers - I only have a little time each week to work on this thing.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #725692 08/23/06 05:30 AM
Jamez Offline
So are you gonna make a custom A-Pillar pod for the boost guage?
'87 Raider w/rebuilt 2.6
Weber 32/36
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #725693 08/23/06 05:45 AM
52degrees Offline
OH, CRAP!!!! I really didn't think you'd be to this point already. I figured on at least a year before anything serious started happening. Now I have to go back and read the whole thread.
DARN YOU, FRANK!! <img src="/forums/images/graemlins/smile.gif" alt="" />
KG6VNX
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #725694 08/23/06 06:51 AM
LandRaider Offline
Frank
Frank.. dude If I was there, we'd have that thing done in a few days. PSHHHhwwwwwooooooooo
How much boost you gonna put on that poor ole 3.0? <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: G-Raider 3.0L Supercharger Project [Re: Jamez] #725695 08/23/06 01:16 PM
FrankR Offline OP
Nope:
6-8 psi should be just fine for what I want.... don't want to blow up this poor old engine. <img src="/forums/images/graemlins/wink.gif" alt="" /> Anyway, that's about the practical limit without a lot of changes to the engine and fuel system.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #725696 09/01/06 12:47 AM
FrankR Offline OP
More fun today - the details take a long time and it's sure tempting to rush things. <img src="/forums/images/graemlins/shame.gif" alt="" />
Drilled and tapped a hole for a boost port - to run the vacuum/boost gauge and fuel pressure regulator.... attached nylon tubing goes to the gauge, the open side of the tee will feed the fuel pressure regulator:
Welded/threaded ports and fittings for the brake booster and PCV valve hoses:
Rear brace welded on the inlet pipe for additional stability - intended to cover/use both holes in the OE plenum stay, but missed the down angle <img src="/forums/images/graemlins/angry.gif" alt="" /> <img src="/forums/images/graemlins/shame.gif" alt="" /> - one through-bolt should work, though - not gonna redo it:
Nice little bracket for the throttle valve cables - hopefully figured out how I can use OE transmission cable adjusters on both shortened cables:
Right rear corner of the discharge plenum milled to clear the heater hoses - still need to massage the angle of the hose connections just a wee bit more:
Drilled and tapped a hole to use a reformed bracket and wire loom at the front of the blower plenum - ok, it's mainly for looks, but it does serve to keep the wires from rubbing <img src="/forums/images/graemlins/wink.gif" alt="" />:
All in all, a good day with at least a little progress. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #725697 09/01/06 02:19 PM
dadrab Offline
Beautiful <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: G-Raider 3.0L Supercharger Project [Re: dadrab] #725698 09/01/06 05:49 PM
LRJ4x4 Offline
Frank....It's not safe to go over 125mph with your do open <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: G-Raider 3.0L Supercharger Project [Re: LRJ4x4] #725699 09/01/06 09:46 PM
8
89IsMine Offline
Ha! Good one, Les <img src="/forums/images/graemlins/kewl.gif" alt="" />
You'd better do something about the hi-speed yard cart off the starboard bow tho'. I think it's pacing Frank...
Eric W.
Re: G-Raider 3.0L Supercharger Project [Re: LRJ4x4] #725700 09/02/06 12:18 AM
FrankR Offline OP
Yeah, but notice I was only turning 5400 rpms on 9psi of boost... at 126mph, think how much more there was left at 6000 rpms.... another 14mph = 140mph top end at red line! <img src="/forums/images/graemlins/lol.gif" alt="" />
Frank
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.013s) Memory: 0.6627 MB (Peak: 0.7765 MB) Data Comp: Off Server Time: 2026-06-10 07:29:05 UTC
