Rating: 5
Page 12 of 131 1 2 10 11 12 13 14 130 131
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #725701 09/02/06 04:47 AM
sparkem Offline
Why is it like that?
Re: G-Raider 3.0L Supercharger Project [Re: sparkem] #725702 09/02/06 05:12 AM
LRJ4x4 Offline
Photoshop <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: G-Raider 3.0L Supercharger Project [Re: LRJ4x4] #725703 09/02/06 06:11 AM
sparkem Offline
Doh, you should have blurred the background
Re: G-Raider 3.0L Supercharger Project [Re: sparkem] #725704 09/02/06 06:51 AM
LRJ4x4 Offline
Re: G-Raider 3.0L Supercharger Project [Re: LRJ4x4] #725705 09/02/06 07:13 AM
sparkem Offline
Maybe we should not jumble up Frank's super charger thread. Start another post. I dont know how to do that suff or I would do it too. What about put a race track background with a couple of GT cars in front of him.
On topic, Frank, did you drive it yet?
Re: G-Raider 3.0L Supercharger Project [Re: sparkem] #725706 09/02/06 07:51 AM
LRJ4x4 Offline
Frank is a pilot, he will take off when the check list is done <img src="/forums/images/graemlins/wink.gif" alt="" /> On the right runway of course <img src="/forums/images/graemlins/wink.gif" alt="" />
Sure is getting close <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: G-Raider 3.0L Supercharger Project [Re: sparkem] #725707 09/02/06 01:14 PM
FrankR Offline OP
Not yet, Sparky.... still need to:
1) tweak (as in bend) the heater hose pipes a little more
2) make the nose drive brace/idler bracket
3) grind/drill/tap the alternator stay bracket
4) make a fuel pressure regulator mount
5) fashion a 2 piece air duct with an aluminum sleeve (in the middle) to receive the CCV hose
6) send the new injectors off for flow testing
7) shorten the throttle and kickdown cables
8) lengthen the TPS/IAC harness
9) make paper gaskets for the blower, blower plate and inlet flange
10)make an EGR block-off plate
11)drill/tap a mounting hole for the choke and capacitor that are normally mounted on the coil bracket
12)put everything together one last time
13)make a hood scoop
14)tune it
As little time as I get to work on it, it might be a couple of months before it's running.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #725708 09/05/06 12:49 PM
FrankR Offline OP
An old jack handle worked well as a sort of mandrel to gain bending leverage on the heater hose tubes:
The heater hoses no longer rub:
One small job is done and now I can final-install the lower intake and coolant hoses.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #725709 09/06/06 03:11 AM
3
3esso Offline
Good Job Frank <img src="/forums/images/graemlins/cheers.gif" alt="" /> I can't wait to see it running
keep up the good work
So when are you gonna try to do the 3.5 ?? <img src="/forums/images/graemlins/smile.gif" alt="" /> ......J/K <img src="/forums/images/graemlins/pfft.gif" alt="" />
96 NJ SWB 3.5 pajero(Bone stock)
84 NA Hi-roof Pajero(also Stock)
Re: G-Raider 3.0L Supercharger Project [Re: 3esso] #725710 09/06/06 03:50 AM
StockRaider Offline
you can already buy a bolt on for the 3.5 from Australia.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
PHP: 7.4.33 Page Time: 0.022s Queries: 16 (0.019s) Memory: 0.6545 MB (Peak: 0.7799 MB) Data Comp: Off Server Time: 2026-06-09 23:48:52 UTC
