Re: G-Raider 3.0L Supercharger Project
[Re: FrankR]
#725771
11/26/06 11:04 AM
Well that clears it all up then!
89 Raider V6 95 SR Montero
[Re: FrankR]
#725772
11/26/06 04:35 PM
FrankR is actually a real off-roader now, as he was in north Georgia last November at Beasley Mt.
Frank what did you do before your retired?
Too many 4x4's, not enough time or money
[Re: jeepdriver]
#725773
11/26/06 05:11 PM
Professional Tinkerer. <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: FrankR]
#725774
11/26/06 05:27 PM
It's a poor man's G-Wagen. <img src="/forums/images/graemlins/wink.gif" alt="" />
... Or a rich man's Raider <img src="/forums/images/graemlins/lol.gif" alt="" />
1999 Mitsu Montero - Crappy Weather 1992 Isuzu Pickup - Zombie Apocalypse 2008 Saturn Sky Redline - Nice Weather
[Re: 87Montero]
#725775
11/27/06 03:38 AM
Frank I've got a spare fuel rail from a 3.5 DOHC if you need it. I dont know of its working condition but I assume its fine - got it on Ebay for a few bucks and scored some injectors out of the deal...the guy was just parting his truck out.
concreteprinter.com
[Re: bretwalda]
#725776
11/27/06 04:16 AM
Phil, thanks. I'd need to see the fuel rail side-be-side to compare it to the 3.0L rail, so I don't know if it'll fit or not - or if it would offer any advantage. The 3.5L injectors are 240cc/min - same flow rate as I'm using now.
I took the blower and plenum back off today and found the leak - it's one of the joints where I tapped into the fuel rail. Risto (777) has had the same experience and found soldering to work..... I'll try some high silver content solder, braze all of the joints sometime this week and try again. I can't really evaluate/adjust the regulator until I get the fuel rail to hold pressure.
Frank
[Re: FrankR]
#725777
11/27/06 07:07 AM
If silver solder holds a/c pressures, it should hold yours...
[Re: FrankR]
#725778
11/27/06 03:19 PM
Frank,
Your hood's going to look killer. I can't wait to see the finished product. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: dadrab]
#725779
11/29/06 01:05 AM
Frank, you really are the DUDE. Nice work, and great documentation. Quality stuff my friend, thanks for sharing with us. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: PHIL_]
#725780
12/06/06 02:48 AM
Arrrghhh! The aggravation continues...... had the fuel rail silver soldered - looked good/strong/etc. There WAS one joint that looked suspicious......... yep, it leaked and the pump could not build pressure when the engine was cranked. <img src="/forums/images/graemlins/evil.gif" alt="" />
I've figured out how to pressure test it, though. The injectors will hold pressure if they're installed, so I'll take the fuel rail along with an old set of injectors and a spare lower intake to the shop and explain that I don't want it back until the rail holds at least 100psi. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Still looking for that pony........ <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Frank
