Rating: 5
Page 53 of 131 1 2 51 52 53 54 55 130 131
Re: G-Raider 3.0L Supercharger Project [Re: hazy_daze] #726111 12/09/07 12:47 AM
FrankR Offline OP
Well, dang
Well, if it's that important, get your pocketbook out and you can buy this one after I get it running and I'll build another one on a 3.8L block. <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
If I were you, I'd wait until you see if I can get a few thousand uneventful miles on it, though. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/ignore.gif" alt="" />
How much torque can a lockup KM148 handle, anyway?
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726112 12/09/07 03:59 AM
Once upon a time I called Mitsu customer service, and got them to connect me to some engineer there who said it was good for at least 300ftlbs. It's pretty tough.
Re: G-Raider 3.0L Supercharger Project [Re: fasteddy] #726113 12/09/07 05:16 AM
FrankR Offline OP
Thanks, Eddy -
300 ft-lbs, eh? Hmmmm.... a 3.8L with a blower would easily exceed that.... better start looking at transmissions before I do any more doodling.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726114 12/09/07 08:41 AM
52degrees Offline
4L80E. With Kevlar <img src="/forums/images/graemlins/smile.gif" alt="" />
KG6VNX
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726115 12/09/07 12:59 PM
If you go with a 3.8, just go with the big auto from the 3.5 in the SR and sports. The 5 speed auto is what I want but the control is Canbus so one needs to get around that.
The control for the 4 speed is simple to work with. It still uses a cable for throttle pressure.
Plus the super select may be wanted since you should be up in the 400'lb range. that could put a hurt on the rear tires.
Re: G-Raider 3.0L Supercharger Project [Re: OldColt] #726116 12/09/07 03:33 PM
FrankR Offline OP
Interesting, Charlie -
The next version of MS will include CANBUS architecture, along with sequential injection and multiple coil drivers. I haven't kept up with their news lately, so I don't know the availability.
Now that's what I'm talkin' about! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Today, I need to figure out some wiring issues - like how do you hook up 4 wires to a 6-pin IAC motor? <img src="/forums/images/graemlins/confused.gif" alt="" /> There are 2 center-tapped coils, so the choice would appear to be to use the ends of both coils - or - use one end and the center tap on each coil..... it does seem like the step number would be reduced, though.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726117 12/09/07 05:08 PM
The Mitsubishi applied 12v to the center wires but the GM system MS is designed after these go to ground. So you will want to ground the centers and the MS signal goes to the ends.
I have not done this yet so time needs to be spent to get the pairing correct.
Re: G-Raider 3.0L Supercharger Project [Re: OldColt] #726118 12/09/07 05:56 PM
FrankR Offline OP
Thanks, Charlie -
I'm going to dig into the wiring diagram and the MS manual in a few minutes and see what's what.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726119 12/09/07 06:16 PM
FrankR Offline OP
In looking at the MegaManual info on unipolar stepper motor coils, it would appear that I can wire both coil center taps to the ignition coil B+ and connect the 4 wires from the ECU to the coil ends as shown in the MS diagram:
pin 1 = Coil 1, lead A
pin 2 = B+
pin 3 = Coil 1, lead B
pin 4 = Coil 2, lead A
pin 5 = B+
pin 6 = Coil 2, lead B
MegaManual page
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726120 12/09/07 11:45 PM
FrankR Offline OP
Charlie -
I have a similar issue with the TPS. The TPS has 4 pins and the MS wiring diagram shows only 3 wires.... ground, Vref and TPS signal.
The Mitsu manual says pin #1 is ground and pin #4 is sensor power.
When I connect an ohmmeter to pins #1 & #3, I get the smooth increase in resistance, so I assume pin #3 is the variable TPS signal to MS.
Does this look correct?:
pin #1 = ground
pin #2 = Vref
pin #3 = TPS signal
pin #4 = 12v+ switched
Or is one pin unused?
Frank
PHP: 7.4.33 Page Time: 0.023s Queries: 15 (0.019s) Memory: 0.6569 MB (Peak: 0.7661 MB) Data Comp: Off Server Time: 2026-06-23 03:10:53 UTC
