Re: G-Raider 3.0L Supercharger Project
[Re: 87Montero]
#726101
11/29/07 01:35 PM
It's on there. It's the aluminum piece the oil filter and oil sender go on. Bottom left in the second picture.
[Re: hazy_daze]
#726102
11/29/07 03:00 PM
Yep - the cooler lines go to the oil filter adapter.
I've also installed the thermostatic valve in place of the plug. The plug had a flat washer as a seal, but that seal doesn't work with the valve.... and the parts manual does not show a seal of any kind. I hope it doesn't leak.
Frank
[Re: FrankR]
#726103
11/29/07 04:51 PM
Awesome <img src="/forums/images/graemlins/kewl.gif" alt="" /> OK, OK I'm a sad man <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: Mad_Scientist]
#726104
12/03/07 02:02 AM
Two days of heavy-duty wrenching with a few football and <img src="/forums/images/graemlins/cheers.gif" alt="" /> breaks... at a leisurely pace... and with Brendan's help got a lot accomplished this weekend. <img src="/forums/images/graemlins/kewl.gif" alt="" /> We installed the engine, exhaust, A/C compressor, P/S pump, starter, alternator, engine oil cooler lines, front prop shaft.... reworked the transmission linkage, filled the t-case, reworked the fuel rails for hopefully the last time - this time JB Weld was used as a thread sealant - don't think they'll leak now. <img src="/forums/images/graemlins/wink.gif" alt="" />... made/installed a clamp to keep the heater hoses from rubbing the back of the blower plenum.... the injectors and fuel rails are in.... finished up a couple of AN fuel fittings - the dual-feed fuel system is now complete except for the return line clamp. Brendan did a lot of the heavy work while I played foreman - he's a great helper! <img src="/forums/images/graemlins/kewl.gif" alt="" /> ![[Linked Image]](http://img206.imageshack.us/img206/1281/img4016ii6.th.jpg) ![[Linked Image]](http://img206.imageshack.us/img206/8739/img4015kv1.th.jpg) I'm sending the radiator out tomorrow to have a 3-row core put in.... still need to complete the engine sensor/ECU/ignition wiring, build an injector harness before it'll be ready... shouldn't be long now. Thanks, Brendan! <img src="/forums/images/graemlins/kewl.gif" alt="" /> Frank
[Re: FrankR]
#726105
12/03/07 05:44 AM
You're welcome! Glad to help.
PS. Steelers won 24-10
It's a good day <img src="/forums/images/graemlins/kewl.gif" alt="" />
1999 Mitsu Montero - Crappy Weather 1992 Isuzu Pickup - Zombie Apocalypse 2008 Saturn Sky Redline - Nice Weather
[Re: 87Montero]
#726106
12/07/07 06:24 PM
The injectors I chose are Denso 325cc/min - originally used on '89-'92 Ford Probe/Mazda MX-6 2.2L turbo cars. Apparently that's the only application and at first glance require a typical square L-Jetronic connector as used on the Gen1 Montero and many other applications - but the lower reference notch is offset to the side - and not the side that most similar connectors use. <img src="/forums/images/graemlins/scared.gif" alt="" /> The standard connectors can be forced on - but I guess Brendan's been hanging around me too long because he insisted that I find the correct connector. <img src="/forums/images/graemlins/wink.gif" alt="" /> Finding the connectors was tough..... 2 days of junkyard combing convinced me that there weren't any of those cars in the yards. I finally spied the correct connector on the front of a '90 Nissan 240SX engine... used as a CLT connector. Got 1 from that yard, 2 from another yard, found the same arrangement on a B-2800 truck in a 3rd yard and finally got 6 of the little buggers and made a new injector harness, wired for bank-fire - 1/3/5 and 2/4/6. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Curtis will probably approve, since the butt splices are crimped, soldered, shrink wrapped - connectors have low-profile rubber boots from a Nissan truck - harness taped, covered with split-loom and taped again - and joined with a GM weatherpak connector. <img src="/forums/images/graemlins/kewl.gif" alt="" /> I don't think weather will bother this harness, but I wouldn't want to be the one who takes it apart. <img src="/forums/images/graemlins/lol.gif" alt="" /> The search also turned up a perfectly good cover for the fusible link box - something no longer available from the dealer and very hard to find in good condition. I need to clean off the crud, though: Curtis is right about the GM weatherpak connectors.... the ones I cut from an old car had absolutely no oxidation on the wires... they were bright copper and looked almost new 2" from the connector. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Hopefully, the fuel system is now complete: ![[Linked Image]](http://img223.imageshack.us/img223/3397/img4017io5.th.jpg) ![[Linked Image]](http://img144.imageshack.us/img144/8457/img4018vw8.th.jpg) ![[Linked Image]](http://img126.imageshack.us/img126/7372/img4019wf4.th.jpg) Now, for the fun of wiring the sensors and distributor. <img src="/forums/images/graemlins/zombie.gif" alt="" /> Frank
[Re: FrankR]
#726107
12/08/07 08:15 PM
Drilled/tapped/counterbored a hole in the side of the discharge plenum for the GM IAT sensor and drilled/tapped a mounting location for the detonation sensor connector mounting bracket: ![[Linked Image]](http://img135.imageshack.us/img135/953/img4022dw3.th.jpg) ![[Linked Image]](http://img219.imageshack.us/img219/3043/img4024rx5.th.jpg) Frank
[Re: FrankR]
#726108
12/08/07 09:29 PM
All I can say is WOW, Frank. Every time you post up, it's like a work of art, and we're watching the sculptor....
That being said, when you're done, you're going to patent this and form a kit, right? <img src="/forums/images/graemlins/wink.gif" alt="" />
[Re: hazy_daze]
#726109
12/08/07 11:16 PM
Thanks, Larry -
I don't think it's possible to make a kit from this accumulation of "stuff". <img src="/forums/images/graemlins/notooth.gif" alt="" />
Frank
[Re: FrankR]
#726110
12/09/07 12:38 AM
Well, dang <img src="/forums/images/graemlins/lol.gif" alt="" />
