Rating: 5
Page 60 of 131 1 2 58 59 60 61 62 130 131
Re: G-Raider 3.0L Supercharger Project [Re: OldColt] #726181 12/14/07 11:39 PM
FrankR Offline OP
No, I don't have a scope. I do have the LEDs installed on the MS panel. I've never tried to use the timing light while rotating the engine by hand - maybe I'll try that.
I have the MS set for rising edge, since the manual said that was the best setting for most vehicles.
I'll see if I can figure out how to print the .msq file to a disk, transfer it to this desktop and post it...... give me a few minutes.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: OldColt] #726182 12/14/07 11:49 PM
FrankR Offline OP
I don't know if you look at them in this format or not.... I opened it with Notepad:
sion="1.0" encoding="ISO-8859-1"?>
<msq xmlns="http://www.msefi.com/:msq">
<bibliography author="MegaTune 2.25 p1" writeDate="2006-12-25T06:24:53-05:00" />
<versionInfo fileFormat="4.0" nPages="2" signature="MSII Rev 2.86000 " />
<page number="0" size="994">
<constant name="AFRMult">&quot;Use Combined VE/AFR table&quot;</constant>
<constant name="AFRStoich" units="AFR">4.5</constant>
<constant name="AFRStoichNB" units="Volts">0.450</constant>
<constant name="AFRStoichWB" units="AFR">4.5</constant>
<constant name="AFRTarget" units="AFR">4.5</constant>
<constant name="AMCOption">&quot;Disabled&quot;</constant>
<constant name="AMCT_thresh" units="sec">1800</constant>
<constant name="AMCdve" units="%">2</constant>
<constant name="AMCramve_dt" units="sec">20</constant>
<constant name="AMCstep" units="%">10</constant>
<constant name="AMCupdate_thresh" units="events">2</constant>
<constant name="AMCve_map" units="kPa">10.00</constant>
<constant name="AMCve_rpm" units="RPM">200</constant>
<constant name="AfrAlpha">0</constant>
<constant name="CID" units="cu.in.">181.0</constant>
<constant name="CWOption">&quot;Two-Point&quot;</constant>
<constant name="Delay_Teeth" units="teeth">0</constant>
<constant name="Dtpred_Gain" units="%">0</constant>
<constant name="DualSpkOptn">&quot;No Dual Spark&quot;</constant>
<constant name="IACStart">160</constant>
<constant name="IACaccstep" units="ms">0.0</constant>
<constant name="IACcoldpos" units="steps">120</constant>
<constant name="IACcoldtmp" units="?F">-40.0</constant>
<constant name="IACcoldxt" units="sec">40</constant>
<constant name="IACcrankpos" units="steps">100</constant>
<constant name="IACcrankxt" units="sec">5</constant>
<constant name="IACminstep" units="steps">1</constant>
<constant name="IACpwm_step" units="Hz">80</constant>
<constant name="IACtstep" units="ms">2.5</constant>
<constant name="ICCrankTrigger">&quot;Trigger Rise&quot;</constant>
<constant name="ICISR_pmask" units="%">50</constant>
<constant name="ICISR_tmask" units="ms">0.0</constant>
<constant name="ICIgnCapture">&quot;Rising Edge&quot;</constant>
<constant name="ICIgnOption">&quot;Standard Coil Charge&quot;</constant>
<constant name="IdleCtl">&quot;IAC Stepper Moving Only&quot;</constant>
<constant name="IdleHyst" units="?F">5.0</constant>
<constant name="IgnAlpha">0</constant>
<constant name="MAFOption">&quot;No MAF&quot;</constant>
<constant name="MAFpin">&quot;MAF on MAP pin&quot;</constant>
<constant name="MAPOXLimit" units="kPa">90.00</constant>
<constant name="No_Miss_Teeth" units="teeth">2</constant>
<constant name="No_Skip_Teeth" units="teeth">9</constant>
<constant name="OddAng" units="degrees">0.0</constant>
<constant name="PredOpt">&quot;Alpha-Beta-Gamma Filter&quot;</constant>
<constant name="RevLimMaxRtd" units="deg">12</constant>
<constant name="RevLimOption">&quot;Spark Retard&quot;</constant>
<constant name="RevLimRpm1" units="RPM">5500</constant>
<constant name="RevLimRpm2" units="RPM">6000</constant>
<constant name="TPSOXLimit" units="%">70.0</constant>
<constant name="acc_synchk">&quot;Check Always&quot;</constant>
<constant name="adcLF">50</constant>
<constant name="aeEndPW" units="ms">2.0</constant>
<constant name="aeTaperTime" units="s">0.1</constant>
<constant name="ae_hirpm" units="rpm">5000</constant>
<constant name="ae_lorpm" units="rpm">2500</constant>
<constant cols="12" name="afrTable1" rows="12" units="AFR">
13.5 13.5 13.5 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0
13.0 13.5 13.5 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0
12.5 13.5 13.5 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0
12.5 13.0 13.0 14.5 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0
12.5 13.0 13.0 14.5 14.5 14.5 14.5 14.5 14.5 14.5 14.5 14.5
12.5 12.5 13.0 13.8 13.8 13.8 13.8 13.8 13.8 13.8 13.8 13.8
12.5 12.5 12.5 13.4 13.4 13.4 13.4 13.4 13.4 13.4 13.4 13.4
12.0 12.0 12.0 12.5 13.2 13.2 13.2 13.2 13.2 13.2 13.2 13.2
11.0 11.0 11.0 11.0 11.0 12.5 12.5 12.5 12.5 12.5 12.5 12.5
11.0 11.0 11.0 11.0 11.0 11.0 12.0 12.0 12.0 12.0 12.0 12.0
</constant>
<constant cols="12" name="afrTable2" rows="12" units="AFR">
13.0 13.5 16.0 16.0 16.0 14.9 14.3 13.2 13.1 13.2 13.1 13.0
13.2 13.7 15.7 15.7 15.5 14.9 14.2 13.2 13.0 12.9 12.8 12.7
13.4 13.9 15.5 15.5 15.4 14.9 14.1 13.0 12.9 12.8 12.7 12.7
13.5 14.0 15.2 15.2 15.0 14.7 14.0 13.0 12.9 12.8 12.7 12.6
13.6 14.1 15.0 14.9 14.7 14.7 14.0 12.9 12.8 12.7 12.6 12.6
13.5 13.8 14.5 14.3 14.1 14.1 13.5 12.8 12.7 12.6 12.6 12.6
13.4 13.4 13.9 13.7 13.6 13.6 13.1 12.7 12.6 12.6 12.6 12.6
13.2 13.2 13.5 13.3 13.3 13.2 13.0 12.6 12.5 12.5 12.5 12.5
13.0 13.0 13.1 13.0 13.0 12.9 13.0 12.5 12.5 12.5 12.5 12.5
13.0 12.9 12.9 12.8 12.8 12.7 12.6 12.5 12.5 12.5 12.5 12.4
13.0 12.9 12.9 12.8 12.8 12.7 12.6 12.5 12.5 12.5 12.3 12.3
13.0 12.9 12.9 12.8 12.8 12.7 12.6 12.5 12.5 12.2 12.2 12.2
</constant>
<constant name="algorithm">&quot;Speed Density&quot;</constant>
<constant name="alpha" units="%">90</constant>
<constant cols="6" name="alphaMAPtable" rows="6" units="kPa">
100.0 60.0 30.0 35.0 40.0 40.0
100.0 65.0 35.0 40.0 45.0 45.0
100.0 70.0 40.0 45.0 50.0 50.0
100.0 75.0 45.0 50.0 55.0 55.0
100.0 80.0 50.0 55.0 60.0 60.0
</constant>
<constant name="alpha_hirpm" units="RPM">0</constant>
<constant name="alpha_lorpm" units="RPM">0</constant>
<constant name="alternate">&quot;Alternating&quot;</constant>
<constant name="amap_rpm" rows="6" units="RPM">
0
500
1000
1500
2000
2000
</constant>
<constant name="amap_tps" rows="6" units="%">
0.0
12.0
16.0
30.0
60.0
60.0
</constant>
<constant name="asTolerance" units="%">70</constant>
<constant name="aseCount" units="cycles">350</constant>
<constant name="aseCountHot" units="cycles">150</constant>
<constant name="asePct" units="%">45</constant>
<constant name="asePctHot" units="%">25</constant>
<constant name="baro0" units="kPa">3.5</constant>
<constant name="baroCorr">&quot;Two Independent Sensors&quot;</constant>
<constant name="baromax" units="kPa">416.5</constant>
<constant name="batt0" units="V">0.1</constant>
<constant name="battFac" units="ms/v">0.20</constant>
<constant name="battmax" units="V">29.7</constant>
<constant name="baud">115200</constant>
<constant name="bcor0" units="%">147.0</constant>
<constant name="bcormult" units="%">-47</constant>
<constant name="beta" units="%">80</constant>
<constant name="board_id_type" rows="16">
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
</constant>
<constant name="board_id_type0">&quot;MS-II ECU&quot;</constant>
<constant name="clt0" units="?F">0.0</constant>
<constant name="cltmult" units="%">100</constant>
<constant name="cold_adv_table" rows="10" units="deg">
6.0
5.0
4.0
3.0
2.0
1.0
0.0
0.0
0.0
0.0
</constant>
<constant name="crankCold" units="ms">12.0</constant>
<constant name="crankHot" units="ms">4.0</constant>
<constant name="crankTolerance" units="%">50</constant>
<constant name="crankingRPM" units="RPM">300</constant>
<constant name="divider">3</constant>
<constant name="dualTable">&quot;Single Table&quot;</constant>
<constant name="dwellAcc" units="ms">0.6</constant>
<constant name="dwellDuration" rows="5" units="ms">
2.4
0.9
0.0
-0.5
-0.9
</constant>
<constant name="dwellVolts" rows="5" units="V">
-4.0
-2.0
0.0
2.0
4.0
</constant>
<constant name="ego0" units="afr">0.0</constant>
<constant name="egoAlgorithm">&quot;Simple&quot;</constant>
<constant name="egoCount">16</constant>
<constant name="egoDelta" units="%">1</constant>
<constant name="egoKD" units="%">0</constant>
<constant name="egoKI" units="%">20</constant>
<constant name="egoKP" units="%">100</constant>
<constant name="egoKdelay1" units="ms">10</constant>
<constant name="egoKdelay2" units="revs">4000</constant>
<constant name="egoLF">60</constant>
<constant name="egoLimit" units="%">75</constant>
<constant name="egoRPM" units="RPM">1300</constant>
<constant name="egoTemp" units="?F">160.0</constant>
<constant name="egoType">&quot;Single Wide Band&quot;</constant>
<constant name="egomult" units="%">100</constant>
<constant name="fastIdleT" units="?F">140.0</constant>
<constant name="flexFuel">&quot;Disabled&quot;</constant>
<constant name="floodClear" units="%">70.0</constant>
<constant name="fmap1" units="kPa">30.0</constant>
<constant name="fmap10" units="kPa">130.0</constant>
<constant name="fmap11" units="kPa">145.0</constant>
<constant name="fmap12" units="kPa">160.0</constant>
<constant name="fmap2" units="kPa">40.0</constant>
<constant name="fmap3" units="kPa">50.0</constant>
<constant name="fmap4" units="kPa">60.0</constant>
<constant name="fmap5" units="kPa">70.0</constant>
<constant name="fmap6" units="kPa">80.0</constant>
<constant name="fmap7" units="kPa">90.0</constant>
<constant name="fmap8" units="kPa">100.0</constant>
<constant name="fmap9" units="kPa">115.0</constant>
<constant name="fmap_table" rows="12" units="kPa">
30.0
40.0
50.0
60.0
70.0
80.0
90.0
100.0
115.0
130.0
145.0
160.0
</constant>
<constant name="frpm1" units="RPM">500</constant>
<constant name="frpm10" units="RPM">4000</constant>
<constant name="frpm11" units="RPM">5000</constant>
<constant name="frpm12" units="RPM">6000</constant>
<constant name="frpm2" units="RPM">800</constant>
<constant name="frpm3" units="RPM">1200</constant>
<constant name="frpm4" units="RPM">1500</constant>
<constant name="frpm5" units="RPM">1750</constant>
<constant name="frpm6" units="RPM">2000</constant>
<constant name="frpm7" units="RPM">2250</constant>
<constant name="frpm8" units="RPM">2500</constant>
<constant name="frpm9" units="RPM">3000</constant>
<constant name="frpm_table" rows="12" units="RPM">
500
800
1200
1500
1750
2000
2250
2500
3000
4000
5000
6000
</constant>
<constant name="fuelCorr" rows="2" units="%">
100
163
</constant>
<constant name="fuelCorr0" units="%">100</constant>
<constant name="fuelCorr1" units="%">163</constant>
<constant name="fuelFreq" rows="2" units="Hz">
50
150
</constant>
<constant name="fuelFreq0" units="Hz">50</constant>
<constant name="fuelFreq1" units="Hz">150</constant>
<constant name="fuelSpkDel" rows="2" units="deg">
0.0
-13.0
</constant>
<constant name="fuelSpkDel0" units="deg">0.0</constant>
<constant name="fuelSpkDel1" units="deg">-13.0</constant>
<constant name="gamma" units="%">10</constant>
<constant name="iacstepTable" rows="10" units="steps">
40
60
75
90
105
120
130
140
150
160
</constant>
<constant name="injOpen" units="ms">1.0</constant>
<constant name="injPwmP" units="%">100</constant>
<constant name="injPwmPd" units="Ásec">66</constant>
<constant name="injPwmT" units="ms">25.4</constant>
<constant name="injTestMode">&quot;Normal Mode&quot;</constant>
<constant name="injTestOffTime" units="msec">60.0</constant>
<constant name="injTestPW" units="msec">20.000</constant>
<constant name="injTestSqrts" units="squirts">400</constant>
<constant name="injType">&quot;Port Injection&quot;</constant>
<constant name="ipwmTable" rows="10" units="%">
40
60
75
90
105
120
130
140
150
160
</constant>
<constant name="knkDirection">&quot;Below threshold&quot;</constant>
<constant name="knkLF">80</constant>
<constant name="knkOption">&quot;Disabled&quot;</constant>
<constant name="knk_dtble_adv" units="deg">3.0</constant>
<constant name="knk_hirpm" units="rpm">3500</constant>
<constant name="knk_lorpm" units="rpm">700</constant>
<constant name="knk_maxmap" units="kPa">70.0</constant>
<constant name="knk_maxrtd" units="deg">10.0</constant>
<constant name="knk_ndet" units="knocks">2</constant>
<constant name="knk_rpm" rows="6" units="rpm">
500
1000
2000
3000
4000
5000
</constant>
<constant name="knk_step1" units="deg">3.0</constant>
<constant name="knk_step2" units="deg">1.0</constant>
<constant name="knk_tadv" units="sec">2.0</constant>
<constant name="knk_thresh" rows="6" units="v">
2.00
2.00
2.00
2.00
2.00
2.00
</constant>
<constant name="knk_trtd" units="sec">0.2</constant>
<constant name="knock0" units="V">0.0</constant>
<constant name="knockmax" units="V">5.0</constant>
<constant name="maeBins" rows="4" units="ms">
0.0
0.0
0.0
0.0
</constant>
<constant name="maeRates" rows="4" units="kPa/s">
0
0
0
0
</constant>
<constant name="map0" units="kPa">3.5</constant>
<constant name="mapLF">50</constant>
<constant name="mapThresh" units="kPa/s">100</constant>
<constant name="mapmax" units="kPa">416.5</constant>
<constant name="mat0" units="?F">0.0</constant>
<constant name="matmult" units="%">100</constant>
<constant name="max_coil_dur" units="ms">3.1</constant>
<constant name="max_spk_dur" units="ms">2.0</constant>
<constant name="nCylinders">&quot;6&quot;</constant>
<constant name="nInjectors">&quot;6&quot;</constant>
<constant name="no_skip_pulses">3</constant>
<constant name="primePulse" units="ms">6.0</constant>
<constant name="primePulseHot" units="ms">2.0</constant>
<constant name="prime_delay" units="sec">0</constant>
<constant cols="7" name="psCondition" rows="2">
60 60 60 60 60 60 60
</constant>
<constant name="psConnector" rows="7">
32
32
32
32
32
32
32
</constant>
<constant name="psEnabled" rows="7" units="on/off">
0
0
0
0
0
0
0
</constant>
<constant cols="7" name="psHysteresis" rows="2">
0 0 0 0 0 0 0
0 0 0 0 0 0 0
</constant>
<constant name="psInitValue" rows="7">
0
0
0
0
0
0
0
</constant>
<constant cols="7" name="psOutOffset" rows="2">
1 1 1 1 1 1 1
1 1 1 1 1 1 1
</constant>
<constant cols="7" name="psOutSize" rows="2">
0 0 0 0 0 0 0
0 0 0 0 0 0 0
</constant>
<constant name="psPortValue" rows="7">
0
0
0
0
0
0
0
</constant>
<constant cols="7" name="psThreshold" rows="2">
0 0 0 0 0 0 0
0 0 0 0 0 0 0
</constant>
<constant name="pulseTolerance" units="%">25</constant>
<constant name="reqFuel" units="ms">10.20</constant>
<constant name="rpmLF">50</constant>
<constant name="smap1" units="kPa">30.0</constant>
<constant name="smap10" units="kPa">130.0</constant>
<constant name="smap11" units="kPa">145.0</constant>
<constant name="smap12" units="kPa">160.0</constant>
<constant name="smap2" units="kPa">40.0</constant>
<constant name="smap3" units="kPa">50.0</constant>
<constant name="smap4" units="kPa">60.0</constant>
<constant name="smap5" units="kPa">70.0</constant>
<constant name="smap6" units="kPa">80.0</constant>
<constant name="smap7" units="kPa">90.0</constant>
<constant name="smap8" units="kPa">100.0</constant>
<constant name="smap9" units="kPa">115.0</constant>
<constant name="smap_table" rows="12" units="kPa">
30.0
40.0
50.0
60.0
70.0
80.0
90.0
100.0
115.0
130.0
145.0
160.0
</constant>
<constant name="spkout_hi_lo">&quot;Going High (Inverted)&quot;</constant>
<constant name="srpm1" units="RPM">500</constant>
<constant name="srpm10" units="RPM">4000</constant>
<constant name="srpm11" units="RPM">5000</constant>
<constant name="srpm12" units="RPM">6000</constant>
<constant name="srpm2" units="RPM">800</constant>
<constant name="srpm3" units="RPM">1200</constant>
<constant name="srpm4" units="RPM">1500</constant>
<constant name="srpm5" units="RPM">1750</constant>
<constant name="srpm6" units="RPM">2000</constant>
<constant name="srpm7" units="RPM">2250</constant>
<constant name="srpm8" units="RPM">2500</constant>
<constant name="srpm9" units="RPM">3000</constant>
<constant name="srpm_table" rows="12" units="RPM">
500
800
1200
1500
1750
2000
2250
2500
3000
4000
5000
6000
</constant>
<constant name="taeBins" rows="4" units="ms">
2.0
5.0
10.5
15.0
</constant>
<constant name="taeColdA" units="ms">3.0</constant>
<constant name="taeColdM" units="%">130</constant>
<constant name="taeRates" rows="4" units="%/s">
10.0
40.0
80.0
154.0
</constant>
<constant name="taeTime" units="s">0.2</constant>
<constant name="tdePct">90</constant>
<constant name="tempTable" rows="10" units="?F">
-40.0
-20.0
0.0
20.0
40.0
60.0
80.0
100.0
130.0
160.0
</constant>
<constant name="tempUnits">&quot;Coolant/IAT Tables in ?F&quot;</constant>
<constant name="temper1" units="?F">-40.0</constant>
<constant name="temper10" units="?F">160.0</constant>
<constant name="temper2" units="?F">-20.0</constant>
<constant name="temper3" units="?F">0.0</constant>
<constant name="temper4" units="?F">20.0</constant>
<constant name="temper5" units="?F">40.0</constant>
<constant name="temper6" units="?F">60.0</constant>
<constant name="temper7" units="?F">80.0</constant>
<constant name="temper8" units="?F">100.0</constant>
<constant name="temper9" units="?F">130.0</constant>
<constant name="tpsLF">75</constant>
<constant name="tpsMax" units="ADC">996</constant>
<constant name="tpsMin" units="ADC">194</constant>
<constant name="tpsProportion" units="%">100</constant>
<constant name="tpsThresh" units="%/s">20.0</constant>
<constant name="triggerOffset" units="deg">0.00</constant>
<constant name="triggerTeeth" units="teeth">0</constant>
<constant name="twoStroke">&quot;Four-stroke&quot;</constant>
<constant name="wueBins" rows="10" units="%">
180
180
160
150
135
125
113
108
102
100
</constant>
</page>
<page number="1" size="946">
<constant name="AMCNBurns" units="burns">0</constant>
<constant name="MAFCor" rows="12" units="%">
100
100
100
100
100
100
100
100
100
100
100
100
</constant>
<constant name="MAFDir">&quot;Use Above&quot;</constant>
<constant name="MAFFlow" rows="12" units="g/sec">
1.0
20.0
40.0
60.0
80.0
100.0
120.0
140.0
160.0
180.0
200.0
250.0
</constant>
<constant name="MAFRPM1" units="rpm">1200</constant>
<constant name="MAFRPM2" units="rpm">3000</constant>
<constant name="MatRtdRPMHi" units="rpm">1500</constant>
<constant name="MatRtdRPMLo" units="rpm">800</constant>
<constant name="VEIXOptn">&quot;Use MAP only&quot;</constant>
<constant cols="12" name="advanceTable" rows="12" units="deg">
14.5 15.0 18.5 21.0 23.2 25.4 27.5 29.7 34.0 34.0 34.0 34.0
15.0 18.0 20.0 21.0 23.2 25.4 27.5 29.7 34.0 34.0 34.0 34.0
16.0 18.0 20.0 21.0 23.2 25.4 27.5 29.7 34.0 34.0 34.0 34.0
12.0 12.5 14.5 15.5 17.7 19.9 22.0 24.2 28.5 28.5 28.5 28.5
12.0 12.0 12.0 12.0 12.2 14.4 16.5 18.7 23.0 23.0 23.0 23.0
12.0 12.0 12.0 12.0 12.0 12.0 12.0 13.2 17.5 17.5 17.5 17.5
12.0 12.0 12.0 12.0 12.0 12.0 12.0 12.0 12.0 12.0 12.0 12.0
</constant>
<constant name="aseCntTable" rows="10" units="cycles">
350
330
310
290
270
250
230
210
180
150
</constant>
<constant name="asePctTable" rows="10" units="%">
45
43
41
39
37
35
33
31
28
25
</constant>
<constant name="baroCorrDelta" rows="6" units="%">
0.0
0.0
0.0
0.0
0.0
0.0
</constant>
<constant name="baroCorrVals" rows="6" units="kPa">
80.0
90.0
100.0
105.0
110.0
120.0
</constant>
<constant name="crankPWTable" rows="10" units="ms">
12.0
11.2
10.4
9.6
8.8
8.0
7.2
6.4
5.2
4.0
</constant>
<constant name="matCorrDelta" rows="6" units="%">
0.0
0.0
0.0
0.0
0.0
0.0
</constant>
<constant name="matCorrTemps" rows="6" units="?F">
40.0
60.0
100.0
130.0
160.0
180.0
</constant>
<constant name="matRetard" rows="6" units="deg">
0.0
0.0
2.0
4.0
6.0
8.0
</constant>
<constant name="matTemps" rows="6" units="?F">
160.0
180.0
200.0
220.0
240.0
260.0
</constant>
<constant name="primePWTable" rows="10" units="ms">
6.0
5.6
5.2
4.8
4.4
4.0
3.6
3.2
2.6
2.0
</constant>
<constant cols="12" name="veTable1" rows="12" units="%">
26 26 29 34 40 46 50 55 58 61 61 60
29 29 32 38 46 53 56 60 63 66 65 62
38 37 39 44 53 61 65 67 69 73 71 66
43 42 43 45 54 63 66 69 71 75 73 67
48 46 48 50 58 65 69 71 73 77 75 69
52 51 52 55 62 67 71 73 75 79 77 71
57 59 61 65 69 72 76 78 81 85 85 80
61 62 65 69 72 75 79 82 85 89 88 84
65 66 69 73 76 78 82 86 90 93 92 88
68 70 73 78 81 83 86 90 94 98 97 93
72 77 82 87 90 93 95 100 105 109 108 103
74 81 86 91 95 97 100 105 111 114 113 108
</constant>
<constant cols="12" name="veTable2" rows="12" units="%">
</constant>
<constant name="xTauCLT" rows="10" units="%">
20000
15000
10000
8000
5800
4800
3600
2400
1200
100
</constant>
<constant name="xTauMAT" rows="10" units="%">
140
136
126
116
110
106
104
102
100
100
</constant>
<constant name="xTauOption">&quot;Off&quot;</constant>
<constant cols="12" name="xTauTable" rows="12" units="sec">
0.19 0.15 0.12 0.09 0.06 0.05 0.04 0.03 0.03 0.02 0.02 0.01
0.21 0.19 0.13 0.10 0.07 0.06 0.05 0.04 0.03 0.03 0.02 0.01
0.22 0.19 0.15 0.12 0.09 0.08 0.06 0.05 0.04 0.03 0.02 0.02
0.23 0.20 0.16 0.13 0.10 0.09 0.07 0.05 0.04 0.03 0.02 0.02
0.24 0.21 0.17 0.14 0.11 0.10 0.08 0.06 0.04 0.04 0.03 0.02
0.26 0.23 0.18 0.15 0.13 0.11 0.09 0.07 0.05 0.04 0.03 0.02
0.27 0.24 0.19 0.17 0.14 0.12 0.10 0.07 0.05 0.04 0.03 0.02
0.28 0.25 0.20 0.18 0.15 0.13 0.11 0.08 0.06 0.05 0.03 0.03
0.29 0.26 0.21 0.19 0.16 0.14 0.12 0.08 0.06 0.05 0.04 0.03
0.30 0.27 0.22 0.21 0.18 0.15 0.13 0.09 0.06 0.05 0.04 0.03
0.31 0.28 0.23 0.22 0.19 0.16 0.14 0.10 0.07 0.06 0.04 0.03
0.33 0.29 0.24 0.23 0.20 0.17 0.15 0.10 0.07 0.06 0.04 0.03
</constant>
<constant name="xTdecel" units="%">100</constant>
<constant name="xTscale">1</constant>
<constant name="xTx" units="%">30</constant>
</page>
</msq>
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726183 12/14/07 11:57 PM
It is more difficult that way, I can install this MSQ into my system and open it with Mega tune.
Are you set up for Hybrid Alpha N?
Re: G-Raider 3.0L Supercharger Project [Re: OldColt] #726184 12/15/07 12:15 AM
FrankR Offline OP
Hybrid Alpha N is the MAP/MAF blending, right? No, I am using the MAP sensor only.
I just sent the .msq file via email. If you need it in a different format, let me know what you need. Thanks.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726185 12/15/07 12:37 AM
It is back to you.
I did an estmate on the ignition. I also let the EGO correction available full time, it was set like a narrowband.
Come to think of it I did not look at all the O2 settings but some of that is not in the MSQ.
You can do a save as for your MSQs allowing you to keep track of them better than the timestamp that defaults to them.
Re: G-Raider 3.0L Supercharger Project [Re: OldColt] #726186 12/15/07 12:45 AM
FrankR Offline OP
Thanks - I'll install the modified file and see if it starts.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726187 12/15/07 01:09 AM
FrankR Offline OP
No joy...
I have not installed the IGN pullup resistor because it seemed "iffy" that it would need it. What do you think?
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726188 12/15/07 01:13 AM
Are you running the Opto or going direct to the processer? But a pullup is needed since the dizzy is just a switch. I get +5V from within the VR conditioning area to install a 450 Ohm pullup.
Re: G-Raider 3.0L Supercharger Project [Re: OldColt] #726189 12/15/07 01:24 AM
FrankR Offline OP
I don't understand what you're saying there.
I'm using the VB921 high current ignition driver in MS, triggering the coil (-). The distributor is from a '90/'91 Montero (assuming it's good - haven't tested it in a vehicle) and I'm taking the signal from the low resolution wheel (6 signals/revolution) and not using the high resolution signal at all.
When I was checking the distributor (off the truck and not connected to MS) to see which wire was which with my digital voltmeter, I applied B+ to the sensor. I found the signal output voltage low - about .2v - does that indicate that I need to install the pullup resistor circuit? If so, what value resistor would you use?
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726190 12/15/07 01:46 AM
The MS will trigger the spark with the VB921, this is it's output.
A pullup will be in the input circuit. The original MS is setup for either a set of points,(using the Opto isolator) or a VR sensor.
Mitsubishi uses a simple trigger for switching the timing events, this provides a rather clean signal especially with a shielded conductor. The MS2 has a 1K resistor on the processor pin used for the input so not much other conditioning is needed. So you can get by with a wire from the 37pin connector to the processor and install a pullup so the Dizzy has something to switch.
PHP: 7.4.33 Page Time: 0.021s Queries: 15 (0.018s) Memory: 0.7035 MB (Peak: 0.9089 MB) Data Comp: Off Server Time: 2026-06-10 01:49:08 UTC
