Re: G-Raider 3.0L Supercharger Project
[Re: OldColt]
#726181
12/14/07 11:39 PM
No, I don't have a scope. I do have the LEDs installed on the MS panel. I've never tried to use the timing light while rotating the engine by hand - maybe I'll try that.
I have the MS set for rising edge, since the manual said that was the best setting for most vehicles.
I'll see if I can figure out how to print the .msq file to a disk, transfer it to this desktop and post it...... give me a few minutes.
Frank
[Re: OldColt]
#726182
12/14/07 11:49 PM
I don't know if you look at them in this format or not.... I opened it with Notepad: sion="1.0" encoding="ISO-8859-1"?> <msq xmlns="http://www.msefi.com/:msq"> <bibliography author="MegaTune 2.25 p1" writeDate="2006-12-25T06:24:53-05:00" /> <versionInfo fileFormat="4.0" nPages="2" signature="MSII Rev 2.86000 " /> <page number="0" size="994"> <constant name="AFRMult">"Use Combined VE/AFR table"</constant> <constant name="AFRStoich" units="AFR">4.5</constant> <constant name="AFRStoichNB" units="Volts">0.450</constant> <constant name="AFRStoichWB" units="AFR">4.5</constant> <constant name="AFRTarget" units="AFR">4.5</constant> <constant name="AMCOption">"Disabled"</constant> <constant name="AMCT_thresh" units="sec">1800</constant> <constant name="AMCdve" units="%">2</constant> <constant name="AMCramve_dt" units="sec">20</constant> <constant name="AMCstep" units="%">10</constant> <constant name="AMCupdate_thresh" units="events">2</constant> <constant name="AMCve_map" units="kPa">10.00</constant> <constant name="AMCve_rpm" units="RPM">200</constant> <constant name="AfrAlpha">0</constant> <constant name="CID" units="cu.in.">181.0</constant> <constant name="CWOption">"Two-Point"</constant> <constant name="Delay_Teeth" units="teeth">0</constant> <constant name="Dtpred_Gain" units="%">0</constant> <constant name="DualSpkOptn">"No Dual Spark"</constant> <constant name="IACStart">160</constant> <constant name="IACaccstep" units="ms">0.0</constant> <constant name="IACcoldpos" units="steps">120</constant> <constant name="IACcoldtmp" units="?F">-40.0</constant> <constant name="IACcoldxt" units="sec">40</constant> <constant name="IACcrankpos" units="steps">100</constant> <constant name="IACcrankxt" units="sec">5</constant> <constant name="IACminstep" units="steps">1</constant> <constant name="IACpwm_step" units="Hz">80</constant> <constant name="IACtstep" units="ms">2.5</constant> <constant name="ICCrankTrigger">"Trigger Rise"</constant> <constant name="ICISR_pmask" units="%">50</constant> <constant name="ICISR_tmask" units="ms">0.0</constant> <constant name="ICIgnCapture">"Rising Edge"</constant> <constant name="ICIgnOption">"Standard Coil Charge"</constant> <constant name="IdleCtl">"IAC Stepper Moving Only"</constant> <constant name="IdleHyst" units="?F">5.0</constant> <constant name="IgnAlpha">0</constant> <constant name="MAFOption">"No MAF"</constant> <constant name="MAFpin">"MAF on MAP pin"</constant> <constant name="MAPOXLimit" units="kPa">90.00</constant> <constant name="No_Miss_Teeth" units="teeth">2</constant> <constant name="No_Skip_Teeth" units="teeth">9</constant> <constant name="OddAng" units="degrees">0.0</constant> <constant name="PredOpt">"Alpha-Beta-Gamma Filter"</constant> <constant name="RevLimMaxRtd" units="deg">12</constant> <constant name="RevLimOption">"Spark Retard"</constant> <constant name="RevLimRpm1" units="RPM">5500</constant> <constant name="RevLimRpm2" units="RPM">6000</constant> <constant name="TPSOXLimit" units="%">70.0</constant> <constant name="acc_synchk">"Check Always"</constant> <constant name="adcLF">50</constant> <constant name="aeEndPW" units="ms">2.0</constant> <constant name="aeTaperTime" units="s">0.1</constant> <constant name="ae_hirpm" units="rpm">5000</constant> <constant name="ae_lorpm" units="rpm">2500</constant> <constant cols="12" name="afrTable1" rows="12" units="AFR"> 13.5 13.5 13.5 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 13.0 13.5 13.5 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 12.5 13.5 13.5 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 12.5 13.0 13.0 14.5 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 12.5 13.0 13.0 14.5 14.5 14.5 14.5 14.5 14.5 14.5 14.5 14.5 12.5 12.5 13.0 13.8 13.8 13.8 13.8 13.8 13.8 13.8 13.8 13.8 12.5 12.5 12.5 13.4 13.4 13.4 13.4 13.4 13.4 13.4 13.4 13.4 12.0 12.0 12.0 12.5 13.2 13.2 13.2 13.2 13.2 13.2 13.2 13.2 11.0 11.0 11.0 11.0 11.0 12.5 12.5 12.5 12.5 12.5 12.5 12.5 11.0 11.0 11.0 11.0 11.0 12.5 12.5 12.5 12.5 12.5 12.5 12.5 11.0 11.0 11.0 11.0 11.0 12.5 12.5 12.5 12.5 12.5 12.5 12.5 11.0 11.0 11.0 11.0 11.0 11.0 12.0 12.0 12.0 12.0 12.0 12.0 </constant> <constant cols="12" name="afrTable2" rows="12" units="AFR"> 13.0 13.5 16.0 16.0 16.0 14.9 14.3 13.2 13.1 13.2 13.1 13.0 13.2 13.7 15.7 15.7 15.5 14.9 14.2 13.2 13.0 12.9 12.8 12.7 13.4 13.9 15.5 15.5 15.4 14.9 14.1 13.0 12.9 12.8 12.7 12.7 13.5 14.0 15.2 15.2 15.0 14.7 14.0 13.0 12.9 12.8 12.7 12.6 13.6 14.1 15.0 14.9 14.7 14.7 14.0 12.9 12.8 12.7 12.6 12.6 13.5 13.8 14.5 14.3 14.1 14.1 13.5 12.8 12.7 12.6 12.6 12.6 13.4 13.4 13.9 13.7 13.6 13.6 13.1 12.7 12.6 12.6 12.6 12.6 13.2 13.2 13.5 13.3 13.3 13.2 13.0 12.6 12.5 12.5 12.5 12.5 13.0 13.0 13.1 13.0 13.0 12.9 13.0 12.5 12.5 12.5 12.5 12.5 13.0 12.9 12.9 12.8 12.8 12.7 12.6 12.5 12.5 12.5 12.5 12.4 13.0 12.9 12.9 12.8 12.8 12.7 12.6 12.5 12.5 12.5 12.3 12.3 13.0 12.9 12.9 12.8 12.8 12.7 12.6 12.5 12.5 12.2 12.2 12.2 </constant> <constant name="algorithm">"Speed Density"</constant> <constant name="alpha" units="%">90</constant> <constant cols="6" name="alphaMAPtable" rows="6" units="kPa"> 100.0 60.0 30.0 35.0 40.0 40.0 100.0 65.0 35.0 40.0 45.0 45.0 100.0 70.0 40.0 45.0 50.0 50.0 100.0 75.0 45.0 50.0 55.0 55.0 100.0 80.0 50.0 55.0 60.0 60.0 100.0 80.0 50.0 55.0 60.0 60.0 </constant> <constant name="alpha_hirpm" units="RPM">0</constant> <constant name="alpha_lorpm" units="RPM">0</constant> <constant name="alternate">"Alternating"</constant> <constant name="amap_rpm" rows="6" units="RPM"> 0 500 1000 1500 2000 2000 </constant> <constant name="amap_tps" rows="6" units="%"> 0.0 12.0 16.0 30.0 60.0 60.0 </constant> <constant name="asTolerance" units="%">70</constant> <constant name="aseCount" units="cycles">350</constant> <constant name="aseCountHot" units="cycles">150</constant> <constant name="asePct" units="%">45</constant> <constant name="asePctHot" units="%">25</constant> <constant name="baro0" units="kPa">3.5</constant> <constant name="baroCorr">"Two Independent Sensors"</constant> <constant name="baromax" units="kPa">416.5</constant> <constant name="batt0" units="V">0.1</constant> <constant name="battFac" units="ms/v">0.20</constant> <constant name="battmax" units="V">29.7</constant> <constant name="baud">115200</constant> <constant name="bcor0" units="%">147.0</constant> <constant name="bcormult" units="%">-47</constant> <constant name="beta" units="%">80</constant> <constant name="board_id_type" rows="16"> 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 </constant> <constant name="board_id_type0">"MS-II ECU"</constant> <constant name="clt0" units="?F">0.0</constant> <constant name="cltmult" units="%">100</constant> <constant name="cold_adv_table" rows="10" units="deg"> 6.0 5.0 4.0 3.0 2.0 1.0 0.0 0.0 0.0 0.0 </constant> <constant name="crankCold" units="ms">12.0</constant> <constant name="crankHot" units="ms">4.0</constant> <constant name="crankTolerance" units="%">50</constant> <constant name="crankingRPM" units="RPM">300</constant> <constant name="divider">3</constant> <constant name="dualTable">"Single Table"</constant> <constant name="dwellAcc" units="ms">0.6</constant> <constant name="dwellDuration" rows="5" units="ms"> 2.4 0.9 0.0 -0.5 -0.9 </constant> <constant name="dwellVolts" rows="5" units="V"> -4.0 -2.0 0.0 2.0 4.0 </constant> <constant name="ego0" units="afr">0.0</constant> <constant name="egoAlgorithm">"Simple"</constant> <constant name="egoCount">16</constant> <constant name="egoDelta" units="%">1</constant> <constant name="egoKD" units="%">0</constant> <constant name="egoKI" units="%">20</constant> <constant name="egoKP" units="%">100</constant> <constant name="egoKdelay1" units="ms">10</constant> <constant name="egoKdelay2" units="revs">4000</constant> <constant name="egoLF">60</constant> <constant name="egoLimit" units="%">75</constant> <constant name="egoRPM" units="RPM">1300</constant> <constant name="egoTemp" units="?F">160.0</constant> <constant name="egoType">"Single Wide Band"</constant> <constant name="egomult" units="%">100</constant> <constant name="fastIdleT" units="?F">140.0</constant> <constant name="flexFuel">"Disabled"</constant> <constant name="floodClear" units="%">70.0</constant> <constant name="fmap1" units="kPa">30.0</constant> <constant name="fmap10" units="kPa">130.0</constant> <constant name="fmap11" units="kPa">145.0</constant> <constant name="fmap12" units="kPa">160.0</constant> <constant name="fmap2" units="kPa">40.0</constant> <constant name="fmap3" units="kPa">50.0</constant> <constant name="fmap4" units="kPa">60.0</constant> <constant name="fmap5" units="kPa">70.0</constant> <constant name="fmap6" units="kPa">80.0</constant> <constant name="fmap7" units="kPa">90.0</constant> <constant name="fmap8" units="kPa">100.0</constant> <constant name="fmap9" units="kPa">115.0</constant> <constant name="fmap_table" rows="12" units="kPa"> 30.0 40.0 50.0 60.0 70.0 80.0 90.0 100.0 115.0 130.0 145.0 160.0 </constant> <constant name="frpm1" units="RPM">500</constant> <constant name="frpm10" units="RPM">4000</constant> <constant name="frpm11" units="RPM">5000</constant> <constant name="frpm12" units="RPM">6000</constant> <constant name="frpm2" units="RPM">800</constant> <constant name="frpm3" units="RPM">1200</constant> <constant name="frpm4" units="RPM">1500</constant> <constant name="frpm5" units="RPM">1750</constant> <constant name="frpm6" units="RPM">2000</constant> <constant name="frpm7" units="RPM">2250</constant> <constant name="frpm8" units="RPM">2500</constant> <constant name="frpm9" units="RPM">3000</constant> <constant name="frpm_table" rows="12" units="RPM"> 500 800 1200 1500 1750 2000 2250 2500 3000 4000 5000 6000 </constant> <constant name="fuelCorr" rows="2" units="%"> 100 163 </constant> <constant name="fuelCorr0" units="%">100</constant> <constant name="fuelCorr1" units="%">163</constant> <constant name="fuelFreq" rows="2" units="Hz"> 50 150 </constant> <constant name="fuelFreq0" units="Hz">50</constant> <constant name="fuelFreq1" units="Hz">150</constant> <constant name="fuelSpkDel" rows="2" units="deg"> 0.0 -13.0 </constant> <constant name="fuelSpkDel0" units="deg">0.0</constant> <constant name="fuelSpkDel1" units="deg">-13.0</constant> <constant name="gamma" units="%">10</constant> <constant name="iacstepTable" rows="10" units="steps"> 40 60 75 90 105 120 130 140 150 160 </constant> <constant name="injOpen" units="ms">1.0</constant> <constant name="injPwmP" units="%">100</constant> <constant name="injPwmPd" units="Ásec">66</constant> <constant name="injPwmT" units="ms">25.4</constant> <constant name="injTestMode">"Normal Mode"</constant> <constant name="injTestOffTime" units="msec">60.0</constant> <constant name="injTestPW" units="msec">20.000</constant> <constant name="injTestSqrts" units="squirts">400</constant> <constant name="injType">"Port Injection"</constant> <constant name="ipwmTable" rows="10" units="%"> 40 60 75 90 105 120 130 140 150 160 </constant> <constant name="knkDirection">"Below threshold"</constant> <constant name="knkLF">80</constant> <constant name="knkOption">"Disabled"</constant> <constant name="knk_dtble_adv" units="deg">3.0</constant> <constant name="knk_hirpm" units="rpm">3500</constant> <constant name="knk_lorpm" units="rpm">700</constant> <constant name="knk_maxmap" units="kPa">70.0</constant> <constant name="knk_maxrtd" units="deg">10.0</constant> <constant name="knk_ndet" units="knocks">2</constant> <constant name="knk_rpm" rows="6" units="rpm"> 500 1000 2000 3000 4000 5000 </constant> <constant name="knk_step1" units="deg">3.0</constant> <constant name="knk_step2" units="deg">1.0</constant> <constant name="knk_tadv" units="sec">2.0</constant> <constant name="knk_thresh" rows="6" units="v"> 2.00 2.00 2.00 2.00 2.00 2.00 </constant> <constant name="knk_trtd" units="sec">0.2</constant> <constant name="knock0" units="V">0.0</constant> <constant name="knockmax" units="V">5.0</constant> <constant name="maeBins" rows="4" units="ms"> 0.0 0.0 0.0 0.0 </constant> <constant name="maeRates" rows="4" units="kPa/s"> 0 0 0 0 </constant> <constant name="map0" units="kPa">3.5</constant> <constant name="mapLF">50</constant> <constant name="mapThresh" units="kPa/s">100</constant> <constant name="mapmax" units="kPa">416.5</constant> <constant name="mat0" units="?F">0.0</constant> <constant name="matmult" units="%">100</constant> <constant name="max_coil_dur" units="ms">3.1</constant> <constant name="max_spk_dur" units="ms">2.0</constant> <constant name="nCylinders">"6"</constant> <constant name="nInjectors">"6"</constant> <constant name="no_skip_pulses">3</constant> <constant name="primePulse" units="ms">6.0</constant> <constant name="primePulseHot" units="ms">2.0</constant> <constant name="prime_delay" units="sec">0</constant> <constant cols="7" name="psCondition" rows="2"> 60 60 60 60 60 60 60 60 60 60 60 60 60 60 </constant> <constant name="psConnector" rows="7"> 32 32 32 32 32 32 32 </constant> <constant name="psEnabled" rows="7" units="on/off"> 0 0 0 0 0 0 0 </constant> <constant cols="7" name="psHysteresis" rows="2"> 0 0 0 0 0 0 0 0 0 0 0 0 0 0 </constant> <constant name="psInitValue" rows="7"> 0 0 0 0 0 0 0 </constant> <constant cols="7" name="psOutOffset" rows="2"> 1 1 1 1 1 1 1 1 1 1 1 1 1 1 </constant> <constant cols="7" name="psOutSize" rows="2"> 0 0 0 0 0 0 0 0 0 0 0 0 0 0 </constant> <constant name="psPortValue" rows="7"> 0 0 0 0 0 0 0 </constant> <constant cols="7" name="psThreshold" rows="2"> 0 0 0 0 0 0 0 0 0 0 0 0 0 0 </constant> <constant name="pulseTolerance" units="%">25</constant> <constant name="reqFuel" units="ms">10.20</constant> <constant name="rpmLF">50</constant> <constant name="smap1" units="kPa">30.0</constant> <constant name="smap10" units="kPa">130.0</constant> <constant name="smap11" units="kPa">145.0</constant> <constant name="smap12" units="kPa">160.0</constant> <constant name="smap2" units="kPa">40.0</constant> <constant name="smap3" units="kPa">50.0</constant> <constant name="smap4" units="kPa">60.0</constant> <constant name="smap5" units="kPa">70.0</constant> <constant name="smap6" units="kPa">80.0</constant> <constant name="smap7" units="kPa">90.0</constant> <constant name="smap8" units="kPa">100.0</constant> <constant name="smap9" units="kPa">115.0</constant> <constant name="smap_table" rows="12" units="kPa"> 30.0 40.0 50.0 60.0 70.0 80.0 90.0 100.0 115.0 130.0 145.0 160.0 </constant> <constant name="spkout_hi_lo">"Going High (Inverted)"</constant> <constant name="srpm1" units="RPM">500</constant> <constant name="srpm10" units="RPM">4000</constant> <constant name="srpm11" units="RPM">5000</constant> <constant name="srpm12" units="RPM">6000</constant> <constant name="srpm2" units="RPM">800</constant> <constant name="srpm3" units="RPM">1200</constant> <constant name="srpm4" units="RPM">1500</constant> <constant name="srpm5" units="RPM">1750</constant> <constant name="srpm6" units="RPM">2000</constant> <constant name="srpm7" units="RPM">2250</constant> <constant name="srpm8" units="RPM">2500</constant> <constant name="srpm9" units="RPM">3000</constant> <constant name="srpm_table" rows="12" units="RPM"> 500 800 1200 1500 1750 2000 2250 2500 3000 4000 5000 6000 </constant> <constant name="taeBins" rows="4" units="ms"> 2.0 5.0 10.5 15.0 </constant> <constant name="taeColdA" units="ms">3.0</constant> <constant name="taeColdM" units="%">130</constant> <constant name="taeRates" rows="4" units="%/s"> 10.0 40.0 80.0 154.0 </constant> <constant name="taeTime" units="s">0.2</constant> <constant name="tdePct">90</constant> <constant name="tempTable" rows="10" units="?F"> -40.0 -20.0 0.0 20.0 40.0 60.0 80.0 100.0 130.0 160.0 </constant> <constant name="tempUnits">"Coolant/IAT Tables in ?F"</constant> <constant name="temper1" units="?F">-40.0</constant> <constant name="temper10" units="?F">160.0</constant> <constant name="temper2" units="?F">-20.0</constant> <constant name="temper3" units="?F">0.0</constant> <constant name="temper4" units="?F">20.0</constant> <constant name="temper5" units="?F">40.0</constant> <constant name="temper6" units="?F">60.0</constant> <constant name="temper7" units="?F">80.0</constant> <constant name="temper8" units="?F">100.0</constant> <constant name="temper9" units="?F">130.0</constant> <constant name="tpsLF">75</constant> <constant name="tpsMax" units="ADC">996</constant> <constant name="tpsMin" units="ADC">194</constant> <constant name="tpsProportion" units="%">100</constant> <constant name="tpsThresh" units="%/s">20.0</constant> <constant name="triggerOffset" units="deg">0.00</constant> <constant name="triggerTeeth" units="teeth">0</constant> <constant name="twoStroke">"Four-stroke"</constant> <constant name="wueBins" rows="10" units="%"> 180 180 160 150 135 125 113 108 102 100 </constant> </page> <page number="1" size="946"> <constant name="AMCNBurns" units="burns">0</constant> <constant name="MAFCor" rows="12" units="%"> 100 100 100 100 100 100 100 100 100 100 100 100 </constant> <constant name="MAFDir">"Use Above"</constant> <constant name="MAFFlow" rows="12" units="g/sec"> 1.0 20.0 40.0 60.0 80.0 100.0 120.0 140.0 160.0 180.0 200.0 250.0 </constant> <constant name="MAFRPM1" units="rpm">1200</constant> <constant name="MAFRPM2" units="rpm">3000</constant> <constant name="MatRtdRPMHi" units="rpm">1500</constant> <constant name="MatRtdRPMLo" units="rpm">800</constant> <constant name="VEIXOptn">"Use MAP only"</constant> <constant cols="12" name="advanceTable" rows="12" units="deg"> 14.5 15.0 18.5 21.0 23.2 25.4 27.5 29.7 34.0 34.0 34.0 34.0 14.5 15.0 18.5 21.0 23.2 25.4 27.5 29.7 34.0 34.0 34.0 34.0 15.0 18.0 20.0 21.0 23.2 25.4 27.5 29.7 34.0 34.0 34.0 34.0 15.0 18.0 20.0 21.0 23.2 25.4 27.5 29.7 34.0 34.0 34.0 34.0 15.0 18.0 20.0 21.0 23.2 25.4 27.5 29.7 34.0 34.0 34.0 34.0 16.0 18.0 20.0 21.0 23.2 25.4 27.5 29.7 34.0 34.0 34.0 34.0 16.0 18.0 20.0 21.0 23.2 25.4 27.5 29.7 34.0 34.0 34.0 34.0 16.0 18.0 20.0 21.0 23.2 25.4 27.5 29.7 34.0 34.0 34.0 34.0 12.0 12.5 14.5 15.5 17.7 19.9 22.0 24.2 28.5 28.5 28.5 28.5 12.0 12.0 12.0 12.0 12.2 14.4 16.5 18.7 23.0 23.0 23.0 23.0 12.0 12.0 12.0 12.0 12.0 12.0 12.0 13.2 17.5 17.5 17.5 17.5 12.0 12.0 12.0 12.0 12.0 12.0 12.0 12.0 12.0 12.0 12.0 12.0 </constant> <constant name="aseCntTable" rows="10" units="cycles"> 350 330 310 290 270 250 230 210 180 150 </constant> <constant name="asePctTable" rows="10" units="%"> 45 43 41 39 37 35 33 31 28 25 </constant> <constant name="baroCorrDelta" rows="6" units="%"> 0.0 0.0 0.0 0.0 0.0 0.0 </constant> <constant name="baroCorrVals" rows="6" units="kPa"> 80.0 90.0 100.0 105.0 110.0 120.0 </constant> <constant name="crankPWTable" rows="10" units="ms"> 12.0 11.2 10.4 9.6 8.8 8.0 7.2 6.4 5.2 4.0 </constant> <constant name="matCorrDelta" rows="6" units="%"> 0.0 0.0 0.0 0.0 0.0 0.0 </constant> <constant name="matCorrTemps" rows="6" units="?F"> 40.0 60.0 100.0 130.0 160.0 180.0 </constant> <constant name="matRetard" rows="6" units="deg"> 0.0 0.0 2.0 4.0 6.0 8.0 </constant> <constant name="matTemps" rows="6" units="?F"> 160.0 180.0 200.0 220.0 240.0 260.0 </constant> <constant name="primePWTable" rows="10" units="ms"> 6.0 5.6 5.2 4.8 4.4 4.0 3.6 3.2 2.6 2.0 </constant> <constant cols="12" name="veTable1" rows="12" units="%"> 26 26 29 34 40 46 50 55 58 61 61 60 29 29 32 38 46 53 56 60 63 66 65 62 38 37 39 44 53 61 65 67 69 73 71 66 43 42 43 45 54 63 66 69 71 75 73 67 48 46 48 50 58 65 69 71 73 77 75 69 52 51 52 55 62 67 71 73 75 79 77 71 57 59 61 65 69 72 76 78 81 85 85 80 61 62 65 69 72 75 79 82 85 89 88 84 65 66 69 73 76 78 82 86 90 93 92 88 68 70 73 78 81 83 86 90 94 98 97 93 72 77 82 87 90 93 95 100 105 109 108 103 74 81 86 91 95 97 100 105 111 114 113 108 </constant> <constant cols="12" name="veTable2" rows="12" units="%"> 26 26 29 34 40 46 50 55 58 61 61 60 29 29 32 38 46 53 56 60 63 66 65 62 38 37 39 44 53 61 65 67 69 73 71 66 43 42 43 45 54 63 66 69 71 75 73 67 48 46 48 50 58 65 69 71 73 77 75 69 52 51 52 55 62 67 71 73 75 79 77 71 57 59 61 65 69 72 76 78 81 85 85 80 61 62 65 69 72 75 79 82 85 89 88 84 65 66 69 73 76 78 82 86 90 93 92 88 68 70 73 78 81 83 86 90 94 98 97 93 72 77 82 87 90 93 95 100 105 109 108 103 74 81 86 91 95 97 100 105 111 114 113 108 </constant> <constant name="xTauCLT" rows="10" units="%"> 20000 15000 10000 8000 5800 4800 3600 2400 1200 100 </constant> <constant name="xTauMAT" rows="10" units="%"> 140 136 126 116 110 106 104 102 100 100 </constant> <constant name="xTauOption">"Off"</constant> <constant cols="12" name="xTauTable" rows="12" units="sec"> 0.19 0.15 0.12 0.09 0.06 0.05 0.04 0.03 0.03 0.02 0.02 0.01 0.21 0.19 0.13 0.10 0.07 0.06 0.05 0.04 0.03 0.03 0.02 0.01 0.22 0.19 0.15 0.12 0.09 0.08 0.06 0.05 0.04 0.03 0.02 0.02 0.23 0.20 0.16 0.13 0.10 0.09 0.07 0.05 0.04 0.03 0.02 0.02 0.24 0.21 0.17 0.14 0.11 0.10 0.08 0.06 0.04 0.04 0.03 0.02 0.26 0.23 0.18 0.15 0.13 0.11 0.09 0.07 0.05 0.04 0.03 0.02 0.27 0.24 0.19 0.17 0.14 0.12 0.10 0.07 0.05 0.04 0.03 0.02 0.28 0.25 0.20 0.18 0.15 0.13 0.11 0.08 0.06 0.05 0.03 0.03 0.29 0.26 0.21 0.19 0.16 0.14 0.12 0.08 0.06 0.05 0.04 0.03 0.30 0.27 0.22 0.21 0.18 0.15 0.13 0.09 0.06 0.05 0.04 0.03 0.31 0.28 0.23 0.22 0.19 0.16 0.14 0.10 0.07 0.06 0.04 0.03 0.33 0.29 0.24 0.23 0.20 0.17 0.15 0.10 0.07 0.06 0.04 0.03 </constant> <constant name="xTdecel" units="%">100</constant> <constant name="xTscale">1</constant> <constant name="xTx" units="%">30</constant> </page> </msq> Frank
[Re: FrankR]
#726183
12/14/07 11:57 PM
It is more difficult that way, I can install this MSQ into my system and open it with Mega tune.
Are you set up for Hybrid Alpha N?
[Re: OldColt]
#726184
12/15/07 12:15 AM
Hybrid Alpha N is the MAP/MAF blending, right? No, I am using the MAP sensor only.
I just sent the .msq file via email. If you need it in a different format, let me know what you need. Thanks.
Frank
[Re: FrankR]
#726185
12/15/07 12:37 AM
It is back to you. I did an estmate on the ignition. I also let the EGO correction available full time, it was set like a narrowband. Come to think of it I did not look at all the O2 settings but some of that is not in the MSQ.
You can do a save as for your MSQs allowing you to keep track of them better than the timestamp that defaults to them.
[Re: OldColt]
#726186
12/15/07 12:45 AM
Thanks - I'll install the modified file and see if it starts.
Frank
[Re: FrankR]
#726187
12/15/07 01:09 AM
No joy...
I have not installed the IGN pullup resistor because it seemed "iffy" that it would need it. What do you think?
Frank
[Re: FrankR]
#726188
12/15/07 01:13 AM
Are you running the Opto or going direct to the processer? But a pullup is needed since the dizzy is just a switch. I get +5V from within the VR conditioning area to install a 450 Ohm pullup.
[Re: OldColt]
#726189
12/15/07 01:24 AM
Are you running the Opto or going direct to the processer? But a pullup is needed since the dizzy is just a switch. I get +5V from within the VR conditioning area to install a 450 Ohm pullup. I don't understand what you're saying there. I'm using the VB921 high current ignition driver in MS, triggering the coil (-). The distributor is from a '90/'91 Montero (assuming it's good - haven't tested it in a vehicle) and I'm taking the signal from the low resolution wheel (6 signals/revolution) and not using the high resolution signal at all. When I was checking the distributor (off the truck and not connected to MS) to see which wire was which with my digital voltmeter, I applied B+ to the sensor. I found the signal output voltage low - about .2v - does that indicate that I need to install the pullup resistor circuit? If so, what value resistor would you use? Frank
[Re: FrankR]
#726190
12/15/07 01:46 AM
The MS will trigger the spark with the VB921, this is it's output.
A pullup will be in the input circuit. The original MS is setup for either a set of points,(using the Opto isolator) or a VR sensor.
Mitsubishi uses a simple trigger for switching the timing events, this provides a rather clean signal especially with a shielded conductor. The MS2 has a 1K resistor on the processor pin used for the input so not much other conditioning is needed. So you can get by with a wire from the 37pin connector to the processor and install a pullup so the Dizzy has something to switch.
