Re: G-Raider 3.0L Supercharger Project
[Re: FrankR]
#726211
12/15/07 11:23 PM
Under base ignition, you mean move the trigger offset number that you changed to 60? If so, do I need to "Burn to ECU" after each change? Missed this, Yes you need to burn.
[Re: OldColt]
#726212
12/15/07 11:32 PM
Maybe it kicked hard and jumped time. Geez... I reckon it did. The passenger side cam cover is completely broken... <img src="/forums/images/graemlins/scared.gif" alt="" /> belt's loose on the sprockets. I think I need to cut some more bait. <img src="/forums/images/graemlins/barf.gif" alt="" /> Frank
[Re: FrankR]
#726213
12/15/07 11:36 PM
That sucks! I expect the valves are gone from the noise, maybe not.
[Re: OldColt]
#726214
12/15/07 11:38 PM
If the belt is that loose, is it broken or did an idler or the tensioner fail?
[Re: OldColt]
#726215
12/15/07 11:39 PM
I expect the valves are gone from the noise, maybe not. Shouldn't be - non-interference engine..... but it still sucks. Frank
[Re: OldColt]
#726216
12/15/07 11:42 PM
If the belt is that loose, is it broken or did an idler or the tensioner fail? I don't know yet - It's still around both cam sprockets..... just loose. Maybe I forgot to tighten the tensioner with all of the cam work I did. Frank
[Re: FrankR]
#726217
12/15/07 11:45 PM
That has been done before. If it is, it will be nice if no damage is done. Bad enough that it will take a day to check and reset it.
[Re: OldColt]
#726218
12/16/07 12:27 AM
It can wait until tomorrow. <img src="/forums/images/graemlins/lol.gif" alt="" />
I do have a hunch, though. Something hard had to have been leveraged against the cam cover to break it like that - it's broken at both mounting bolts. My guess is the tensioner spring broke, caught in the belt, rode between the belt and sprocket until it reached the cam cover and.... bang!
I'd bet a beer on it....... I'll know tomorrow... maybe.
Frank
[Re: FrankR]
#726219
12/16/07 12:56 AM
Of course it is under the Accy mount so no easy access.
[Re: OldColt]
#726220
12/16/07 01:21 AM
Nope - not easy...... radiator, A/C compressor, P/S pump and crank pulley all have to come off. I've never replaced one with the engine in the truck, but there's a first time for everything.
Frank
