Rating: 5
Page 63 of 131 1 2 61 62 63 64 65 130 131
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726211 12/15/07 11:23 PM
Under base ignition, you mean move the trigger offset number that you changed to 60? If so, do I need to "Burn to ECU" after each change?
Missed this, Yes you need to burn.
Re: G-Raider 3.0L Supercharger Project [Re: OldColt] #726212 12/15/07 11:32 PM
FrankR Offline OP
Maybe it kicked hard and jumped time.
Geez... I reckon it did. The passenger side cam cover is completely broken... <img src="/forums/images/graemlins/scared.gif" alt="" /> belt's loose on the sprockets.
I think I need to cut some more bait. <img src="/forums/images/graemlins/barf.gif" alt="" />
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726213 12/15/07 11:36 PM
That sucks! I expect the valves are gone from the noise, maybe not.
Re: G-Raider 3.0L Supercharger Project [Re: OldColt] #726214 12/15/07 11:38 PM
If the belt is that loose, is it broken or did an idler or the tensioner fail?
Re: G-Raider 3.0L Supercharger Project [Re: OldColt] #726215 12/15/07 11:39 PM
FrankR Offline OP
Shouldn't be - non-interference engine..... but it still sucks.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: OldColt] #726216 12/15/07 11:42 PM
FrankR Offline OP
I don't know yet - It's still around both cam sprockets..... just loose. Maybe I forgot to tighten the tensioner with all of the cam work I did.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726217 12/15/07 11:45 PM
That has been done before.
If it is, it will be nice if no damage is done. Bad enough that it will take a day to check and reset it.
Re: G-Raider 3.0L Supercharger Project [Re: OldColt] #726218 12/16/07 12:27 AM
FrankR Offline OP
It can wait until tomorrow. <img src="/forums/images/graemlins/lol.gif" alt="" />
I do have a hunch, though. Something hard had to have been leveraged against the cam cover to break it like that - it's broken at both mounting bolts. My guess is the tensioner spring broke, caught in the belt, rode between the belt and sprocket until it reached the cam cover and.... bang!
I'd bet a beer on it....... I'll know tomorrow... maybe.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726219 12/16/07 12:56 AM
Of course it is under the Accy mount so no easy access.
Re: G-Raider 3.0L Supercharger Project [Re: OldColt] #726220 12/16/07 01:21 AM
FrankR Offline OP
Nope - not easy...... radiator, A/C compressor, P/S pump and crank pulley all have to come off. I've never replaced one with the engine in the truck, but there's a first time for everything.
Frank
PHP: 7.4.33 Page Time: 0.024s Queries: 16 (0.021s) Memory: 0.6594 MB (Peak: 0.7790 MB) Data Comp: Off Server Time: 2026-06-12 14:48:47 UTC
