Rating: 5
Page 82 of 131 1 2 80 81 82 83 84 130 131
Re: G-Raider 3.0L Supercharger Project [Re: OldColt] #726401 01/21/08 10:30 PM
FrankR Offline OP
Why do you want a colder plug? That is old school chevy tuning stuff.
I guess partly because I'm an old school Chevy tuning guy.
The VR4 runs the same plug as the NA engines.
Not exactly. It does run the same heat range as the sedans. The Montero was spec'd with a heat range 5 and the sedans were spec'd with a heat range 6 which is a colder plug than the Montero.
BPR5ES-11 = Montero
BPR6ES-11 = Diamante SOHC
BKR6ES-11 = Diamante DOHC
BKR6ES-11 = 3000GT non-turbo
BKR6ES-11 = 3000GT VR-4 turbo
In NGK terminology, the following are the codes
1st Character
B = 14mm hex size
2nd Character
P = projected insulator type
K = 5/8" projected tip
3rd Character
R = resistor type
4th Character
2 = hot -> <- 12 = cold
5th Character
E = 3/4" thread reach
6th Character
S = standard center electrode type
7th (and 8th if used) Character
11 = .044" gap
I agree that the heat range 6 plug with the standard gap should work fine. I did get detonation in the prior engine with heat range 5 plugs, but that wasn't the only issue. In this case, I was trying to get some extra insurance until the tune was finished..... but too much insurance isn't always a good thing.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726402 01/21/08 10:47 PM
The only real difference is the reduced wrench size.
Re: G-Raider 3.0L Supercharger Project [Re: OldColt] #726403 01/21/08 11:20 PM
FrankR Offline OP
How so when the OE Montero plug is a heat range 5 and the others are a heat range 6?
Perhaps it isn't a large difference, but there's enough difference between the heat range 5 and heat range 7 that my engine won't start.
I'm ordering a BPR6ES-11 set and will see how they work - I agree that they should be fine since the Diamante SOHC heads are the same. As for the combustion chamber, I tend to look at the piston top as a part of the chamber during combustion and mine is different since I have a full dished top instead of the normal squish area of the 8.9:1 pistons. I suspect the lack of squish area might also be a reason why the heat range 7 plugs won't fire the mixture.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726404 01/22/08 12:27 AM
Sorry I was refering to the all the higher powered engines. I have done no work with the Montero SOHC engine.
Re: G-Raider 3.0L Supercharger Project [Re: OldColt] #726405 01/22/08 01:16 AM
FrankR Offline OP
I just got a set of BPR6ES-11 NGKs from AutoZone. When I get back from the exhaust shop tomorrow I'll install them and see how they work.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726406 01/22/08 02:47 AM
Frank, these are the mitsu spec for the 2v Starion. I know, different chambers, but the heat ranges are all the same at 7. With your lower boost, 6 sounds right to start with.
BUR7ES-11 Alternate plug BPR7ES-11 or BP7ES11
Re: G-Raider 3.0L Supercharger Project [Re: fasteddy] #726407 01/22/08 09:19 PM
FrankR Offline OP
The heat range 6 plugs work - maybe a little longer cranking time, but they seem ok at idle.
Charlie, I have the dwell set at 3.1. I backed it off until I heard definite idle misfires around 2.0, but in between the 2 values, the idle wasn't as smooth, so I set it back to 3.1. Would I be better off to cut it back to just above definite misfire and then readjust the VE table tune... or leave it where it is? What have you found Mitsubishi coils to need as a minimum dwell?
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726408 01/22/08 10:49 PM
My stuff has all been up in the 3.6 range.
Re: G-Raider 3.0L Supercharger Project [Re: OldColt] #726409 01/22/08 11:09 PM
FrankR Offline OP
Thanks - maybe I'll try raising the dwell and see if it starts easier. From your experience, I guess the OE coil can take that much dwell without damage.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726410 01/22/08 11:15 PM
Try working on the voltage compensation rather than raising the base dwell. You may need to be up in the 5 to 6 range when cranking.
PHP: 7.4.33 Page Time: 0.022s Queries: 15 (0.020s) Memory: 0.6635 MB (Peak: 0.7690 MB) Data Comp: Off Server Time: 2026-06-10 07:25:44 UTC
