Rating: 5
Page 83 of 131 1 2 81 82 83 84 85 130 131
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726411 01/22/08 11:17 PM
I have a dwell meter. Want me to check the dwell on a stock 3.0 coil? I guess we'd have to convert degrees into milliseconds (microseconds?). Guessing from your units...
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726412 01/22/08 11:24 PM
FrankR Offline OP
I just checked CAPS for the coil #s on the Montero 3.0L SOHC and the Diamante 3.0L SOHC. The coils look identical, but have different part numbers:
MD131711 = Montero
MD166146 = Diamante
Mitsubishi still shows both part #s available, yet the Beck-Arnley catalog shows the same coil for both vehicles.
I have a Diamante coil - I might try it on the chance that it was an upgraded piece.... maybe it generates a better spark for the heat range 6 plugs.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: fasteddy] #726413 01/22/08 11:28 PM
FrankR Offline OP
Eddy, it would be better if you have an inductance meter and can tell me what the coil primary measures. Then I could run the formula for dwell time.
I've never tried to convert degrees into time-based, but maybe we could do it..... yes, the dwell values in MS are milliseconds.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726414 01/23/08 12:10 AM
FrankR Offline OP
Interesting...... I changed to the Diamante coil - the markings on the coil are the same with the exception of 4 small digits below the "Diamond" logo.... they're different.
It may be my imagination, but the engine seemed to start sooner and idle smoother with the Diamante coil. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726415 01/23/08 01:16 AM
Y
yankneck696 Offline
I swapped a Diamante, Stealth & Monty coil 1 day to show a customer that it's all the same. I think I still have the Stealth coil in place, but am running the Jacobs setup I found in a Saab....
Sheesh.... I miss working in the junk yard !!!
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: G-Raider 3.0L Supercharger Project [Re: yankneck696] #726416 01/23/08 01:24 AM
FrankR Offline OP
If they're the same, why would MMC still offer separate coils for the Montero and Diamante?
I'm not saying one won't work in another engine, but there must be some minor difference - particularly since they have identical shapes.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726417 01/23/08 01:43 AM
G
generation_one Offline
Frank
ole man eddy nodded off
is it the black or white wire?
I dont know if I can reach those wires without undoing a harness.(havent looked yet-it's cold out)
have a dwell meter too and that might be easier
EDIT
Okay never mind -until spring thaw. I just touched the connector and killed the engine.
Wires too brittle in this cold to mess with...those are brittle anyway
Re: G-Raider 3.0L Supercharger Project [Re: generation_one] #726418 01/23/08 04:03 PM
As a matter of fact, I did. Sleeping upright is not as fun as it used to be, either...
Frank, I'm too dumb to know if I have an inductance meter. I know what inductance is, but never measured any. Remember, me and 'lectrons don't really get along...
Re: G-Raider 3.0L Supercharger Project [Re: generation_one] #726419 01/23/08 04:17 PM
FrankR Offline OP
Charlie, you might find this interesting - maybe even useful:
I've read that most automotive coils have an inductance value between 4 and 10 milliHenries. The VB921 coil driver in MS is current limited to ~ 6.5A. Using the OE spec coil primary winding resistance of .72 - .88 ohms, a 6.0A current value and the 4 - 10mH inductance limits..... and plugging the values into the MS calculator, I get a dwell range of 2.48 - 6.59 milliseconds.
If I use the mid-point values, I get 4.47 milliseconds dwell time.
Odds are, I can increase dwell time to where you've set yours - around 3.5 or so. I'll try it and see if the coil gets hot and if the engine starts better.
I'd sure like to get my hands on an LC meter for a few minutes to see what the coil inductance value really is. Would an automotive shop likely have one?
Frank
Re: G-Raider 3.0L Supercharger Project [Re: fasteddy] #726420 01/23/08 04:19 PM
FrankR Offline OP
Also called an L meter or LC meter or LCR meter.
Frank
PHP: 7.4.33 Page Time: 0.022s Queries: 15 (0.019s) Memory: 0.6564 MB (Peak: 0.7655 MB) Data Comp: Off Server Time: 2026-06-10 00:04:57 UTC
