Rating: 5
Page 91 of 131 1 2 89 90 91 92 93 130 131
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726491 03/05/08 12:35 AM
Hi Frank,
Now that you have some time on this now, do you have any issues with hot starts? You have the IAT sensor in a pretty thick piece of aluminum and this has given some people fits in the past.
Re: G-Raider 3.0L Supercharger Project [Re: OldColt] #726492 03/05/08 02:04 AM
FrankR Offline OP
It takes the same time to start when hot as when cold - not very quickly - maybe 3 revolutions to fire. I noticed there is a 2 msec prime pulse set for starting (I think - need to check closer) and I remember you said it's best to defeat that function. As it begins to fire, it sounds like it's backfiring through the blower, but I can't really tell - tried leaner and richer with no change - maybe the prime pulse is the cause.
Sometimes, the idle speed is high on hot starts, but that may be an IAC control issue.
I don't think I have any issues with the IAT sensor. I counter-bored the side of the discharge plenum to get a socket on the sensor, plus the probe is set well into the airstream. Also, I'm using the fast reading open element sensor - not the solid probe style.
Interestingly, I haven't seen really hot discharge temperatures..... nothing noted over 175*F yet - even with sustained boost. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Fuel economy continues to improve, with the change to 29" tires adding maybe 1 mpg on today's trip to Atlanta - even at 75-80 mph. I'll try to check it at 65mph on the way home this weekend.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726493 03/05/08 03:03 AM
I expect it's quite comical for some folks to see a couple of cold sober geezers in an old truck - driving like drunken teenagers...... intentionally...... with just a hint of a smile on otherwise serious faces.
I'm used to it. I drive like that all the time. <img src="/forums/images/graemlins/evil.gif" alt="" />
Frank, see if you have any real tootsie rolls in the tire pile, like some of those 275/60-15's I used to have on the D50 pickup. I could outcorner Beemers on those tires. And they'd leave more impressive donuts...
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726494 03/09/08 02:02 AM
FrankR Offline OP
On today's drive from Atlanta to Columbia between 65-72 mph (trying to maintain 67 mph) - 201 miles traveled - consumed 10.06 gal for a very good average of 19.98 mpg..... I'll call it 20 mpg. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726495 03/09/08 02:04 AM
A bit of difference in rolling resistance would you say! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: G-Raider 3.0L Supercharger Project [Re: OldColt] #726496 03/09/08 02:46 AM
FrankR Offline OP
More like wind resistance - I got 17mpg on the street tires on the first trip, driving 75mph. I noticed long ago that the Gen1 sweet spot is around 65mph... might be better at lower speeds, though.... I just can't seem to drive any slower than 65 on an interstate highway and maintain my sanity. <img src="/forums/images/graemlins/lol.gif" alt="" />
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726497 03/10/08 10:09 PM
FrankR Offline OP
I've found one quirk with the change to MegaSquirt.... the A/C compressor no longer works.
In checking the FSM wiring schematic, it looks like the A/C engine temperature switch leg runs through the OE ECU before the A/C relay can be powered. I don't yet know if the circuit is a pass-through in the ECU, but it might be possible to jumper the ECU in/out legs in the now unused OE ECU connector.
Charlie, did you run into this on any of your MS installations? If so, how'd you work around it?
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726498 03/10/08 10:32 PM
G
generation_one Offline
that's what appears from the schematic...but somewhere inside that black box the idle speed is bumped up.
The classy thing to do is re-wire it all to an on/off switch
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: G-Raider 3.0L Supercharger Project [Re: generation_one] #726499 03/11/08 12:11 AM
FrankR Offline OP
Yes, that's why it runs to the ECU - for idle speed control.
I'm guessing that the connection in the ECU is a pass-through with a tap that feeds a signal to the IAC stepper motor.
When I get some time to play with it, I'll jumper GR-#1 on C-39 to BW on C-40 and see if it works.
The ON/OFF switch is already there and wired - it's on the dash where the little button says "A/C". <img src="/forums/images/graemlins/lol.gif" alt="" /> All I "think" I need to do is repair the now open circuit.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726500 03/11/08 12:56 AM
The AC power goes through the ECU so the compressor can be cut off at high power and abnormal temperatures.
PHP: 7.4.33 Page Time: 0.021s Queries: 15 (0.018s) Memory: 0.6604 MB (Peak: 0.7700 MB) Data Comp: Off Server Time: 2026-06-10 01:41:29 UTC
