Re: G-Raider 3.0L Supercharger Project
[Re: fasteddy]
#726591
04/09/08 07:34 AM
I don't really have anything to add. I just wanted to claim post #1000 on this thread <img src="/forums/images/graemlins/smile.gif" alt="" />
KG6VNX
[Re: fasteddy]
#726592
04/09/08 12:25 PM
Gee I wanted to be the 1000th poster but Eddy got it!
[Re: OldColt]
#726593
04/09/08 03:51 PM
I'm not called Fast Eddy for nuthin'...
[Re: fasteddy]
#726594
04/09/08 04:42 PM
Apparently, Clay's faster than the both of ya <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: hazy_daze]
#726595
04/09/08 05:09 PM
Ahh that dang rollover to another page, I thought Eddy had it, so he closed out the first 1000 and Clay opened the second. It is good this project will go on so Frank can achieve a 2000 post thread <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: OldColt]
#726596
04/09/08 05:34 PM
Amen to that!!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: hazy_daze]
#726597
04/11/08 02:33 AM
I was only the 2000th poster, including the original post. Clay was the 2000th reply...
Frank, I think the problem is all in the lightbulbs. I think you need to review and incorporate the light bulb post in this one, and we'll nuke the server. Just think, the technically perfect combined with the totally inane. We'll draw schitzes from all over...
[Re: fasteddy]
#726598
05/04/08 09:26 PM
This view is becoming too common: I neglected to post this picture during the build - it shows how the restrictive collector was removed and re-jiggered for a flanged 2.5" Y-pipe outlet: After your blower has eaten a roller bearing cage and roller, here's why you don't just change the oil and filter and hope for the best: Not only do those pieces of steel and aluminum go into the cylinders and get smashed into the valve seats, some make their way past the ring end gaps and find their way into the sump: from where they can migrate into undesirable areas - like between this rod bearing and journal: ![[Linked Image]](http://img370.imageshack.us/img370/6848/img4193ak1.jpg) The main bearings and journals look ok: Since I had the piston pins pressed instead of installed as floating, I'm hoping I can clean up the pistons without worrying about contamination between the wrist pins and bushings.... since the mains are ok, I'm assuming the oil filter worked and kept stuff out of the oil gallery. The rod journal contamination probably was from sump splash which shouldn't have gotten on the wrist pins. Anyway, it looks like a cylinder rehone, crankshaft polish, new bearings, rings, a valve and seat dressing, new valve seals, gaskets and oil seals..... and a very thorough block, piston, rod, oil pickup and oil cooler/lines cleaning is in order. The Magnacharger rep called to say they've inspected the blower and found that I experienced a rear bearing failure..... really? <img src="/forums/images/graemlins/lol.gif" alt="" /> They're now rebuilding it. Frank
[Re: FrankR]
#726599
05/04/08 10:55 PM
I asked about engine damage and suggested that their product should be liable for damages..... offered to provide the labor if they would pay for necessary machine work and needed parts. He spoke with a supervisor, called me back and said we need to take it one step at a time.... nothing was off the table, but they want to see the blower first. OK, back to the stuff on the table. Are they going to pay for your engine parts and machine work?
1990 Monty LS 3.0 A/T LWB. KYB front shocks, OME rears and coils. 33x10.5 BFG Muds. 5.29, 2.85, RD110, RD46. 2 bouncys. Aisins. Monte Disco swaybar disconnects. GenII t-arms, idler arm, UCA's, V45W front brakes. 2in BL.
[Re: DirtDriver]
#726600
05/04/08 11:00 PM
<img src="/forums/images/graemlins/barf.gif" alt="" /> <img src="/forums/images/graemlins/barf.gif" alt="" /> <img src="/forums/images/graemlins/barf.gif" alt="" />Dear God, it looks like a grenade went off in there, Frank. x2 on wanting to if they're going to compensate for incidental/consequential damage. As always, let me know if I can help with anything.
