Rating: 5
Page 116 of 131 1 2 114 115 116 117 118 130 131
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726741 11/09/09 01:27 AM
StockRaider Offline
I was wondering what you happend to use to wash your block? Also, nice white color <img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: G-Raider 3.0L Supercharger Project [Re: StockRaider] #726742 11/09/09 01:51 AM
FrankR Offline OP
I just used car wash soap and water, a rag and a long bore brush..... Simple Green would probably work well, though.
You do have to take care it doesn't rust. I sprayed the decks and bores with WD-40 while it was still wet, blew it dry with compressed air, then sprayed the areas to be painted with brake parts cleaner before painting it.
The white color is an old habit for marine engines in dark engine spaces. The white color makes it easy to see oil leaks...... so, I thought I'd try it on this one. I doubt it'll stay very white once it's on the road, but it might be helpful initially.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726743 11/09/09 08:35 AM
StockRaider Offline
Nice, I hope you don't mind if I steal your paint color.<img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard E
1983 Honda XL600R
Re: G-Raider 3.0L Supercharger Project [Re: StockRaider] #726744 11/09/09 09:14 AM
4ePikanini Offline
that is a very nice engine colour! I like it.
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: G-Raider 3.0L Supercharger Project [Re: 4ePikanini] #726745 11/10/09 04:05 AM
White is nice. Even road dirt washes off pretty easy, unless there's a leaker, so even washed tracks stand out. All the lines and hoses and tubes and such stand out against the white, too, making visual discovers easier.
Re: G-Raider 3.0L Supercharger Project [Re: fasteddy] #726746 11/10/09 08:13 AM
87Montero Offline
Glad you picked white, because everyone knows what happens once you go black...
Re: G-Raider 3.0L Supercharger Project [Re: 87Montero] #726747 11/11/09 01:51 AM
1
1986powerram50 Offline
You cant find oil leaks??? Or is it something else? <img src="/forums/images/graemlins/pfft.gif" alt="" />
--keRby
Ad Inexplorta
Re: G-Raider 3.0L Supercharger Project [Re: 1986powerram50] #726748 11/11/09 04:46 AM
FrankR Offline OP
The crankshaft is installed. The mains have .003" clearance and end play is .006" - not as good as the last crankshaft and looser than I'd prefer, but still within service limit specs:
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726749 11/12/09 01:24 PM
FrankR Offline OP
Yikes!
Today was going to be spent measuring/fitting rods, pistons and rings, but before going that far I wanted to double back and check on something that has been nagging at me.
When I took the parts to the machine shop, I couldn't remember the torque value for the main studs and told the machinist I'd call him back after I researched it. He said not to worry, he'd look it up. I figured that was good enough, given the fellow's reputation.... and when I picked up the block, I did not think to ask him what torque value he used before align honing the main bores.
All day yesterday, that kept nagging at me, so I called and asked him what torque value he used. The answer was "48 lb-ft with ARP assembly lube". <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/cyclops.gif" alt="" />
That sorta got my attention, since the ARP torque spec is 86 lb-ft with ARP lubricant.
So, today the block is going back to the shop for another attempt at align honing........ this time on his nickel.
Frank
Re: G-Raider 3.0L Supercharger Project [Re: FrankR] #726750 11/12/09 01:52 PM
StockRaider Offline
<img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> good save.
Richard E
1983 Honda XL600R
PHP: 7.4.33 Page Time: 0.024s Queries: 15 (0.021s) Memory: 0.6554 MB (Peak: 0.7638 MB) Data Comp: Off Server Time: 2026-06-10 01:46:57 UTC
