Re: G-Raider 3.0L Supercharger Project
[Re: FrankR]
#726741
11/09/09 01:27 AM
I was wondering what you happend to use to wash your block? Also, nice white color <img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: StockRaider]
#726742
11/09/09 01:51 AM
I just used car wash soap and water, a rag and a long bore brush..... Simple Green would probably work well, though.
You do have to take care it doesn't rust. I sprayed the decks and bores with WD-40 while it was still wet, blew it dry with compressed air, then sprayed the areas to be painted with brake parts cleaner before painting it.
The white color is an old habit for marine engines in dark engine spaces. The white color makes it easy to see oil leaks...... so, I thought I'd try it on this one. I doubt it'll stay very white once it's on the road, but it might be helpful initially.
Frank
[Re: FrankR]
#726743
11/09/09 08:35 AM
Nice, I hope you don't mind if I steal your paint color.<img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: StockRaider]
#726744
11/09/09 09:14 AM
that is a very nice engine colour! I like it.
 Karma's Law - For every action there is a multiplied reaction! 93 Pajero GLS 3.0 V6 LWB - SOLD 2001 Gen3 Di-D LWB - SOLD 2005 Touareg R5 2.5 TDi
[Re: 4ePikanini]
#726745
11/10/09 04:05 AM
White is nice. Even road dirt washes off pretty easy, unless there's a leaker, so even washed tracks stand out. All the lines and hoses and tubes and such stand out against the white, too, making visual discovers easier.
[Re: fasteddy]
#726746
11/10/09 08:13 AM
Glad you picked white, because everyone knows what happens once you go black...
1999 Mitsu Montero - Crappy Weather 1992 Isuzu Pickup - Zombie Apocalypse 2008 Saturn Sky Redline - Nice Weather
[Re: 87Montero]
#726747
11/11/09 01:51 AM
Glad you picked white, because everyone knows what happens once you go black... You cant find oil leaks??? Or is it something else? <img src="/forums/images/graemlins/pfft.gif" alt="" />
--keRby
Ad Inexplorta
[Re: 1986powerram50]
#726748
11/11/09 04:46 AM
The crankshaft is installed. The mains have .003" clearance and end play is .006" - not as good as the last crankshaft and looser than I'd prefer, but still within service limit specs: Frank
[Re: FrankR]
#726749
11/12/09 01:24 PM
Yikes!
Today was going to be spent measuring/fitting rods, pistons and rings, but before going that far I wanted to double back and check on something that has been nagging at me.
When I took the parts to the machine shop, I couldn't remember the torque value for the main studs and told the machinist I'd call him back after I researched it. He said not to worry, he'd look it up. I figured that was good enough, given the fellow's reputation.... and when I picked up the block, I did not think to ask him what torque value he used before align honing the main bores.
All day yesterday, that kept nagging at me, so I called and asked him what torque value he used. The answer was "48 lb-ft with ARP assembly lube". <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/cyclops.gif" alt="" />
That sorta got my attention, since the ARP torque spec is 86 lb-ft with ARP lubricant.
So, today the block is going back to the shop for another attempt at align honing........ this time on his nickel.
Frank
[Re: FrankR]
#726750
11/12/09 01:52 PM
<img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> good save.
